Brian Abbott | 17/06/2021 16:28:10 |
![]() 523 forum posts 95 photos | Hello all. Looking to maybe make a George Thomas retractable slide, Anyone know were i will find the drawings to purchase? Thanks |
Dave Wootton | 17/06/2021 16:45:18 |
505 forum posts 99 photos | Hi Brian There are drawings and instructions in G.H.T's Model engineers workshop manual which is still in print and full of information and drawings for much else besides. I think Hemingway do a kit for it. There's an easier to make one in Graham Meek's book Projects for your workshop.
Dave Edited By Dave Wootton on 17/06/2021 16:50:34 |
DC31k | 17/06/2021 16:45:18 |
1186 forum posts 11 photos | See third post of this thread: https://www.model-engineer.co.uk/forums/postings.asp?th=108552 |
Ady1 | 18/06/2021 07:47:25 |
![]() 6137 forum posts 893 photos | These gadgets are quite useful for the easiest type of screwcutting, external threads There is also a lifting type which can be used with a motor that reverses and no retraction is required between cuts, clever stuff If you are looking to speed up screwcutting a reversing motor switch should be your number one priority |
KWIL | 18/06/2021 10:00:48 |
3681 forum posts 70 photos | Posted by Ady1 on 18/06/2021 07:47:25:
There is also a lifting type which can be used with a motor that reverses and no retraction is required between cuts, clever stuff If you are looking to speed up screwcutting a reversing motor switch should be your number one priority Or alternatively you could make a Graham Meek style leadscrew reversing clutch and have the motor continue to run in a forwards direction. GHT style retractable slide is, I find, very useful indeed.
ega | 18/06/2021 10:59:34 |
2805 forum posts 219 photos | I'm not clear whether the retractable top slide or retractable screw cutting tool holder is intended. |
Graham Meek | 18/06/2021 11:08:43 |
714 forum posts 414 photos | There is one omission in the GHT plans with regards to the Retracting Topslide. An Erratum appeared some time during the articles publication in ME, but it never was included in his book. At least not the First Edition. Myford provide a cast recess in the topslide casting to clear their adjustment collar. On some castings this recess is not long enough to allow the fully designed retraction. I do not know if Myford altered this when they remodelled the topslide. This may have been accommodated by Myford's, as there were very close links between George and Chris Moore. Regards Gray,
Martin Kyte | 18/06/2021 11:45:33 |
![]() 3445 forum posts 62 photos | I made one from the Hemmingway kit although I have the book as well. The Hemmingway kit suppies the bearings, gears and left hand lead screw and nut. Very pleased with mine. It doesn't get used for screwcutting much but the advantages of the smooth operation and large micrometer dial which is free settable with a clamp screw is very usefull. It's not hard to make and worth it just for the better micrometer dial. regards Martin |
