Stainless Rod
Vic07/11/2021 13:52:50
3453 forum posts
23 photos
As I don’t like stuff going rusty I use this quite a bit. Recent purchases on the auction site have yielded vastly different results. Some stuff was of nominal size and just looked like a rolled finish, although reasonably round I expect. Other items were bang on size and seem to have a machined finish. I find myself needed some of the latter and wondered if any of you know of a good source. I suppose I may have to get some purpose ground stuff so what should I look for that’s not too expensive? Grade is immaterial except I need to drill and tap the ends and face off. Probably something around 15/16mm dia. TIA.
noel shelley07/11/2021 14:22:40
2308 forum posts
33 photos
At the moment any steel is expensive, what sort of quantities are we talking ? do you want magnetic or non magnetic, 304 or 316, your looking for ground stock ! Noel.
martin haysom07/11/2021 14:32:55
165 forum posts
grade is important as some stainless will rust
Vic07/11/2021 16:15:05
3453 forum posts
23 photos
Any of the 300 series should suffice as long as I can tap it. I’ve actually been making stuff from some old magnetic 400 series and that’s not gone rusty in my workshop. It’s not for outside use. I’ll probably only need half a metre. I think 14mm diameter will do and I have a reamer that size.
not done it yet07/11/2021 17:35:15
7517 forum posts
20 photos
I suspect Cromwell Tools would yield fair quality, but at some expense.
They trade on-line as Zoro. Things seem quite a bit cheaper through zoro - but likely better deals from the stores if one has an account…
