John Smith 47 | 26/10/2021 19:05:44 |
393 forum posts 12 photos | Hello This is probably a bit mad but.... Fwiw, when I need a more accurate, cleaner finish than a hand file, I often use a diamond stone. But I find that it always requires quite a lot of skill to create a true 90° face when either filing by hand or using a diamond stone...
Edited By John Smith 47 on 26/10/2021 19:23:49 Edited By John Smith 47 on 26/10/2021 19:28:35 |
Dave S | 26/10/2021 19:24:22 |
433 forum posts 95 photos | Are you trying to do a 90 degree end - i.e. square across from long side to short side, or a 90 degree included angle at some angle to the long side? Picture (simple sketch) would probably resolve the ambiguity. Look up “Filing rest” with a pair of rollers. Dave |
John Smith 47 | 26/10/2021 19:30:46 |
393 forum posts 12 photos | I need it to be square to both at once. Edited By John Smith 47 on 26/10/2021 19:31:05 |
HOWARDT | 26/10/2021 19:34:14 |
1081 forum posts 39 photos | A four wheeled toy won’t work. A four wheeled design with a parallelogram movement allowing the blade to be free to move downwards as the wheels move apart with downward pressure. Don’t recall seeing anything similar. |
Dave S | 26/10/2021 19:39:29 |
433 forum posts 95 photos | Posted by John Smith 47 on 26/10/2021 19:30:46:
I need it to be square to both at once. Edited By John Smith 47 on 26/10/2021 19:31:05 ? That’s as illuminating as a blown 10w bulb. A sketch would be simple, but I think you are attempting to face the end of the bar to it’s long axis? In which case a lathe will just do that, and a roller filing jig will also with appropriate fixture to hold the plate. Dave |
John Smith 47 | 26/10/2021 19:57:37 |
393 forum posts 12 photos | It's mind numbingly simple. |
JasonB | 26/10/2021 20:20:43 |
![]() 25215 forum posts 3105 photos 1 articles | Pull the axle out of your current jig and replace with a longer one so you can mount two larger wheels sufficient to increase the angle it can grind to 90deg. Edited By JasonB on 26/10/2021 20:27:32 |
Ian P | 26/10/2021 20:33:28 |
![]() 2747 forum posts 123 photos | I foresee two problems with Jason's suggestion. One is the requirement to have a slot in the stone, and secondly how will the user know the edge is at exactly 90 degrees (angle changes as the steel is ground away. Ian P |
JasonB | 26/10/2021 20:41:24 |
![]() 25215 forum posts 3105 photos 1 articles | I'll ignore the first and as for the second if it's the way Brian has got "remarkably accurate" 45deg angles then the change of angle as the blade or workpiece wears is obviously not an issue to him. |
Ian P | 26/10/2021 20:41:38 |
![]() 2747 forum posts 123 photos | Four wheel chariot could hold the 'steels' at 90 degrees. How many do you need to make John? |
John Smith 47 | 26/10/2021 21:04:24 |
393 forum posts 12 photos | OK here is my 3D sketch Here's my part:
EDIT: Wait, it is also important that all of the sides - particularly the long ones are as close to being parallel as possible. So a tolerance of say 0.2mm would be fine. So my sketch should look more like this: In the first instance I only need to make four such pieces. > and the resulting block could be filed by hand to exact size
Edited By John Smith 47 on 26/10/2021 21:16:03 Edited By John Smith 47 on 26/10/2021 21:19:23 |
Dave S | 26/10/2021 21:20:38 |
433 forum posts 95 photos | 2 or 3 angle plates and a pair of rollers. Set the whole lot on a flat surface. Adjust the rail to give required size, push up against angle plate to give squareness. Sketch appears to be at 90 degrees to the intention. |
Robert Butler | 26/10/2021 21:27:21 |
511 forum posts 6 photos | The earlier 45 degree and 90 degree angles and accurate sizing could have been achieved using the Unimat 3 lathe only which was dealt with in the earlier postings. The 90 degree setting in either axis with accurate sizing and repeatability should be achievable using your Proxxon milling machine with suitable jigs or stops, simples! Robert Butler |
John Smith 47 | 26/10/2021 21:35:41 |
393 forum posts 12 photos | Jason, the main problem with your design is my current hone has a roller rather than a pair of removable wheels. Also I can't just cheerfully destroy it because I am still using it to cut 45 deg chamfers!
I still say a 4-wheeler toy with nice hard plastic wheels & zero suspension could be made to work. You would need to push hard down too keep the wheels on the ground. Maybe really solid a little toy railway carriage...(?!) with a vertical cut through the centre of it. Of course one would need to take care not to accidentally grind any of the wheels....
Edited By John Smith 47 on 26/10/2021 21:37:50 |
Dave S | 26/10/2021 21:45:07 |
433 forum posts 95 photos | This: is a roller filing jig for a lathe. the 2 rollers guide the file in a linear manner. Traditionally they are used with a head stock division plate to file squares and other polygons onto the end of round stock. Squint a bit and refer to my sketch and you will see how to make such a thing. However Robert is correct - use a machine to do the job Dave
peak4 | 26/10/2021 22:05:24 |
![]() 2207 forum posts 210 photos | Re filing guides, I was watching this video earlier; the whole thing is quite interesting, but the bit from 2:20 in might be applicable to your requirements. If I've done this correctly, it might even start in the right place. |
John Smith 47 | 26/10/2021 22:35:21 |
393 forum posts 12 photos | Robert Butler - even though Yes, I am still regretting letting that Unimat 3 slip through my hands. It was certainly looked like a bargain. |
Howard Lewis | 26/10/2021 22:47:16 |
7227 forum posts 21 photos | IF you had a lathe with a large enough headstock bore, (Probably 5 MT to pass 32 mm ) the plate could be gripped in a four jaw chuck and faced In this way, if the side faces of the plate were square to each other, which i would expect ground flat stock to be, the facing operation would produce end faces square to the rest of the material. But it looks as if that is an impossible situation for you. This not something that you are going do on your own, without a lot of very careful, and time consuming FITTING work Where are you located ? Maybe someone near you could help? Howard |
peak4 | 26/10/2021 23:08:09 |
![]() 2207 forum posts 210 photos | As a source for carbide, as per my previous video link, may I suggest paint scraper blades such as these. https://harrisbrushes.com/product/protection-and-preparation/ultimate-super-scraper-blades/ You can pick them up for about £7 a pair off ebay for 65mm ones |
John Smith 47 | 27/10/2021 00:40:10 |
393 forum posts 12 photos | Posted by peak4 on 26/10/2021 22:05:24:
Edited By John Smith 47 on 27/10/2021 00:42:09 |
