Michael Gilligan | 08/05/2021 14:12:38 |
![]() 23121 forum posts 1360 photos | I decided it was time for some soldering practice ... so I dug-out a little digital clock kit that I bought a couple of years ago. My soldering is not as good as it used to be, but; looking at it under the stereo microscope I’m reasonably satisfied that the joints are O.K. Problem is ... it doesn’t work, and I have no idea how to fault-find the circuit: Constructionally, it’s very simple, but there is no description of how it works. The big IC is actually an Atmel AT89C2051 microcontroller, although the board is labelled for STC12C2052 There is no information, but I had assumed it to be supplied pre-programmed. The same kit appears to be listed on Amazon and Alibaba, both of which show this [inaccurate because J2 is not on the board] diagram: . Here are scans of the circuit board [with the track-side horizontally flipped for convenience] . . Does anyone recognise it ? ... or have any idea where I should start fault-finding ... or any useful suggestions as to what I might do with salvageable parts ? MichaelG. |
Frances IoM | 08/05/2021 15:17:36 |
1395 forum posts 30 photos | I guess you didn't use a socket for the microprocessor thus depriving you of many simple tests on the wiring and the display. If you did then you can obvious check all the connections and by judicious use of jumpers test out the display |
Joseph Noci 1 | 08/05/2021 15:57:15 |
1323 forum posts 1431 photos | Michael, Bit of a poor design inthe way it drives the led display, Michael. The processor sets up a 7 seg display code on the the lines A to G and then pulls one of the scan lines DS1 thru DS4 low. So, to show the figure 8 on display 1 ( left digits), lines A-G will be set HI . Line DS1 is then pulled low and all the segment LEDs will glow.. If DS2 is also pulled low, Display digit two will glow, etc. What makes the design poor is that when powered from 5V, the 7seg leds will have about 4 to 4.5V across them, with a large current flow, all sourced by the processor output pins - not good for the processor at all! I see when running from battery the supply V=3V, much better! If the processor is not working , it will not be scanning the A-G lines at all. I presume you do not have an oscilloscope? If you do, check the A-G and DS1-DS4 lines - there should be pulse trains on them. If no 'scope, just short one of the DS lines to ground - if the processor is scanning the A-G lines, a 7seg display will remain on during the short - this 'should' not damage the processor, as the DSx outputs are normally pulsed low and then go hi-impedance to not activate that display - They may however drive the output HI rather than hi impedance, so.. A neater way is to take a red led ( lower on voltage) and connect the cathode to ground, and the anode to each A-G line in turn - you should see it glow if the lines are being driven. If not, there are two probable causes - The processor is not programmed, or the oscillator is not..To see if it is oscillating, first check carefully around the crystal, the two capacitors C2 and C3 ( are they really 30pf - can you see any markings?) If visual is good, do you have a short wave radio? Set the dial to around 12MHz, and bring a wire from its antenna socket and touch the crystal metal can - tune around the 12MHz range till you detect the frequency - it should be very strong... Let me know |
Mike Poole | 08/05/2021 16:46:48 |
![]() 3676 forum posts 82 photos | It’s funny that I have exactly the same kit and mine doesn’t work either, I have another one to assemble so I wonder if that will be 3 out of 3 that don’t work? I will post when I have built it. Mike
SillyOldDuffer | 08/05/2021 16:52:23 |
10668 forum posts 2415 photos | The 2051 and 2052 appear to be pin compatible and both support the same instructions. The 2052 looks to be a bit faster and have a couple of extra timers, but those features are unlikely to be needed on a simple digital clock. The circuit is very simple; most of the clock is implemented by a program running on the chip. The chip should be pre-programmed : unlikely it went wrong, but possible. Reading the reviews I see a few people complain about board quality - tracks lifting off with heat, and broken tracks that had to be bridged. Check the tracks carefully with the microscope and for continuity with a multimeter, or - much better an oscilloscope, see below. Apart from Frances' advice# about maybe testing the display by jumpering, I think debugging needs an oscilloscope. If you've got one, should be possible to see:
Dave # Joe posted while I was typing. Edited By SillyOldDuffer on 08/05/2021 16:54:41 |
Michael Gilligan | 08/05/2021 17:50:01 |
![]() 23121 forum posts 1360 photos | Posted by Frances IoM on 08/05/2021 15:17:36:
I guess you didn't use a socket for the microprocessor thus depriving you of many simple tests on the wiring and the display. If you did then you can obvious check all the connections and by judicious use of jumpers test out the display . Why would you guess that, Frances ? The kit came with a socket, and yes, I used it. MichaelG. |
Frances IoM | 08/05/2021 18:00:40 |
1395 forum posts 30 photos | It was an assumption as you didn't comment on it - thus I now assume that as you have checked out that all connections are correct and the display works then what remains is the micro processor (or possibly the Xtal oscillator) - without a scope this is difficult - however if you have an audio jack then there are pseudo-scope programs (eg Audacity) that can display the signal on this jack - they should be fast enough to at least check the display multiplexing. Edited By Frances IoM on 08/05/2021 18:01:33 |
Michael Gilligan | 08/05/2021 18:09:54 |
![]() 23121 forum posts 1360 photos | Posted by Joseph Noci 1 on 08/05/2021 15:57:15:
Michael, Bit of a poor design inthe way it drives the led display, Michael. […] Let me know . Yes, I do have an oscilloscope, Joe ... ‘though it’s currently in storage No, I don’t have a short wave radio Yes, the capacitors are marked 30 Thanks for the comment about voltage ... I tried it with 5V from a USB ‘power bank’ but can happily use the 3V input. Absolutely nothing lit-up, but there was a very brief squeak from the sounder. I will find a way to check the oscillator and the display ... but the microprocessor and its programming [or lack-of] are a complete mystery. MichaelG.
Michael Gilligan | 08/05/2021 18:13:04 |
![]() 23121 forum posts 1360 photos | Posted by Mike Poole on 08/05/2021 16:46:48:
. Thanks, Mike ... I have another one too; but thought I would seek advice, in case the components are more useful than the kit. MichaelG. |
Michael Gilligan | 08/05/2021 18:20:49 |
![]() 23121 forum posts 1360 photos | Posted by Frances IoM on 08/05/2021 18:00:40:
. I have checked the connections to the best of my ability ... but no, the display has never been seen to work. ... I will report back when/if I discover anything. MichaelG. |
Michael Gilligan | 08/05/2021 18:29:37 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 08/05/2021 16:52:23:
The 2051 and 2052 appear to be pin compatible and both support the same instructions. […] Dave # Joe posted while I was typing.
. Thanks to you also, Dave ... I think, I’ve thanked everyone now As per my other replies : I will report back if I get a glimmer of life out of it [aside from that brief bat-squeak] MichaelG. |
Nigel Taylor 2 | 08/05/2021 18:34:29 |
27 forum posts 10 photos | I have built two of these kits. Neither worked... |
Frances IoM | 08/05/2021 18:34:59 |
1395 forum posts 30 photos | with the uP removed jumpering a 1k resistor from vc1 to one of the display pins and jumpering one of the multiplex pins to 0V should light up something on the display which, maybe wrongly, I assume is soldered in position and oriented correctly ? I this fails then remove the display, insert the up and if you can run a program like audacity (or even better one of the programs on a Raspberry Pi - surely everybody has one of these by now) you should be able to check out the uP Edited By Frances IoM on 08/05/2021 18:35:39 |
Michael Gilligan | 08/05/2021 19:09:00 |
![]() 23121 forum posts 1360 photos | Posted by Frances IoM on 08/05/2021 18:34:59:
. Thanks, Frances ... Yes, the display is soldered in; although I didn’t fit it flush to the board, but raised so the face is just above the height of the sounder. It is orientated as per the graphic on the board. Sorry, but ... As I don’t actually know what program is supposed to be on the microprocessor, I’m struggling to understand how I could check it. MichaelG. |
Frances IoM | 08/05/2021 19:16:28 |
1395 forum posts 30 photos | I'm assuming that one possible error is the loading of the display on the uP - the uP should go through its program without the display and the multiplexing pins should be low enough frequency for Audacity to display it. I assume that the uP is a one-time programmable chip (maybe SOD in possession of a data sheet could confirm) - many of these have a mechanism to prevent readout of the program |
Michael Gilligan | 08/05/2021 19:32:49 |
![]() 23121 forum posts 1360 photos | Atmel datasheet [19 pages]: **LINK** https://ww1.microchip.com/downloads/en/DeviceDoc/doc0368.pdf The STC one is also available, but runs to 360 pages ... the vast majority of which are beyond me. MichaelG. . Edit: being (a) from Amazon UK, and (b) currently unavailable ... I trust that it’s permissible to post this link to what appears to be an identical kit: https://www.amazon.co.uk/Universal-Solder-CANADUINO-Digital-Clock-Countdown/dp/B0764WFNC7
Edited By Michael Gilligan on 08/05/2021 19:48:53 |
Michael Gilligan | 08/05/2021 22:29:52 |
![]() 23121 forum posts 1360 photos | O.K. ... This might turn out to be embarrassing I’ve just realised that I paid no attention to which way round I was inserting R2 This is a resistor array [8 resistors and 9 pins] and the one for the one in the other kit is clearly marked
That dot, I now realise, should be at the left side of the board. There is a 50:50 chance that it’s reversed. R2 is now hiding in the narrow slot between the U1 socket and the DS1 display ... so I will need to check with a meter. ... A little job for tomorrow morning ! MichaelG. . Edit: nicely illustrated here: http://darcy.rsgc.on.ca/ACES/TEL3M/ResistorNetwork.html Edited By Michael Gilligan on 08/05/2021 22:37:39 |
Joseph Noci 1 | 09/05/2021 07:29:03 |
1323 forum posts 1431 photos | Posted by Michael Gilligan on 08/05/2021 22:29:52:
That dot, I now realise, should be at the left side of the board. There is a 50:50 chance that it’s reversed. That will make a difference, but reversing the array only makes the segments glow at half brightness, and the decimal point will be messed - so it should still have shown something...You did check pin 1 of the processor..(Sorry Michael… I do think you should try find a way to see if the oscillator is running at all..Borrow the neighbour's SW radio for 10 minutes. Joe |
SillyOldDuffer | 09/05/2021 10:10:30 |
10668 forum posts 2415 photos | Posted by Frances IoM on 08/05/2021 19:16:28:
... I assume that the uP is a one-time programmable chip (maybe SOD in possession of a data sheet could confirm) - many of these have a mechanism to prevent readout of the program I don't think the microprocessor is one-time only, so it should be possible to read it back unless the 'Program Memory Lock Bits' have been set by the vendor: one prevents write, another prevents read as well. (The chup can still be reprogrammed but only by erasing the flash memory first.) Then the program would have to disassembled and studied to confirm it made sense! Deep waters and and more work than I would care to do - apart from the other complications I'm not familiar with the 8051 instruction set and would have to learn it from scratch! The chip can be programmed with an Arduino as described in this instructable, with either the ArduinioISP built-in example, write only, or using the avrdude utility. avrdude can read and write so in principle the binary program could be extracted with a command something like:
I don't think it's worth the effort! And definitely not until all possibility of hardware error has been eliminated. Michael asked about reusing the components. Programming an Arduino Nano to replace the 2051 chip wouldn't be difficult. A big advantage of the Arduino platform is it hides almost all the complicated shenanigans needed to compile, install and test simple programs. Old-school programming of chips of the 2051 generation may require comprehensive understanding of hoards of tricky details, dunno. Though I'm certain there's a C compiler, I'd have to find it and get it working - unknown territory. However, even if the 2051 is easy to work with, I'd stick with the Arduino simply because there's masses of up-to-date help and I already understand it adequately. Dave
Stuart Smith 5 | 09/05/2021 10:53:30 |
349 forum posts 61 photos | Michael After checking that all the components are installed the correct way round. I would suggest removing the uP chip and power up the board from a 5volt supply. Check that the supply voltages around the board are correct. It will be possible then to test the buzzer and display by using jumpers to simulate what the uP should do. The other thing that occurs to me if all this is OK is do you need to start the clock by pressing the 2 buttons in a particular order?
Stuart
