Help to identify this rotating table
AJAX04/10/2021 21:37:12
433 forum posts
42 photos
I'm not sure about this. It came with a milling machine I purchased recently but may have nothing to do with it. There appears to be no mechanism to lock rotation but I would welcome your correction.
20211004-202208 20211004-202221 20211004-202840
Can you help with identification or suggest a use?
Many thanks,
not done it yet04/10/2021 22:07:29
7517 forum posts
20 photos
Maybe set to the desired angle and secured in position via whatever was fitted to it?
No ideas apart from that initial thought.
Pete.05/10/2021 03:49:50
910 forum posts
303 photos
Looks like a vice base, a very specific vice that fits between the two raised edges on the ground surface.
Tony Pratt 105/10/2021 08:35:58
2319 forum posts
13 photos
Likely to be a cutter grinder vice base.
Tony
AJAX05/10/2021 10:57:28
433 forum posts
42 photos
Posted by Tony Pratt 1 on 05/10/2021 08:35:58:
Tony
That seems quite possible. Thanks
old mart05/10/2021 19:39:52
4655 forum posts
304 photos
The two studs may have the dual purpose of holding whatever was intended to sit on it and locking the rotation. Take it apart and all will be revealed.
Roger Best05/10/2021 20:59:26
406 forum posts
56 photos
That looks to be good quality. laugh
AJAX05/10/2021 21:46:41
433 forum posts
42 photos
Posted by not done it yet on 04/10/2021 22:07:29:
Upon dismantling the base it's quite clear the two studs do lock off rotation. If I'd looked more carefully I would have noticed the studs were partially threaded and the nuts were at their limit (thus not locking off). But adding some drilled flat across the studs I can confirm it locks solid.
20211005-212549 20211005-212603 20211005-212613 20211005-212644
AJAX05/10/2021 21:48:51
433 forum posts
42 photos
Posted by old mart on 05/10/2021 19:39:52:
Quite right - should have done that first! But I'm still none the wiser as to what it's from. The 90 degree scale should narrow things down, I guess.
20211005-213251
AJAX05/10/2021 21:50:57
433 forum posts
42 photos
Posted by Roger Best on 05/10/2021 20:59:26:
I think so.
And it was well looked after with a thick layer of grease (and so presumably was not being used on a grinder).
