Here is a list of all the postings Keith Petley has made in our forums. Click on a thread name to jump to the thread.
Thread: TWAIN |
19/05/2023 15:34:28 |
Michael, looking at the driver from the link in your first posting I get the following - which explains the CPU type mismatch, but doesn't help solve the problem. Keith
Keiths-MacBook-Pro-289:MacOS keith$ file MoticTWAIN MoticTWAIN: Mach-O universal binary with 2 architectures: [i386:Mach-O bundle i386] [ppc_7400] MoticTWAIN (for architecture i386): Mach-O bundle i386 MoticTWAIN (for architecture ppc7400): Mach-O bundle ppc_7400 Keiths-MacBook-Pro-289:MacOS keith$ |
Thread: Soundproofing my 3D Printer |
30/04/2023 21:05:53 |
Hi Iain, I had a factory3d printer and found that a lot of the noise was transmitted through the base into whatever it was standing on - rubber feet helped. I don't know how old your printer is, but when I went to re-download the support package I discovered that there was a newer version. The relevant point here is that the new version has two rods which brace the top of the aluminium frame (STL models for the new top/bottom brackets are in the download). These dampen vibrations in the frame, which improves print quality but also lowered the noise coming from the frame. A word of warning - I built a simple enclosure for mine as I was trying to print ABS parts for my next printer. It worked well but then I started to get problems maintaining Z height over the bed, bed levelling and other nasty problems. Eventually discovered that the rise in temperature inside the enclosure coupled with the local heat from the Z steppers and extruder motor were enough to cause the mounting brackets for these motors to sag. They didn't melt as such, just sagged a little more each time it was used - the glass transition point for PLA is only 60 degrees. I ended making aluminium brackets for these parts and had no further heat problems. BTW, these best upgrade I did was to double up the wiring from the PSU to the RAMPS board and from the RAMPS to the bed heater - with the supplied wiring I was barely getting 10v on the bed. It made a huge difference to the startup times. Keith |
Thread: Colouring technical illustrations |
03/11/2022 15:11:13 |
Posted by Michael Gilligan on 03/11/2022 14:16:06:
Posted by SillyOldDuffer on 03/11/2022 13:51:54:
[…] F4C430 is still Saffron, but F4C4303F is the shade of Saffron produced by being 50% transparent. In hexadecimal half FF is 3F. . Thanks for that succinct explanation, Dave 3F duly noted, for my continuing attempts to learn something. MichaelG. Dave, Half of FF is 7F (well 7F.8 to be exact) - so I assume that 3F represents 25%. Which brings the question 25% of what? Is it 25% "pigment", implying the remaining 75% is transparent? Would this then be described as 25% or 75% transparent - a problem neatly avoided by using 50% as an example! Keith |
Thread: Strange problem with jack plugs |
31/07/2022 13:02:48 |
I recall having trouble in the past using mono plugs in stereo sockets. The tip of the mono plugs was more generous in length than those on the stereo plugs and the centre contact on the stereo socket landed across the insulator ring and shorted the plug. Try placing an insulated wedge into the centre switch contacts to lift it clear of the plug and use the outer pair of contacts. Keith |
Thread: EMCO Compact 5 |
16/05/2022 11:42:25 |
Stan, This would appear to be the manual, page 52 has the same image of the screen display https://www.clockmaker.it/files_forum/monografie/emco/emco_5/emco_compact_5.pdf Keith Edited By Keith Petley on 16/05/2022 11:43:07 |
Thread: Unusual Go-No Go Tool? |
23/08/2021 13:35:18 |
Michael, Just thinking out loud here.... ...but if Micrographs isn't the maker's name then the device has no maker's info or serial number etc. which suggests that it may have been made 'in-house'. In that case a "graph" could be informal in-house jargon. For example, "100-300 micro grays per hour" is not an outlandish scale. Keith (who knows nothing about radiation measurements, except what Google just turned up) |
Thread: Stepper motors |
23/07/2021 22:35:24 |
Check that the X motor coils are wired correctly. Sounds like one pair may be wired so that they oppose each other rather than work together. Try just one winding out of each pair and see if it improves things - then add the second winding of each pair. Keith |
Thread: Sieg KX3 Y_Axis Skipped Stepper Steps😢 |
06/05/2021 00:07:17 |
Nicola, before swapping the X and Y over check for backlash in the Y. Move in one direction (eg +Y), zero an indicator on it, move the same direction again and then come back. Try it a couple of times and then a couple in the reverse direction. Backlash problems normally give a repeatable set of readings. If it's worked OK for a long time and then "degraded" I'd look for a mechanical problem first, electrical failures tend to be all or nothing. I once chased a weird problem which looked a lot like lost steps but turned out to be a ball nut mounting block had come loose. Keith |
Thread: Virtual Meet Ups |
04/11/2020 11:22:11 |
Hi Neil, Count me in as well Thanks, Keith |
18/10/2020 22:09:24 |
Hi Neil, Please could you add me to the list? Thanks. |
Thread: Sieg KX3 Controller Board Dying? |
13/10/2020 22:55:32 |
Hi Nicola, Before you climb in the back of the machine with a soldering iron a couple of things to consider. First is the long green connector really a plug and socket? On some of them the top part with the wires and screw terminals will unplug from the bottom half which is soldered to the board. The long black line on the connector in the photo looks promising. Secondly do you have any spare opto inputs on the board? If so, can you move the e-stop to one of the spares (need to tell mach3 where you moved it). Keith |
Thread: Coping with voltage spikes |
20/08/2020 22:30:49 |
Hi Michael, Try reading the resistor in the ebay photo from the other end - looks like green,blue,black,black,brown which would be 560 Ohm at 1% tolerance. Keith |
Thread: LaserWeb4 [for Mac] ... Advice please |
11/11/2019 10:43:39 |
Hi Michael, I took a quick look at the errors above and if you still want to have a go at building this then try the following: 1 - I think you are launching the script from the wrong place. The script expects to be run from the directory where it is located. cd Downloads/LaserWeb4-Binaries-4.0.996-134 ./build.osx.sh 2 - The script can't find the yarn command - you probably need to download it from somewhere 3 - The same with npm. Keith |
Thread: Triangular Screws |
07/10/2019 15:34:53 |
Hi Neil, Try looking up Taptite screws - first came across them in the70's Keith |
Thread: proxxon micro torch burner thread size? |
01/05/2019 23:15:15 |
Apart from the colour the Proxxon device appears visually the same as the Rokrow RK2050. Rokrow spares may be easier to find (or maybe not... ) Keith
Thread: What are these tools. |
19/09/2015 19:43:58 |
Filling knife/scraper blades are tapered so that the blade gets thinner as it gets wider. Perhaps they are the scrap from stamping blanks for that sort of blade? For example **LINK** Keith
Thread: Blown X1 Mill speed control |
07/02/2010 22:52:09 |
Hi Oliver,
The Little Machine Shop sells STW20NK50Z (IRFP460) mosfets for this purpose. Maybe you can find them locally.
http://www.littlemachineshop.com/products/product_view.php?ProductID=1221&category=
Keith
