modeng2000 | 15/05/2021 15:44:57 |
340 forum posts 1 photos | Is there a type of sheet brass that has a spring charactersitic? I have an application, or I should say I might have, for a flat brass sheet spring about 25mm x 75mm by about 1mm thick. I need to be able to put a slight bend of a few degrees on a long edge and to use this edge to apply pressure. I could use clock spring material but brass would be much better. Any suggestions please? John |
Michael Gilligan | 15/05/2021 16:05:35 |
![]() 23121 forum posts 1360 photos | Brass can be hammer-hardened ... but have you considered using phosphor bronze ? MichaelG. . ferinstance: https://www.rapidonline.com/phosphor-bronze-sheets-520937 Edited By Michael Gilligan on 15/05/2021 16:06:07 |
Tim Stevens | 15/05/2021 16:05:40 |
![]() 1779 forum posts 1 photos | Brass shim (at least the english version) is fairly springy, and it comes in a roll or strips about 100mm wide. The name of the product is hard-rolled brass if you are searching in places where 'shim' is not understood. 1mm thick is fairly thick for shim, too, as it normally ranges in steps from 0.002 inches up to 0.015" or a bit more. Try for 0.04 inches as that is a knats over 1mm. If you know of a jeweller or anyone who might have a precision roller, you could ask them to roll your strip to the thickness you need. Regards, Tim |
Bob Stevenson | 15/05/2021 16:06:19 |
579 forum posts 7 photos | Brass is a poor material for springs but clockmakers do work harden brass to give a degree of spring tension. The way that I usually do this is to put a ball peen hammer in the vice with the ball pein up and work the brass by light taps with a second hammer using the raised ball pein as an anvil. Overworking the brass will cause it to work harden too much and crack. The brass is, not surprisingly, thinned out some due to the hammering so you need to factor this into your calculations.
stainless steel may well be more suitable........ |
JasonB | 15/05/2021 16:10:00 |
![]() 25215 forum posts 3105 photos 1 articles | Bronze may be a better option an does not look too different. |
John Haine | 15/05/2021 16:23:27 |
5563 forum posts 322 photos | Molybdenum copper |
Clive Brown 1 | 15/05/2021 16:53:31 |
1050 forum posts 56 photos | Beryllium copper is used for non-ferrous springs. |
Michael Gilligan | 15/05/2021 17:28:21 |
![]() 23121 forum posts 1360 photos | Posted by Clive Brown 1 on 15/05/2021 16:53:31:
Beryllium copper is used for non-ferrous springs. . Not arguing, Clive [you are obviously correct] ... but I'm interested to know if there is any useful advantage [except for its high electrical conductivity] over phosphor bronze. MichaelG. |
Dave Halford | 15/05/2021 17:35:13 |
2536 forum posts 24 photos | Relay contacts springs used to be Beryllium copper, I was taught as an apprentice at GPO phones to reshape them by stroking them with smooth jawed pliers. |
John Haine | 15/05/2021 17:41:07 |
5563 forum posts 322 photos | Oops. Meant beryllium, not molybdenum. |
Brian Wood | 15/05/2021 17:41:10 |
2742 forum posts 39 photos | Be careful when machining beryllium copper, Beryllium is poisonous when ingested. Brian |
Michael Gilligan | 15/05/2021 17:43:35 |
![]() 23121 forum posts 1360 photos | Posted by Dave Halford on 15/05/2021 17:35:13:
Relay contacts springs used to be Beryllium copper, I was taught as an apprentice at GPO phones to reshape them by stroking them with smooth jawed pliers. . Don't think I would be trying that with: 25mm x 75mm by about 1mm thick
Dave Halford | 15/05/2021 18:00:15 |
2536 forum posts 24 photos | Posted by Michael Gilligan on 15/05/2021 17:43:35:
Indeed, he needs a hell of a spring. You can with 10thou thick and 3/16 wide springs |
Roderick Jenkins | 15/05/2021 18:58:54 |
![]() 2376 forum posts 800 photos | Posted by Michael Gilligan on 15/05/2021 17:28:21:
Beryllium copper is used for non-ferrous springs. . Not arguing, Clive [you are obviously correct] ... but I'm interested to know if there is any useful advantage [except for its high electrical conductivity] over phosphor bronze. MichaelG. Perhaps the greatest advantage of BeCu is that it can be formed in the annealed state and then heat treated at about 320C to develop the spring properties. Regarding the hazards of BeCu, this is from a hazard data sheet:
Rod |
Michael Gilligan | 15/05/2021 19:18:14 |
![]() 23121 forum posts 1360 photos | Posted by Roderick Jenkins on 15/05/2021 18:58:54:
Beryllium copper is used for non-ferrous springs. . Not arguing, Clive [you are obviously correct] ... but I'm interested to know if there is any useful advantage [except for its high electrical conductivity] over phosphor bronze. MichaelG. Perhaps the greatest advantage of BeCu is that it can be formed in the annealed state and then heat treated at about 320C to develop the spring properties. […] . Thanks, Rod ... I didn’t know that ^^^ MichaelG. |
modeng2000 | 15/05/2021 19:23:18 |
340 forum posts 1 photos | Well thank you all for the suggestions and ideas. i wanted to use brass because of the colour match and it seems I can probably achieve enough 'spring' by careful work hardening. Hard rolled brass might well fit the requirement if I can find a suitable thickness. This is all a bit experimental and there might be a trade-off between hardness and thickness, Is there possibly a grain orientation requirement when considering a bend? John |
modeng2000 | 16/05/2021 15:32:33 |
340 forum posts 1 photos | Posted by Bob Stevenson on 15/05/2021 16:06:19:
Brass is a poor material for springs but clockmakers do work harden brass to give a degree of spring tension. The way that I usually do this is to put a ball peen hammer in the vice with the ball pein up and work the brass by light taps with a second hammer using the raised ball pein as an anvil. Overworking the brass will cause it to work harden too much and crack. The brass is, not surprisingly, thinned out some due to the hammering so you need to factor this into your calculations. Thanks for this idea Bob, needless to say it worked John |
