Dore Westbury x slide motorising
brian jones 1118/08/2021 11:10:00
347 forum posts
62 photos
Has anyone had success in fitting a traversing motor to the lead screw on a DW or other m/c
Things to be considered I think
what feed rates were deemed suitable
Given a 10 tpi thread what size motor, rpm, torque, gear ratio, dc watts, variable speed control
How was it disengaged for manual operation
Are there any commercial kits available
ps
i have for example got an old cordless drill motor/chuck which looks promising
Edited By brian jones 11 on 18/08/2021 11:15:04
pps i dont thin i need to go to the trouble of limit sw cut outs
Edited By brian jones 11 on 18/08/2021 11:21:11
JasonB18/08/2021 12:59:32
Have a search for "power feed" using the search box on the home page. loads of threads about home brew X axis feeds from wiper motors through to steppers all can be adapted to your machine.
Also ask yourself how much you really need one. I have on on my main mill and maybe only use it 5% of the time if that. If it did not cost me anything then I doubt I would have bought it. Depends what you intend to do on the mill.
Edited By JasonB on 18/08/2021 13:02:05
Durhambuilder18/08/2021 15:03:59
77 forum posts
5 photos
My Dore Westbury is the one in the photos on Tony Griffiths site, **LINK**, this has the original power feed option but I can truthfully say I’ve never used it whilst milling!
brian jones 1118/08/2021 16:02:41
347 forum posts
62 photos
OBTW Ive noticed one fundamental stumbling block, that is that the lead nut is fixed at the rhs side of the table so the lead screw winds in out out following the x slide - ie just like the Myford compound slide.
So attaching to the LHS end of the lead screw means an extension shaft (with horizontal slot for a drive Cog) poking out the full length of the table
Thats pretty clumsy I think
More work needed
Any ideas?
John Haine18/08/2021 16:09:26
5563 forum posts
322 photos
My VMB has a handle at each end. The LH one is modified to take a timing belt pulley and a pin clutch. Feeding manually I use the RH handle but I could use the LH one. It has lost it's micrometer scale but I have a DRO anyway. I'm sure a micrometer scale could be retained I just didn't need it. Sureley you do something like this at whatever end has the feed handle?
brian jones 1118/08/2021 21:39:04
347 forum posts
62 photos
Posted by JasonB on 18/08/2021 12:59:32:
Did a search on power feed before but it didnt give anything relevant hence my posting here
Michael Gilligan18/08/2021 21:48:40
23121 forum posts
1360 photos
Posted by brian jones 11 on 18/08/2021 21:39:04:
Have a search for "power feed" using the search box on the home page. […]
Here is a link to the home page, Brian: **LINK**
https://www.model-engineer.co.uk
The box you want is about half-way down that page.
Enjoy the exploration !
brian jones 1118/08/2021 22:02:01
347 forum posts
62 photos
Thnx MG I see what I did wrong, I was searching locally under workshop thread rather than the home page which goes across the whole site - stupid boy Pike again
not done it yet19/08/2021 08:21:28
7517 forum posts
20 photos
Would it not be better to seriously consider using some of that “ten grand’ and just buy complementary lathe and milling machines (such as Sieg) and retire both myford lathe and DW mill? And still have change after buying the extras like power feeds and DROs?
brian jones 1119/08/2021 10:04:52
347 forum posts
62 photos
Posted by not done it yet on 19/08/2021 08:21:28:
WHAT
I am reporting you to the Monsignor for obscene language
Wash your mouth out
speelwerk19/08/2021 10:51:31
464 forum posts
Posted by brian jones 11 on 19/08/2021 10:04:52:
WHAT
Wash your mouth out
I can read nothing obscene in ndiy post, it is always good advice to have a re-think. Niko.
