A Martin Evans' dwg comment
Fowlers Fury | 09/06/2021 11:18:42 |
![]() 446 forum posts 88 photos | In a Martin Evans series from back in 1975, he appears to have pasted, as an after-thought, a drawing of the inside valve "bobbin" of a 3 cylinder loco. I'd welcome info please on what this comment might mean in terms of the bobbin.
JasonB | 09/06/2021 11:33:14 |
![]() 25215 forum posts 3105 photos 1 articles | What is the actual distance between the passages, best not to assume the two lines are lined up in which case 1 7/8" (1.875) seems likely. |
Martin Kyte | 09/06/2021 11:36:22 |
![]() 3445 forum posts 62 photos | The exaust clearance is the amount by which the valve is open to exaust at mid point of travel. This is the INNER edge of the valve bobbin. So on your drawing the gap between the inner edges of the bobbin is 1.855 -2 x 0.302 = 1.251" To give 20' exaust clearance the distance between the INNER faces of the tranfer ports in the valve cylinder would be 2 x 0.020 less than this or 1.211" apart. I think I have understood it correctly. There are many who will be more expert at valve gear than I am I'm sure so maybe someone would like to confirm. regards Martin |
J Hancock | 09/06/2021 11:39:50 |
869 forum posts | Is he not referring to the clearance of the spool on the valve shaft ? |
Martin Kyte | 09/06/2021 11:40:50 |
![]() 3445 forum posts 62 photos | Actually that would be for outside steam admission. regards Martin |
Fowlers Fury | 09/06/2021 15:41:48 |
![]() 446 forum posts 88 photos | Very grateful to Jason B and Martin K.
JasonB | 09/06/2021 16:34:27 |
![]() 25215 forum posts 3105 photos 1 articles | Well the way I goy my 1 7/8" was to add the length of the bobbin 1.855" and the 0.020" Exhaust Clearance. Not read any of the above mentioned people but assume it ensures the exhaust is open before the inlet on the opposite end of the cylinder |
Martin Kyte | 09/06/2021 19:11:45 |
![]() 3445 forum posts 62 photos | Jason is correct for inside steam admission. I had the thing 'inside out' regards Martin |
duncan webster | 09/06/2021 20:06:17 |
5307 forum posts 83 photos | Excuse me for throwing in more confusion, but I think exhaust clearance is the amount the exhaust is open when the valve is central. So does Mr Wikipedia ex clear . The drawings give 0.01" each end, so exhaust clearance is 0.01", not 0.02" I wouldn't have thought exhaust clearance was needed on a 5"g model, all it achieves is letting the exhaust out sooner, ie reducing the cylinder power output. Piston speed is very low in models, so unless the ports are badly designed there shouldn't be a problem with pressure drops. I know of some 15"g locos which have exhaust lap, this might be going a bit far!. If cut off is 25% for example exhaust will open at 75% stroke, opening sooner doesn't seem like a good idea Lots of big engines had screwed in plugs through which you could see the valves opening and closing. You can see them on NG15 |
Martin Kyte | 09/06/2021 20:20:29 |
![]() 3445 forum posts 62 photos | At last a valve gear expert. Thanks Duncan. regards Martin |
Paul Kemp | 10/06/2021 00:20:12 |
798 forum posts 27 photos | Duncan, not quite sure I follow on exhaust clearance reducing cylinder power? I guess that might happen if you have zero lap on the admission side but the clearance on the exhaust also relates to the port spacing? Admission "clearance" could be considered to be introduced by the effect of introducing lead (inlet opens before dead centre)? Exhaust clearance only introduces a small difference in actual valve events and at the point the exhaust opens the majority of the expansive effort on the inlet steam would mainly be spent? At high speeds it is just as important to get the expanded or "dead" steam out as getting fresh steam in? Clearance surely also give the effect of keeping the exhaust open longer reducing the resistance on the other side of the piston? Is your 25% / 75% relationship true if you consider at 25% cut off valve travel is consequently reduced so would closing the inlet early necessarily result in the same proportion of opening exhaust early? In full gear (say 80% cut off) would exhaust open at 20% stroke? If you look at an indicator diagram that situation gives zero expansive effort at full gear or 25% cut off? Been a long day so I am probably missing something! Paul. |
duncan webster | 10/06/2021 12:59:43 |
5307 forum posts 83 photos | An expert eh! Perhaps ex as in has been and spurt as in drip under pressure. As Paul says, it is important to get the exhaust out, but pressure drop in ports is proportional to steam velocity squared, and if ports are something like to scale, since model piston speeds are much lower than full size, pressure drop will be very much lower . I'm trying to avoid using algebra. This is borne out by Prof Hall's indicator tests using a Speedy cylinder. Unfortunately the link to that paper seems to be broken. Modern full size simple expansion locos didn't have exhaust clearance as far as I can ascertain, someone will now prove me wrong, so models don't need it. However, I hadn't appreciated that FF is building a compound, so I need to do some more thinking. Having made the bobbins I certainly wouldn't bin them. Back pressure on the HP piston is of course much higher on a compound. On the topic of expansion: if we have a cylinder with a clearance volume of 10% of the swept volume (which is typical full size) working at 25% cut off, it will exhaust at ~75% (not quite due to the effect of lead), so the expansion ratio is (75+10) : 25+10), ie 2.4 : 1. If the steam chest pressure is 80 psig (95 psia) the pressure at exhaust will be 95/2.4 - 15 = 24 psig. I could work out what percentage loss of indicator diagram this represents, but it would get a bit heavy for this forum. If there is general interest I will prepare a monograph (posh name for an article on a single topic!), but ME seems uninterested in techy stuff nowadays, and it would be a fair amount of work. Keep the grey matter churning tho'. I've driven little locos which will just about limp along with only 25 psi boiler pressure (I'm not very good at this keeping the fire going bit), so chucking it away doesn't feel right, but we do need some backpressure to drive the blastpipe, so it's all a balancing act, as is all engineering. Big mill engines always had separate valve gears for exhaust and admission. So did Caprotti valve locos. It can be done with piston/slide valves, indeed it was tried, but must not have been worth the extra complexity edited to remove ****** Smileys Edited By duncan webster on 10/06/2021 13:02:01 |
duncan webster | 10/06/2021 13:19:43 |
5307 forum posts 83 photos | I should have mentioned that amongst Bill Hall's work was a method of calculating pressure drops in ports which allowed for piston speed and varying port openings to produce a theoretical indicator diagram. It agreed remarkably well with actual test results from a full size Britannia tested at Rugby. I spent one Christmas repeating the model, not sure I could do it again, but it agreed with Bill's. Unfortunately he then wrapped it up with his complete loco model. I might be able to find Bill's source code but it would be a fair job to disentangle it, not least because reading someone else's code is never easy. |
