AEW VICEROY HORIZON MILLING MACHINE
Using 1mm cutters on a Viceroy miller.
Thomas Clarke18/06/2021 09:19:23
2 forum posts
Could someone please advise me on how I would go about attaching a 1mm cutter to this machine. It takes the Clarkson S Type collets with threaded cutters but I can't find any as small as 1mm. I look forward to any replies.
Thomas
img_20210318_152238_resized_20210618_085717041.jpgimg_20210318_152226_resized_20210618_085716573.jpg
Mark Simpson 118/06/2021 09:30:16
115 forum posts
30 photos
If it's a one off thread the end of a bit of silver steel (outside diameter same as one of your collets) and drill a 1mm hole in the other end and loctite a 1mm bit in (when, rather than if, you break it warm with a blow lamp and get the broken bit out...)
There are stacks of ER11 collet holders on ebay and the like, put one of those in a collet and tighten it up... Then you can hold any size of small drill or cutter The odds of it getting pulled out by a 1mm drill are small
The truth is that you will struggle to do 1mm holes with your machine, it doesn't go fast enough and raising the knee will require a lot of subtlety not to break the drill... I too have a heavy weight machine and it's hard work with small drills (at least they are cheap!)
Ady118/06/2021 09:43:48
6137 forum posts
893 photos
I tried 3 drills with a 1mm bit yesterday and it was too small for all of them
1mm is watchmaker kit
1.5mm is a doddle, fitted into them all but was too big for drilling out a MIG tip
Peter Cook 618/06/2021 09:55:47
462 forum posts
113 photos
Get or make a sensitive/micro drilling attachment with a small chuck. ARC & WARCO both do one with a 1/2" shank, and there are instructions on the web as to how to make one. Hold that in a suitable collet in the machine. It will give you the ability to down feed the drill by 10-15mm as well as holding it. Although the speeds will still be slow.
Roderick Jenkins18/06/2021 10:18:43
2376 forum posts
800 photos
Read the question guys! The OP is looking for a milling cutter. My solution would be to get a 1mm end mill with a 6mm Weldon shank and put this in a Weldon to Clarkson threaded adapter. Milling with cutters this small is possible with a knee only machine (like mine) with care. It looks like the maximum speed of the mill is 3000rpm which is slightly faster than mine, so definitely worth a try.
HTH,
Rod
DC31k18/06/2021 13:38:41
1186 forum posts
11 photos
Posted by Roderick Jenkins on 18/06/2021 10:18:43:
...My solution would be to get a 1mm end mill with a 6mm Weldon shank and put this in a Weldon to Clarkson threaded adapter.
Is this the same thing that is known as an FC3 cutter? And a Clarkson FC3 adaptor?
To the OP: see for background this thread:
https://www.model-engineer.co.uk/forums/postings.asp?th=76239
Robin Dufton18/06/2021 19:46:56
38 forum posts
10 photos
I wouldn't bother without a spindle speeder and they do occasionally come up second hand. 3mm is pushing it on a manual mill, trying to cut with a 1mm cutter would be pissing in to the wind, but then people use face mills in little Chinese mill drills.
