Are the optics saveable?
William S | 03/07/2021 20:52:58 |
![]() 80 forum posts 335 photos | Hello All Just after winning this piece of vintage kit, I said that it is going to be the best £134 or worst £134 I have probably ever spent! I'll let you decide:
So that what it looked liked inside upon arrival!, it was sold as being sat in a shed for a few years, seemed to be an uninsulated shed! The constant temperature changes and being basically a sealed unit means it has basically sweated inside, and ended up in the mess as seen above.
William S | 03/07/2021 20:53:37 |
![]() 80 forum posts 335 photos | However a bit of dismantling, WD40 and a razor blade, most rust was scraped off ending up with:
Not too bad if I say so myself! The only damaged I subjected it to was the cracked casting around the locking knob, this was not my finest hour and I am quite peeved with myself. The rust hasn't eaten in to the base metal really it had almost just furred up like scale in a kettle so was quite easily removed. Now mechanically it is in good condition there is very little wear, helped by the rather simple yet clever oiling system. Optically however it is challenged. Its internal soaking has dissolved what I believe were water slide transfers on the glass(or could they of been something else?), The glass ring around the spindle is totally void of any markings, this was like this on me dismantling it, however the minutes scale on the was in ''good'' condition because it was sandwiched between to pieces of glass however on me separating them to clean the water staining between has meant I have disturbed the very brittle transfer and ended up with: So basically it is useless as it stands, How do you think it is best saved? Could one get water slide transfers made up? Could lazer engraving be a contender?- My worry would be precision with this method, I.E., set up in the machine etc. There is a local firm who I am thinking of talking to. The glass ring I was thinking about setting it up on the my pantograph on a rotary table with a diamond drag tool in the spindle and scoring the glass. Again though my worry is actually getting it right as it all depends on getting them exactly 1 degree apart! (or does it?) Or is it a really specialist task? Would a company who produces microscopes be worth contacting. So there we go, please fire away with your thoughts! I look forward to hearing them William Edited By William S on 03/07/2021 20:53:53 |
Michael Gilligan | 03/07/2021 22:52:32 |
![]() 23121 forum posts 1360 photos | It doesn’t help with your predicament, William … but feast your eyes on this one: https://www.nielsmachines.com/en/pg-optical-dividing-head.html MichaelG. |
Alan Charleston | 04/07/2021 07:21:27 |
157 forum posts 26 photos | Hi William, It's probably a long shot, but the markings on the glass glass could have been etched into it, and made visible using a dark material (like the graduations on an old glass thermometer) which may have been washed out during wet storage. It might pay to get some finely powdered graphite, (or filed off pencil lead), and rub it across the surface of the glass where the markings are and see if any new markings appear. As I say, a long shot, but worth a try. Regards, Alan |
Chris Evans 6 | 04/07/2021 12:47:51 |
![]() 2156 forum posts | I believe PG are still trading, worth trying to contact them. They did have a fire in the late '90s so may not have older stock. |
old mart | 04/07/2021 15:15:07 |
4655 forum posts 304 photos | As Alan says, it is worth a very close look just in case the marks are etched as was common with instruments then. |
KW56 | 04/07/2021 15:58:18 |
8 forum posts | Hi, I have just been making waterslide transfers for a model I am making. Look on ebay for 'waterslide transfer paper'. It is available for laser or inkjet printers and you just create your transfer in either Word or CAD. print on a normal printer then apply just as we used to do on our Airfix models. |
Bazyle | 04/07/2021 16:03:04 |
![]() 6956 forum posts 229 photos | I'm not sure how these things work. Is the optical scale on a glass plate attached to the main spindle, I know should be obvious but just to make sure? If so the accuracy is in that scale, not the worm. Therefore normal dividing unless done on another similar quality device would not be 'up to spec'. |
William S | 04/07/2021 21:05:56 |
![]() 80 forum posts 335 photos | Hello all, thanks for all your thoughts, Yes Micheal, I have come across that, although that one has a resolution of 3 seconds as opposed to mine which is a 6 second resolution. I think they just engraved another line on the dial. That is about the extent of online information! Alan, and old mart, it was worth a try, I had a go today with some graphite it sadly didn’t highlight any etched markings so I don’t think it was previously etched. Making water slide transfers up is something I have contemplated, however accuracy is my biggest worry. Chris, you might be correct, I did a bit of online digging they appear to be under a slightly different name of PGT Ceewrite/Ceewrite engineering Ltd. I will give them a call and find out. Just quickly glancing google for PG hadn’t found much.
I like the idea of laying it out on a large scale, that is something worth thinking about. It was doable 40 years ago so it should be possible in this modern day and age! Thanks again, I’ll keep you posted with what I find out. William
Clive Hartland | 04/07/2021 22:02:53 |
![]() 2929 forum posts 41 photos | William, having replaced etched circles many times be aware that if you remove the circle, when replacing it will have to be accurately centered. The circles are in fact photo etched and then baked to set the etch permanently, I have never seen the markings come off. as a cost comparison a glass circle from a theodolite cost all but £200. There are optic companies who will make one, but of course cost is the crunch. |
Alan Charleston | 05/07/2021 07:11:03 |
157 forum posts 26 photos | Hi William, Sorry to hear there aren't any invisible etched graduations. One option to consider is forgetting about the optical part of the dividing head and converting it to a more usual configuration. If you can determine the number of turns of the handwheel required for 360 degrees, you should be able to make an appropriately graduated collar to fit on the handwheel shaft. You'd need to add a pillar to the body of the head to provide a reference mark to measure against - maybe with a vernier scale on it to improve the accuracy. Regards, Alan |
gerry madden | 05/07/2021 10:45:14 |
331 forum posts 156 photos | William, just a quick though occurs to me.... some of the graticles in my OMT microscope optics were almost so fine they were invisible to the naked eye. It might be worth going over the glass with a microscope to see if there is anything there, or at least the remnants of something which may show you where to put new marks if that's what you decide to do. Gerry |
Bazyle | 05/07/2021 20:12:04 |
![]() 6956 forum posts 229 photos | Some very rough calculations. If your photo reduction is 10:1 the master is 60 inches dia. And you have to mark up that master to 1 thou accuracy. If I've got this right I can understand why they are expensive. |
Michael Gilligan | 06/07/2021 20:44:37 |
![]() 23121 forum posts 1360 photos | I hope William will forgive the slight digression, but Gerry’s post prompts me to share this: https://www.newall.org.uk/omt/#header MichaelG. |
William S | 13/07/2021 23:56:29 |
![]() 80 forum posts 335 photos | A quick update: The prize goes to Gerry for suggesting that the markings might be practically invisible to the naked eye, which they almost are! They are absolutely miniscule, how they were done 40 years ago is blowing my mind! All markings on that ring are present and correct, I'm going to have a look at it tomorrow on the shadowgraph at work, hopefully I can then get some pictures as well. I found them by playing about with a little led bulb, I was just shining it down the hole and turning the handle when in the corner of the readout I just saw the flash of a very feint line and what looked like numbers above. I then twiddled the handle back and forth and could just see a few lines. You would not belive the relief that was. I then spent all day at work eager to get back as shortly after finding the lines I then subsequently lost them again! When I got home I took the glass ring off and in holding it up to a strong light I could just make out the blobs of the numbers and lines, all the way around the ring. Under my Prior dissecting microscope I can just about read each number! Although I don't have any of the actual magnifying hoods so I am unsure of the magnification, I will try as I said with the shadowgraph and post my findings. Many thanks William |
Michael Gilligan | 14/07/2021 05:59:49 |
![]() 23121 forum posts 1360 photos | Excellent news, William MichaelG. |
gerry madden | 14/07/2021 10:03:14 |
331 forum posts 156 photos | Thanks William. Its nice to know that one can give to the forum occasionally as well as take I also dont know how they can make these things so small ! Gerry |
Kiwi Bloke | 14/07/2021 11:30:02 |
912 forum posts 3 photos | Fascinating! It looks like you're winning - certainly hope so. Does anyone know how the markings are made? Pantograph and diamond (scratch) engraving? I gather diffraction gratings were ruled by similar refined, but essentially simple, methods. I'm sure I remember the 'Amateur Scientist' section of Scientific American had an article on DIY-making diffraction gratings - must have been in the '60s. Same source carried all sorts of exciting - and dangerous - projects, often involving very high voltages, toxic chemicals, etc. Now considered too dangerous even to think about... However, all the articles are/were available on data disks. Must get around to hunting them down! |
William S | 14/07/2021 23:46:26 |
![]() 80 forum posts 335 photos | Here’s some pictures of the “non existent” markings!
I think now my issue is some staining on the middle lens of the magnifying lens. It’s marked C Baker 1/2” 14x. If any one can suggest how that comes apart, I’ve unscrewed it in to 3 parts but I think there’s 2 glass parts together and moisture is trapped between them making it almost impossible to see through. I’ll get some more pictures it’ll explain better than I can say in words! I do understand the need to clock the ring Clive, there is putty which was/is acting as a locator, but I may replace this as it’s very delicate, Do you think the markings were done concentrically to the ring o.d/I.d or do I need to be creative? The ring had to come off to disassemble it, there was no way around that, I was very reluctant to remove the ring due to getting it back concentric. William |
Michael Gilligan | 15/07/2021 06:52:29 |
![]() 23121 forum posts 1360 photos | Posted by William S on 14/07/2021 23:46:26: […] I think now my issue is some staining on the middle lens of the magnifying lens. It’s marked C Baker 1/2” 14x. If any one can suggest how that comes apart, I’ve unscrewed it in to 3 parts but I think there’s 2 glass parts together and moisture is trapped between them making it almost impossible to see through. I’ll get some more pictures it’ll explain better than I can say in words! […] . Yes please, William … detail photos of the Baker would be interesting and hopefully ‘diagnostic’ From your brief description it sounds like there is a cemented achromatic doublet in there, and delamination may be the problem. MichaelG. . P.S. __ Impressive as it may be in the context of a large glass ring … 0.2mm high lettering is by no means uncommon on graticules/reticles Ref. https://www.graticulesoptics.com/manufacturing Edited By Michael Gilligan on 15/07/2021 07:06:57 |
