sean logie | 31/10/2021 20:35:55 |
![]() 608 forum posts 7 photos | Hi It's been a while since I've been on here ,asking for some help and information .Today I bought this lathe knowing it had a couple of issues but I paid a good price for it. The first and main issue is the cross feed hand wheel is MIA the feed screw is bent just before it goes into the cross slide ,the casting that bolts onto the face of the cross slide where the feed screw and handwheel are supported is missing . Basically I need the whole cross feed screw assembly . I may manage to straighten the outer part of the feed screw I'm not sure . The serial number at the tailstock end is ...CUD--ll--26640, Is this lathe metric or imperial . I'm maybe not making any sense but I'm sure somebody will correct me. Is there a good source for parts for this lathe or is it a case of just hunting them down . Reason I'm so unprepared on this lathe is that my wife sprung it on me today ,she knew I was watching it so she sent a lowball offer which was accepted .
TA Sean |
old mart | 31/10/2021 20:54:39 |
4655 forum posts 304 photos | A good source of info on Boxford is on the "lathes UK" website, they may have parts lists also. |
sean logie | 31/10/2021 21:02:37 |
![]() 608 forum posts 7 photos | Posted by old mart on 31/10/2021 20:54:39:
A good source of info on Boxford is on the "lathes UK" website, they may have parts lists also. Thankyou
Clive Brown 1 | 31/10/2021 23:12:26 |
1050 forum posts 56 photos | Sean, I think it's difficult to make out metric or imperial machines from the serial number. AFAIK, metric Boxfords have the tailstock spindle graduated in metric units.( My imperial machine is in inches). The feed dials have 0.02mm graduations. The lead screw is 3mm pitch. |
sean logie | 01/11/2021 04:55:42 |
![]() 608 forum posts 7 photos | Posted by Clive Brown 1 on 31/10/2021 23:12:26:
Sean, I think it's difficult to make out metric or imperial machines from the serial number. AFAIK, metric Boxfords have the tailstock spindle graduated in metric units.( My imperial machine is in inches). The feed dials have 0.02mm graduations. The lead screw is 3mm pitch. Thanks Clive |
Speedy Builder5 | 01/11/2021 08:53:28 |
2878 forum posts 248 photos | Sean, if you decide to measure the lead screw pitch mm / Threads Per Inch, be aware that the 3mm pitch metric lead screw is very similar to the 8TPI imperial lead screw (ie 3mm / 3.175mm). Bob |
Micky T | 01/11/2021 09:03:04 |
![]() 76 forum posts 29 photos | Hi Sean you can try **LINK** there is a gentleman called Mark Lord on there who sells spares for Boxford lathes via a site called simplylathes.co.uk, you could contact him as he may well have the parts that you need. Regards, MickyT |
sean logie | 01/11/2021 16:48:26 |
![]() 608 forum posts 7 photos | Posted by Micky T on 01/11/2021 09:03:04:
Hi Sean you can try **LINK** there is a gentleman called Mark Lord on there who sells spares for Boxford lathes via a site called simplylathes.co.uk, you could contact him as he may well have the parts that you need. Regards, MickyT Appreciate that Mickey |
Bazyle | 01/11/2021 20:48:41 |
![]() 6956 forum posts 229 photos | The cross feed screw mount in a sort of tube of varying widths along its length, then has the dial and handle attached. This makes up a self contained assembly. I'll take a photo later of the standard bits. |
Bazyle | 02/11/2021 12:19:59 |
![]() 6956 forum posts 229 photos | This is the cross slide screw for a Boxford A so has the built in gear for the facing feed which you will not have. PS in my last post I didn't mean taper rollers I meant roller thrust bearings. Edited By Bazyle on 02/11/2021 12:32:20 |
Grindstone Cowboy | 02/11/2021 12:48:48 |
1160 forum posts 73 photos | That's totally different to the cross-slide screw on my Boxford Model C (bench type) - mine has ball thrust bearings, resettable dials and endfloat adjustment - and I have no reason to think these features were not original (it has the same set-up on the compound too). Maybe the power crossfeed on the A and B models necessitated a different arrangement? Rob |
Bazyle | 02/11/2021 14:23:53 |
![]() 6956 forum posts 229 photos | Interesting. The spares site shows the thrust bearings so I wonder when it was introduced. Possibly 1963 from the spares list so postdating mine by several years. I see the 'tube' is called the 'cross side bush'. |
Nicholas Farr | 02/11/2021 15:12:40 |
![]() 3988 forum posts 1799 photos | Hi, well I guess diagram R in the scan below was an earlier version. Regards Nick. |
sean logie | 07/11/2021 19:17:31 |
![]() 608 forum posts 7 photos | I'll insert a photo of my cross feed screw. I have sourced a couple of parts, the casting that houses the outer thrust bearing washers and supports the hand wheel along with a micrometer dial which is imperial which I might be able to work with until I source a metric one . I'm toying with making a hand/thumb wheel . Going by what I've read this is not the standard cross feed screw. Parts seem quite hard to find . Anyone have a set of thrust washer bearings for this Cross feed screw below Edited By sean logie on 07/11/2021 19:18:51 Edited By sean logie on 07/11/2021 19:43:00 |
Pete Rimmer | 07/11/2021 20:06:12 |
1486 forum posts 105 photos | Drawing for your screw. Looks pretty standard to me. Only difference is the metric pitch on yours. Edited By Pete Rimmer on 07/11/2021 20:07:21 |
Grindstone Cowboy | 07/11/2021 20:26:48 |
1160 forum posts 73 photos | Just for the sake of my sanity, can you clarify whether your lathe has power cross-feed or not? If it has, it's not a Model C, so that may indicate the bed is not original (or the saddle/carriage/leadscrew assembly isn't, depending how you look at it). Rob |
Pete Rimmer | 07/11/2021 20:35:05 |
1486 forum posts 105 photos | That screw is for a model A or B but it'll work in a model C all the same. Could be that someone swapped it out. |
sean logie | 07/11/2021 20:56:50 |
![]() 608 forum posts 7 photos | Posted by Grindstone Cowboy on 07/11/2021 20:26:48:
Just for the sake of my sanity, can you clarify whether your lathe has power cross-feed or not? If it has, it's not a Model C, so that may indicate the bed is not original (or the saddle/carriage/leadscrew assembly isn't, depending how you look at it). Rob Hi Rob, my lathe is a Boxford model CUD ,I believe this screw is not original to my lathe, but it fits and works none the less. Having it gives me options I believe ...
Sean |
Grindstone Cowboy | 07/11/2021 21:52:26 |
1160 forum posts 73 photos | Thanks Sean |
Dave Halford | 08/11/2021 19:39:56 |
2536 forum posts 24 photos | I suspect it's a CUD that tripped on the pub doorstep during a heavy night out, it might pay you to look for cracks in the apron. |
