Michael Gilligan | 05/08/2021 10:29:01 |
![]() 23121 forum posts 1360 photos | This revelation is featured on BBC Science Focus: https://youtu.be/8C6IbJJ-mhM … Might be of interest MichaelG. |
KWIL | 05/08/2021 10:58:28 |
3681 forum posts 70 photos | Thank you Micheal. |
Ady1 | 05/08/2021 10:58:33 |
![]() 6137 forum posts 893 photos | A lot of the problems early civilisations had seem to stem from the number systems they used and the amount of brainpower required to translate and visualise those number signs into meaningful information which could be used to generate even more meaningful information into processes and conclusions Coding for computers has the same issue and various attempts have been made to simplify the visual result of all the bits of electronic lego in a coding structure, I suppose electronics had/has similar issues Once you simplify it into the correct format the average human brain fairly romps through the subject matter A simple example They are both base 10 compare doing long division or multiplication in roman numerals and decimal numerals Edited By Ady1 on 05/08/2021 11:03:37 |
Kiwi Bloke | 05/08/2021 11:26:15 |
912 forum posts 3 photos | Posted by Ady1 on 05/08/2021 10:58:33:
A lot of the problems early civilisations had seem to stem from the number systems they used and the amount of brainpower required to translate and visualise those number signs into meaningful information which could be used to generate even more meaningful information into processes and conclusions Coding for computers has the same issue and various attempts have been made to simplify the visual result of all the bits of electronic lego in a coding structure, I suppose electronics had/has similar issues Once you simplify it into the correct format the average human brain fairly romps through the subject matter A simple example They are both base 10 compare doing long division or multiplication in roman numerals and decimal numerals Edited By Ady1 on 05/08/2021 11:03:37 Yes, absolutely! Good points! Personal realization was trying to get to grips with musical notation, as an adult. It's a disaster! Usually, of course, it's something that children, not adults, grapple with, and kids will accept anything... The crazy system we have is the fault of the Catholic church. There are rational notation systems out there, but they'll never catch on: there's no point battling against the traditional system's self-renewing user base. |
Kiwi Bloke | 05/08/2021 12:03:44 |
912 forum posts 3 photos | Interesting discovery. The 'second tablet' seems to be a 'look-up table' for a limited range of triangle configurations, suggesting that the end-user wouldn't have understood the geometrical theory and couldn't work out general-case problems. Perhaps the theory wasn't known, and all that was available was empirical knowledge. Then along came theoretical understanding, with Pythagoras - although it's now suggested he merely popularized the theory. |
Nick Wheeler | 05/08/2021 12:46:58 |
1227 forum posts 101 photos | Posted by Kiwi Bloke on 05/08/2021 12:03:44:
Interesting discovery. The 'second tablet' seems to be a 'look-up table' for a limited range of triangle configurations, suggesting that the end-user wouldn't have understood the geometrical theory and couldn't work out general-case problems. Perhaps the theory wasn't known, and all that was available was empirical knowledge. Then along came theoretical understanding, with Pythagoras - although it's now suggested he merely popularized the theory. It's all very well knowing how to do the theoretical work, but the end user isn't going to waste time calculating them every time he needs to make a thingy fit a whatsit. He's going to use a look-up table. We still do it with tapping charts, screwcutting tables, fraction to decimal lists, log tables(maybe not so much now) etc. When I needed to screw cut several M20 threads it was much quicker, easier and therefore more efficient to look up the relevant dimensions and tolerances than working them out for myself. If I had to do a lot of that sort of work, I'd draw up my own chart laid out to suit me. |
Calum Galleitch | 05/08/2021 15:19:43 |
![]() 195 forum posts 65 photos | Posted by Kiwi Bloke on 05/08/2021 11:26:15:
Hmm, well. It's very easy to invent a notation system for music that is easier to understand; it's far harder to invent a notation system that accommodates extension as Western notation does. Many of the advantages of music notation as used in the West are only apparent to relatively expert musicians. And it is far simpler to learn to read than written English. |
