Shaper
Elliott 14m
Sean Stimpson06/06/2021 19:27:23
31 forum posts
14 photos
Hi there does anyone know the weight of a elliott 14m shaper. I have purchased it but don't have a manual was thinking a 2 ton engine hoist and lift into a big van or onto a trailer
Many thanks for people's input
Dave Halford06/06/2021 19:35:51
2536 forum posts
24 photos
Around a ton and a half Sean.
Buffer06/06/2021 19:37:07
430 forum posts
171 photos
Sean I dont have one but having lifted machines onto trailers I am not sure an engine hoist would get it high enough. Last time I lifted a surface grinder onto a trailer I needed a jcb to get the height. So just check how high you can go.
Joseph Noci 106/06/2021 20:07:28
1323 forum posts
1431 photos
I re-furbished an Alba 14M - same as yours - Arrived at home with it on the back of a Landcruiser LDV - thought I would take it down with my engine hoist...Way to high - the hoist is very unhappy lifting the shaper while on the ground with the hoist arm extended to max, and max would not reach the shaper top while on the LDV...rented a small forklift and driver.
Joe
Martin Cargill06/06/2021 20:10:49
203 forum posts
Found one figure of 800kg. You may need to strip bits off to get the weight down so that you can use an engine crane at its max extension (so that you can get the max lifting height). Lathes.co.uk can probably provide a manual that should give you weights, dimensions and the lifting points.
Martin
Sean Stimpson06/06/2021 20:33:02
31 forum posts
14 photos
Brilliant many thanks guys il take a load of tools.with me shouldn't take to long to strip down the hoist is 2 ton so lifts fairly high the bloke may be able to borrow a forklift il pester him to get one thanks
