Sieg KX3 Y_Axis Skipped Stepper Steps😢
Nicola Casali05/05/2021 16:59:14
33 forum posts
6 photos
Continuing the saga with behavioural anomalies..
I replaced my LED lamp with a "quieter" EMI producing LED lamp. That helped. My UC300eth is powered by 5V from a USB cable. I moved that to a USB battery pack to reduce ground loops. Just learning about those! That helped massively with spindle erraticness. EMI is still present but its effects on the spindle are very minor.
So over the last few months I've been experiencing unexplained inaccuracies in machining I've put down to bad workholding and user error. Tolerances haven't needed to be critical, up until now. I started machining some small parts out of mild steel using two passes.
It's on the second passes that the penny suddenly dropped. The endmill is not touching the -Y side but cuts heavily into the opposite side, +Y. It can't now be workholding, maybe the steel is being stress relieved during milling?
Using a dial indicator before and after air cutting a job instead of the stock, it seems the Y axis is out by a massive 0.20 - 0.30mm. X is fine. I've loosened the Y gibb, just in case I overtightened it a few month back. That helps not.
I think my motor tuning settings are default, as set up by John Stevenson. Could this also be an EMI problem?
Is there anything else I could be looking at that could be the cause?
Martin Connelly05/05/2021 18:22:08
2549 forum posts
235 photos
It seems like lost steps in one direction. This can be caused by tapered gib strips that can move about when the axis is moved, loosening in one direction and tightening in the other. If this is the case (the tapered gib moving that is) the solution is to prevent this unwanted movement with one of a number of options. One is to make sure that any adjusting screw is not moving when the machine is in use. The next is that if the screw is working in a slot make sure the slot is a snug fit around the screw and third if there is only one screw at one end add a second screw at the other end to pin the gib strip where it is set.
If you don't have a tapered gib then it may just be that the motor has too low a torque for the machine, adding large vices to a small machine can increase the loads on the motors. A number of solutions for this include fitting a larger motor, adding a planetary gearbox in line with the motor, using timing belts and pulleys to reduce the speed of the drive to the leadscrew but increasing the torque, You could also add motors with feedback encoders but they require suitable motor drivers so that may be the most expensive option.
Martin C
Nicola Casali05/05/2021 21:32:08
33 forum posts
6 photos
I disconnected the lead screw nut for the Y axis and moved the table by hand. There doesn't seem to be any binding in any direction. I'm not sure how tight the tapered gib should be, but it's not loose.
It's not a machine I built. I purchased the KX3 new in 2011. I don't _think_ I've had this problem before. It could be a problem with the UC300Eth motion controller I installed in 2017.
I may have to limp along for now with accuracy in only 2 dimensions. The parts I need to machine only require that.
What I could try immediately is:
1. switch to an unused parallel interface on the UC300Eth.
then
2. swap the x and y pins on the breakout board.
3. swap the x and y stepper drivers to see if it's a driver issue.
4. swap around the stepper motors?
5. switch back to using an old Windows XP PC with parallel port to rule out UC300Eth. (I was about to dump that old PC)
6. ?
Joseph Noci 105/05/2021 22:41:30
1323 forum posts
1431 photos
Nicola,
Are you using MACH3 or UCCNC software with the UC300ETH?
Are the X and Y steppers the same type, ditto the stepper driver modules?
Are the two driver modules set up the same way, dip switches, if any, etc.
Some drivers can be set to go Half Current in the steppers during short pauses in moves, which when driven in microstepping mode can lose micro-step position within the native motor magnetic detent step - if that accumulates it can result in an accumulating step error. If your drivers have such capability, disable it.
I would also suggest checking the stepper pulse train definition setup in the software - MACH3 and UCCNS both have a section where you set up the dwell period between stepper direction control change and the beginning of the next step pulse train - if that is to short for your stepper driver, it can result in lost steps. Likewise, the minimum width of the stepper pulse train can be set up as well - I would make them not less than 5us, even go for 10us, for your kind of setup. At least make sure the Y axis setup is the same as the X Axis.
From your description is seems the Y axis is loosing steps in the -Y direction, biasing the cut to the +Y side. Does the part you are cutting have any rapid Y moves that are more in the -Y direction than +Y? If so , could be that the Y max acceleration ( or velocity) setting for the Y axis are to enthusiastic. X has to move only the X axis, vice and workpiece - Y axis moves include the whole X axis, vise and workpiece, and the Y axis mechanics.
Joe
Nicola Casali05/05/2021 23:22:24
33 forum posts
6 photos
Swapping parallel ports on the UC300Eth did not help.
I never did set up UCCNC in the end, despite having a license. I'm still using Mach3.
I don't know which drivers are being used or dip switches. The machine is set up against a wall and access is from the back. I did manage to fit wheels to the base, so I am able to move it and check those things out. It's quite a hefty machine though.
I've now gone for your suggested 10us pulses and started a job without stock. I've reduced the acceleration for Y from 300 to 200 in Mach3. With 5us pulses that didn't make any difference. Let's see with the 10us pulses.
Actually, the table is gradually moving away from me, meaning it's having problems 'moving' the spindle in the + direction.
The only rapids are once at the start and then rapids only for z throughout.
Currently, I only have a small 70mm vise bolted to the work table.
Nicola Casali05/05/2021 23:37:14
33 forum posts
6 photos
Job finished. Y is off by -0.25mm. This was with 10us pulses and 200 acceleration. Tomorrow I'll take a look at the stepper drivers and compare any settings. If they are identical I'm going to swap the X and Y and retest.
Keith Petley06/05/2021 00:07:17
18 forum posts
Nicola, before swapping the X and Y over check for backlash in the Y.
Move in one direction (eg +Y), zero an indicator on it, move the same direction again and then come back. Try it a couple of times and then a couple in the reverse direction. Backlash problems normally give a repeatable set of readings.
If it's worked OK for a long time and then "degraded" I'd look for a mechanical problem first, electrical failures tend to be all or nothing.
I once chased a weird problem which looked a lot like lost steps but turned out to be a ball nut mounting block had come loose.
Keith
Nicola Casali06/05/2021 00:26:07
33 forum posts
6 photos
I checked for backlash. There appears to be about 0.02mm.
I did check the ball nut. I checked it as I unbolted it to see if there was any binding in the tapered gib. I tightened it back up really well. It appears to be a consistent step loss in one direction only. Bizarre! I can reverse the direction of Y travel in Mach3. That's what I'll do next. That'll confuse it..laugh
Nicola Casali06/05/2021 01:42:07
33 forum posts
6 photos
Reversing the Y axis causes it to lose steps in the opposite direction by the same amount. Let me sleep on it..crook
John Haine06/05/2021 06:59:25
5563 forum posts
322 photos
Is backlash compensation enabled, and if so is it set for the right value? If it is enabled, try switching it off.
Joseph Noci 106/05/2021 09:13:22
1323 forum posts
1431 photos
Very strange behaviour if none of those fixes sort it out! I suppose it could be a Stepper driver failure, but I doubt it.
Nicola, I am not sure I understand your axis direction - If the table is moving away from you, its the same as the table remaining still and the head moving toward you - that is Y -Ve direction, not +Ve...
Not really important here as it still has no bearing on the problem..
I doubt backlash comp has anything to do with this - backlash comp is a symmetrical function and would not create such asymmetry.
Nicola, if the G-Code file is not to big would you care to post it here?
JasonB06/05/2021 10:16:27
Nicola you should be able to access the electronics from the side, the back panel is really only to get at the mechanicals
Looks like the Y gib is only a single screw but as the problem is now showing up with direction altered unlikely to be that. Might be worth marking the ball screw to see if that is returning to the same position and possibly also either side of the coupling
Edited By JasonB on 06/05/2021 10:16:41
Ronald Morrison06/05/2021 11:10:00
98 forum posts
4 photos
My Y axis would skip steps. Turned out I was setting the current to the stepper to high and the driver would momentarily overheat and shut down for a few steps. Turned the current down and it didn't have enough power to push the mill through the material. Ahh, power is voltage times amperes. Raised the voltage on the power supply and now it steps just fine. That may not be your problem but is another avenue to explore.
Nicola Casali06/05/2021 11:12:45
33 forum posts
6 photos
JasonB, I have marked the ballscrew and it returns to the correct place when the table hits the dial indicator I've set up. And thanks for the view of the stepper drivers.
This is actually my first attempt at 3D machining with Fusion 360. I'm thinking about rotating the model and stock by 90 degrees to see if X starts getting affected.
Joseph, here's the file.
https://www.filemail.com/d/zgorgrgcozwfvti
Edited By Nicola Casali on 06/05/2021 11:16:04
JasonB06/05/2021 12:27:59
So if the screw is returning to the same position then it does not sound like it is missing steps otherwise it would be at a slightly different angle.
Any chance of also posting the F360 file. There is an option to share which will give you a link.
Nicola Casali06/05/2021 13:02:18
33 forum posts
6 photos
JasonB, when the dial indicator I set up is indicating zero, the ball screw has returned to its mark. However, in Mach3 readout it's off by 0.25mm. To me that means the ball nut is fine, at least.
John Haine06/05/2021 13:32:01
5563 forum posts
322 photos
Have you tried moving the table back and forth along the Y axis using G code via the MDI? If you typed in -
G91 (sets incremental mode)
F100
G1 Y10
G1 Y-10
G1 Y10
G1 Y-10
...while checking the motion with a DTI it should always return to the same point at either end of the travel.
Nicola Casali06/05/2021 14:34:49
33 forum posts
6 photos
Nice simple test. Will try soon. I don't think I tried that one yet. Although I have written a loop in g code that does something similar, but in absolute mode. That loses steps. I have tried moving the table back and forth using a Vista pendant with the wheel with a variable velocity. That loses steps too.
John Haine06/05/2021 15:19:02
5563 forum posts
322 photos
Remember to give it a G90 when you finish or you can get very confused!
Nicola Casali07/05/2021 02:36:30
33 forum posts
6 photos
Posted by John Haine on 06/05/2021 13:32:01:
F100
G1 Y10
G1 Y-10
G1 Y10
G1 Y-10
I put this in a loop in a text file and ran it 200 times at F250. It didn't skip a single step, or didn't accumulate lost steps. I jogged the Y axis back and forth with my pendant a dozen times. No steps lost. I didn't rerun the F360 file. This was 1:30am. I will try again tomorrow during the day, when whatever conditions may be playing a part...return? Mysterious.
