Clutch slip
Salvie Cudlip06/11/2021 23:03:06
15 forum posts
6 photos
Hi all,
I have clutch slip on my myford ml7! Cleaned, and deglazed shoes. Refitted, still the same.
can you buy aftermarket shoes? Can you also get the roll pin for the adjuster on the clutch?
many thanks
not done it yet07/11/2021 11:21:52
7517 forum posts
20 photos
Is the roll pin something special?
might be cheaper than a single roll pin from a ‘specialist’.
Plenty of other alternatives if one searches for them.
noel shelley07/11/2021 12:04:39
2308 forum posts
33 photos
The cluch shoes were from a raleigh moped possibly a runabout ! they require very careful adjustment. If the shoes are in good order it should be possible to get them relined. you refer to a roll pin, do you mean the push rod ? Good luck. Noel.
bernard towers07/11/2021 12:56:18
1221 forum posts
161 photos
I was thinking on those lines Noel but had it stuck in the back of my mind they were D1 bantam.
Salvie Cudlip07/11/2021 13:21:53
15 forum posts
6 photos
Thank you all for replying!
Apologies for my incorrect terminology! Push pin looks too short! The shoes look absolutely fine, loads of material on them.
I’ve deglazed the shoes and inner drum. When I adjust the pin so the clutch is completely engaged, the pin sometimes falls out . I’m thinking of making a longer pin so the adjusting screw won’t be wound in so much.
I have some bar which I should be able to run down to diameter.
I’ve taken pictures but unfortunately can’t send from my phone!
Really appreciate the replys
salvie
Salvie Cudlip11/11/2021 07:27:27
15 forum posts
6 photos
Made up a new push pin, slightly longer than the one fitted. Clutch working fine now . Thank you for information
