Ruggedising a Type 17 Stepper motor electrical connection
Greensands18/08/2021 16:38:29
449 forum posts
72 photos
Can anyone suggest a means of ruggedising the electrical connection to the Type 17 stepper motor as illustrated in the photo as the 4 lead connection provided with the motor is far from being workshop proof. One problem is that I do not know the correct term or type reference for this type of cable connection or whether or not more purposeful plugs exist which can mate directly with the socket which is a 6-way, the cable connection being 4-way. Any ideas or suggestions as to how to go about making the assembly more workshop proof would be much appreciated.
DC31k18/08/2021 17:25:29
1186 forum posts
11 photos
Plenty for 23 and 34, so they may be a starting point for inspiration, search terms or suppliers:
https://www.soigeneris.com/stepper-motors
https://www.thingiverse.com/thing:2481149
https://www.cnccookbook.com/gorgeous-nema23-stepper-motor-back-covers/
https://cnc4pc.com/3d-printed-back-motor-cover-kit-for-nema-23-60mm-570oz-in.html
duncan webster18/08/2021 18:24:22
5307 forum posts
83 photos
What I did was make up some longer bolts to replace those which hold the whole thing together and use them to hold a plate to the end. This plate protruded beyond the connector and supported a plastic box, in the side of which I had a grommet to support the 4 core cable. My motor didn't have a plug socket arrangement, so soldered connection inside the box
Not a brilliant photo, but it might help. I'll take a better one if it would help
Greensands18/08/2021 19:04:17
449 forum posts
72 photos
Hi Duncan Yes, another pic would be helpful
Journeyman19/08/2021 09:41:25
1257 forum posts
264 photos
There are a number of 3D printed covers / caps designed to provide cable restraint such as this one on Thingiverse. This particular example is for NEMA 23 size motor but could be re-drawn to suit, the right size cover is probably somewhere on the interweb! Found this one for NEMA 17.
Edit: Add link for 17 size
Edited By Journeyman on 19/08/2021 10:08:00
Dave S19/08/2021 09:57:13
433 forum posts
95 photos
The 'quick and dirty' way I have often employed is to turn the motor so the wires are at the bottom, secure to the motor body with a cable tie and 'pot' the whole connector and tie in hot melt glue.
noel shelley19/08/2021 11:19:01
2308 forum posts
33 photos
Like Dave, Fit a strip connector to the motor and continue to the controller in much thicker wire and pot the lot ! Noel.
John Haine19/08/2021 11:45:15
5563 forum posts
322 photos
Sugru is excellent for "potting" since you can mould it round the item and it supports itself.
Another method I used on the steppers on my lathe and dividing head, which have flying leads emerging from the motor, is to drill a hole at one end of a small plastic project box, pass the wires through the hole into the box, and glue it down on the side of the motor with Araldite.  Then terminate the flying leads with terminal strip inside the box on to multicore cable run through a grommet, screw on the box lid, and if necessary use a tie wrap round the flying lead for strain relief.  Will post a photo if I can find one.
This is the X axis drive on my VMB mill.  It uses a Type 23 stepper so a bit bigger, you would need a smaller box.  In this case the 8 flying leads from the motor needed some interconnect to put the windings in series, so they are soldered and heat-shrink sleeved, then the non-commoned ends connected to the choc bloc segments to connect to the leads to the driver - this could have also been soldered to save space.  The leads were actually led in from the end of the box, and protected by moulding Sugru around them.  At the other end the cable I made up has a spiral nylon binding, fixed at the otor end with heat shrink, and again moulded in Sugru.  Box lid has been unscrewed to get this shot.
Edited By John Haine on 19/08/2021 12:00:28
Edited By John Haine on 19/08/2021 12:23:42
Tony Pratt 119/08/2021 11:55:07
2319 forum posts
13 photos
Obvious answer is turn the motor 180 degrees so the connector is at the bottom.
Tony
Oven Man19/08/2021 12:06:41
204 forum posts
37 photos
I don't think there is much demand for end covers on NEMA 17 steppers as they are mainly used on 3D printers that don't operate in a particularly harsh environment. This is where the ability to design and 3D print something really comes into its own. I can't find any size 17 designs on the web that would fit to a motor that has a built in connector.
Peter
duncan webster19/08/2021 13:13:46
5307 forum posts
83 photos
photo below, but mine is a much bigger motor. There is a slight bend in the plate to accomodate the draft angle on the plastic box, and 2 of the motor securing screws have been replaced with longer. Mine were tapped into the outer end plate, not recessed like the OP's. It's not the easiest place to take photos, can't get camera far enough away reallyimg_20210819_120001.jpg
Neil Wyatt19/08/2021 18:10:32
19226 forum posts
749 photos
86 articles
Be wary of enclosing a stepper, as used in a high power application they can get quite hot.
