Looking for dimensions/Drummond gear change fork
chris bale 123/10/2021 10:16:42
10 forum posts
9 photos
I'm after a bit of info if anyone has one, i need a few dimensions from the gear fork of a little drummond, to help get this lathe running again, my intension is to make a 3d printed version as a mock up to prove, then maybe make a 2part piece from 2 bits of ali, round stock and a bit of plate. Made a quick sketch on freecad. Proberbly a bit much but here is hoping, thanks in advance.
I need:
the angle between the forks
the length of the slots
A rough distance of the start of the slots from the center of the fixing boss
The distance of where the shoulder bolt/gear bolts are in relation to its mounting boss machined face on lathe bed. Seems to be inline with the recess around the boss.
Ady123/10/2021 11:00:48
6137 forum posts
893 photos
Is it the banjo you mean?
(Perhaps a mod would change the title)
Martin Kyte23/10/2021 11:06:52
3445 forum posts
62 photos
If it's a roundbed I could perhapse help. I do have one in bit's.
regards Martin
Michael Gilligan23/10/2021 11:14:48
23121 forum posts
1360 photos
Posted by Martin Kyte on 23/10/2021 11:06:52:
If it's a roundbed …
From Chris’s album photos … it would appear not sad
DiogenesII23/10/2021 11:16:51
859 forum posts
268 photos
Think this is for the OP's Type B?
Er, Ady, (and others?), do you think the M type (or any other Drmd. fitment) might be the same?
Edited By DiogenesII on 23/10/2021 11:17:39
Edited By DiogenesII on 23/10/2021 11:20:41
Ady123/10/2021 13:11:42
6137 forum posts
893 photos
My answer is probably
but needs to be checked
My lathe boss is 1.75" outer diameter
chris bale 123/10/2021 15:02:33
10 forum posts
9 photos
Yes the banjo, last photos didn't upload so reuploaded.
Its the one with the screw feed at the front, still unsure of the model
Lee Rogers23/10/2021 16:10:44
203 forum posts
Posted by DiogenesII on 23/10/2021 11:16:51:
Round bed Pre B, Btype and M are all different. Your best bet is to keep an eye out for a donor lathe .
This is how I ended up with 6 1/2 B types but in the end it is an economical way of stocking up on spares .
theres a healthy market for anything you don't need.
Lee Rogers23/10/2021 16:11:02
203 forum posts
Round bed , Pre B, Btype and M are all different. Your best bet is to keep an eye out for a donor lathe .
DiogenesII24/10/2021 18:33:17
859 forum posts
268 photos
Chris, if you haven't seen this page, it's worth a look in detail, particularly the photo about 3/4 of the way down whose caption begins 'Instead of a single slot L-shaped...' & which shows a compound reduction train for fine feed, which is likley to take up as much 'banjo-room' as you are likely to need - it's common to put one's largest wheel on the leadscrew, leaving the next largest pair and the next smallest pair to be compounded into two sets to fill the gap between the spindle and that - as the 'top' pair will be on the 'main leg' of your banjo, the length and angle of the lower slot will constrained quite narrowly by the need to mesh these to the leadscrew gear..
It's a rather complicated thing to describe, I hope the pictures help explain it better.. I notice that the ends of the banjo are shown in the picture, you may be able to approximate the lengths and angle by experimenting with cardboard templates or by drawing them up..
Lathes.co.uk - Drummond B-Type Lathe..
