AJAX | 04/10/2021 19:04:50 |
433 forum posts 42 photos | I'm now the proud owner of this suitably vintage milling machine and apart from the colour (which may or may not suit your taste) it appears to have been very well cared for and cuts surprisingly well. I've taken a few test cuts using 1/2" end mill in mild steel and the cutting was smooth and clean, something I didn't really expect as I'm used to a much larger machine (3 HP SEMCO at work). The machine does not use a draw bar and I'm unfamiliar with the collets which I'm guessing may be difficult to source. It came with quite a lot of tooling including a few 1/4" and 1/2" collets. For smaller tooling I'm wondering about making some custom tool holders with a fixing grub screw (grinding a flat on the tool). All comments welcome (including what colour I should paint it). Brian |
Dave Halford | 04/10/2021 20:46:04 |
2536 forum posts 24 photos | You only need 6 collets to cover all the relevant cutter shanks. 1/4" 3/8" 1/2" 6mm 10mm 12mm |
Michael Gilligan | 04/10/2021 21:02:23 |
![]() 23121 forum posts 1360 photos | Very useful looking little mill Z axis adjustment looks interesting … presumably it is this ‘BC’ model: **LINK** http://www.lathes.co.uk/portmac/ MichaelG. |
AJAX | 04/10/2021 21:14:26 |
433 forum posts 42 photos | Posted by Dave Halford on 04/10/2021 20:46:04:
Having just checked what I actually possess, I need to correct what I stated earlier. I have one each of 1/4", 3/8" and 1/2" collets. The milling machine also came with a good amount of end mills -- I'd guess at about 100+ which should keep me going a while. I don't have any metric collets, which may or may not be a problem. |
AJAX | 04/10/2021 21:23:17 |
433 forum posts 42 photos | Posted by Michael Gilligan on 04/10/2021 21:02:23:
Very useful looking little mill Z axis adjustment looks interesting … presumably it is this ‘BC’ model: **LINK** http://www.lathes.co.uk/portmac/ MichaelG. Yes, the Z axis is "interesting" but it seems to work very well. I've only tried it for a couple of test cuts but I rather like it already. Unlike most older machines I've owned, this one appears to have very little wear. I read the same webpage which mentions the "BC miller" but I wonder where the author gets that name from. Mine has various names on the castings including VM20 and VM4. When I Google "Portmac" all I get is Apple Mac computer ports! |
AJAX | 04/10/2021 21:25:11 |
433 forum posts 42 photos | The well-known Lathes website states the following: the spindle accepted standard dead-length Crawford collets (1.5" long with capacities ranging from 1/8" to 1/2" ) Is this something I could obtain without selling a kidney? Edited By AJAX on 04/10/2021 21:25:33 |
AJAX | 05/10/2021 23:32:05 |
433 forum posts 42 photos | Apparently they may be the same collets as used on a Herbert or Ward Models "0" or "1". I'd be grateful if anyone could confirm that. If I don't make any progress with collets then I may look at fitting an ER system instead (that may in fact be the better option) making use of the existing nose thread. |
Hollowpoint | 06/10/2021 07:29:29 |
550 forum posts 77 photos | That's a really nice little machine! Not seen one before. 😎 |
Michael Gilligan | 06/10/2021 08:08:44 |
![]() 23121 forum posts 1360 photos | Posted by AJAX on 04/10/2021 21:23:17: […] When I Google "Portmac" all I get is Apple Mac computer ports! . Disappointing to see that even this got me nowhere: **LINK** https://www.bristolmodelengineers.co.uk/?s=portmac&submit=Search MichaelG. |
John Haine | 06/10/2021 08:38:46 |
5563 forum posts 322 photos | The arrangement with the splined spindle is like the Myford VMB. Is there a fine downfeed? |
John Haine | 06/10/2021 08:40:18 |
5563 forum posts 322 photos | One could make those collets I'd have thought. |
Michael Gilligan | 06/10/2021 08:53:25 |
![]() 23121 forum posts 1360 photos | Posted by John Haine on 06/10/2021 08:38:46:
The arrangement with the splined spindle is like the Myford VMB. Is there a fine downfeed? . From the lathes.co.uk description, John: [quote] [/quote] MichaelG. . Edit: __ killed a smiley Edited By Michael Gilligan on 06/10/2021 08:54:38 |
AJAX | 06/10/2021 22:41:19 |
433 forum posts 42 photos | Posted by John Haine on 06/10/2021 08:38:46:
The arrangement with the splined spindle is like the Myford VMB. Is there a fine downfeed? Yes, there is. Rotate the large hand wheel (through which the spindle passes) and the feed can be finely controlled. Fingers also pass very close to the rotating spindle, so I might see if I can fit some sort of boot. I have too many jobs on at the moment (I stripped down a Multico A3 table saw and it's now an explosion of parts being repainted) but when I make some room I'll take more photos and possibly a video of it running. I think that will be worth doing as it seems a quite unique machine. |
AJAX | 06/10/2021 22:45:02 |
433 forum posts 42 photos | Posted by John Haine on 06/10/2021 08:40:18:
One could make those collets I'd have thought. I don't know whether I could make one of those collets but I'm sure I could turn something that would be useful. I did actually enquire about getting collets made (or adapted) and the price was not unreasonable but more than I'd like to pay now. I'm still wondering whether I can't make an ER collet adapter than fits on the spindle nose. |
AJAX | 06/10/2021 22:45:56 |
433 forum posts 42 photos | Posted by Michael Gilligan on 06/10/2021 08:08:44:
Posted by AJAX on 04/10/2021 21:23:17: […] When I Google "Portmac" all I get is Apple Mac computer ports! . Disappointing to see that even this got me nowhere: **LINK** https://www.bristolmodelengineers.co.uk/?s=portmac&submit=Search MichaelG. Yes, the apparently world-wide absence of information (apart from the Lathes website and a couple of posts here) is a bit curious. |
John Haine | 07/10/2021 07:36:29 |
5563 forum posts 322 photos | **LINK** is an article on making myford style collets, a similar method should work. |
AJAX | 19/11/2021 06:07:33 |
433 forum posts 42 photos | I have been working on this project somewhat intermittently but the mill has now been repainted and a new 3 phase motor fitted. Rather happy with the Leroy Somer 0.25 kW motor which cost only £31.20 including Vat and delivery and comes with a 3 year warranty.
Michael Gilligan | 19/11/2021 07:37:46 |
![]() 23121 forum posts 1360 photos | Posted by AJAX on 19/11/2021 06:07:33:
[…] Rather happy with the Leroy Somer 0.25 kW motor which cost only £31.20 including Vat and delivery and comes with a 3 year warranty.
. Please see my query on the concurrent ‘Chinese Lathe’ thread Thanks MichaelG. |
ega | 19/11/2021 11:17:05 |
2805 forum posts 219 photos | Posted by AJAX on 04/10/2021 21:23:17:...
When I Google "Portmac" all I get is Apple Mac computer ports! DuckDuckGo finds MG's link halfway down the first page. The link also seems to answer the colour point. |
