Workhead Taper
Chris Crew | 06/10/2021 21:32:37 |
![]() 418 forum posts 15 photos | I have a J&S 1310 EIU cylindrical grinder the work-head of which has an internal spindle taper of 1.4375" 3.5"/foot. I have never been able to source an additional J&S chuck back-plate with an integral male taper of this size. The only alternative is to manufacture one in the lathe, finishing it on the grinder itself as I have J&S accessories with this taper integral to them to use as a setting gauge. However, if this taper is a recognised standard I may be able to obtain one from a dealer. So, does anyone recognise this taper as a standard or is it particular to J&S machines? |
John Haine | 06/10/2021 22:11:55 |
5563 forum posts 322 photos | 3.5" per foot is the same taper angle as BT tapers I think. Which end is the 1.4375"? |
Pete. | 06/10/2021 22:21:33 |
![]() 910 forum posts 303 photos | like this Chris Ebay listing Is that your listing Chris? Edited By Pete. on 06/10/2021 22:23:00 |
Pete. | 06/10/2021 22:39:11 |
![]() 910 forum posts 303 photos | I should have read the listing, did you buy this one in error? |
Chris Crew | 06/10/2021 23:07:40 |
![]() 418 forum posts 15 photos | Pete, Yes, it is my listing and, yes, I did buy this one blind but in error. I have tried to get the correct one from several J&S legacy dealers but nobody has been able to help me. It was one of the dealers who supplied the information about the taper but he was unable to supply the correct taper. |
Chris Crew | 06/10/2021 23:15:11 |
![]() 418 forum posts 15 photos | John, the 1.4375" dimension is of the large end although I have not measured it myself to confirm. The taper data was supplied by a J&S legacy dealer who also supplied a few other details about my machine which actually surprised me as I had no idea such details would be on record. This was the email he sent me: - Hi Chris |
Bazyle | 06/10/2021 23:43:29 |
![]() 6956 forum posts 229 photos | INT20 is the one sometimes used for T&C grinder workheads. Never seen one on ebay when I was looking a few years ago as they would normally be carefully kept with the grinder or binned when some dumbos liquidated the business. All the INT sizes have the same taper but the base threaded boss for the drawbar won't allow a larger size to fit the smaller socket. However a BTversion (ie BT30) which has the same taper as the INT but no boss can clumsily fit and ISO20 or INT20 socket I think. |
Pete. | 06/10/2021 23:43:59 |
![]() 910 forum posts 303 photos | There's another on ebay, the seller has put that it's a 50 int, is yours a small 30 taper as John says 3.5"/foot is an iso taper? if it is maybe searching for this would find you something. Ebay 50int |
Chris Crew | 06/10/2021 23:52:08 |
![]() 418 forum posts 15 photos | Pete, I have INT30 tapers on some milling machine tooling and it does not fit the grinder work-head. Someone is suggesting INT20 may be the one to try but I have never actually seen this taper before, so it may be quite rare. |
David George 1 | 07/10/2021 07:03:44 |
![]() 2110 forum posts 565 photos | Chris have you tried Andmar machinery services. https://www.andmar.co.uk/ David |
Chris Evans 6 | 07/10/2021 09:00:42 |
![]() 2156 forum posts | Plus 1 for trying Andmar. Andmar rebuilt a 1310 for me when I was managing a toolroom but it was maybe 20 or more years ago. |
Bazyle | 07/10/2021 19:43:00 |
![]() 6956 forum posts 229 photos | You know that BT taper, Iso taper and INTernational tapers are all the same angle, all 7/24. A google of ISO20 came up with this instantly. The small 20 size is much more common in USA ebay than the UK. |
Chris Crew | 07/10/2021 21:08:45 |
![]() 418 forum posts 15 photos | Thanks to you all for your kindly advice. I have e-mailed Andmar with an enquiry and I am just awaiting on their response. |
Howard Lewis | 08/10/2021 12:50:46 |
7227 forum posts 21 photos | Have just consulted my Apprentice training notes. Inetrnational Taper is 3.5" per foot. Dimensions: No.30 INT Length, flange to end 2.625" , Major diameter 1.25" Parallel diameter 0.5625" No.40 INT Length, flange to end 3.5625" Major Diameter 1.75" Parallel diameter 0.6406" No.50 INT Length, flange to end 5.125", Major diameter 2.750" Parallel diameter 1.250" Howard |
Chris Crew | 08/10/2021 15:48:36 |
![]() 418 forum posts 15 photos | Howard, thank you. I think we can now discount any idea that the taper is INT/ISO as I have just measured the taper major and minor diameters (as far as is practicable) with a digital vernier. The major diameter is almost certainly 1.4375", which corresponds to the dimension given in the e-mail, and the minor diameter appears to be 0.850. over a distance of 2.250". There is approx 0.500" of parallel beyond the end of the taper of 0.750" diameter. This contains a fine thread which I suspect will be 0.625" UNF L/H. Not sure what the included angle will come to without drawing it out and applying some elementary trig. I did e-mail Andmar as advised by David and attached a photo of the taper I require alongside the one I bought in error but so far I have not received a reply. Edited By Chris Crew on 08/10/2021 15:50:29 |
Howard Lewis | 09/10/2021 10:19:13 |
7227 forum posts 21 photos | Have a look at "Tools-n-Gizmos" They list many tapers and their dimensions, so yours may be among them, somewhere. Could it be a B & S taper, possibly? Nearest might be No.11 Howard |
Bazyle | 09/10/2021 11:44:52 |
![]() 6956 forum posts 229 photos | I take it you are measuring the outer end of the throat . An int taper male does does not go in full depth of the socket - the dimensions given are just gauge points and the actual length provided by the manufacturer is variable. So if your outer end is 1.4 then it is probably intended for Int40 arbors. It is important that the arbor sits proud as in life some male tapers might have been damaged and reground and must not then vanish down the hole, The manufacturers of toolroom grinders were not entirely stupid They knew the primary purpose of the machine would be to sharpen the cutters for the works milling machines which would mostly have Int40 or Int50 spindles unless the company had been suckered into getting one with a proprietary taper to get locked into single source spares. Matching that on the workhead enabled greater precision and speed of turnaround, |
Chris Crew | 11/10/2021 16:13:57 |
![]() 418 forum posts 15 photos | Well, Andmar did get back to me in a very civil and professional manner and they could help me but, although I am sure the price is very competitive for a new back-plate, it is a little out of my budget. So the search goes on for a suitable used part or I will just have to get down to making one. |
