steamdave | 03/05/2021 16:23:34 |
526 forum posts 45 photos | Many folk use magnetic bits such as magnetic DTI holders and the like on their machines. In time there must be a build up of magnetism in the machine which in turn attracts the ferrous swarf. I've studiously avoided the use of magnetic equipment on my machines until recently when I started using a magnetic holder for a DTI. So, how do people de-magnetise their machines, or do they not bother? Dave |
mark costello 1 | 03/05/2021 16:44:17 |
![]() 800 forum posts 16 photos | Never had a problem. |
Tony Pratt 1 | 03/05/2021 17:06:49 |
2319 forum posts 13 photos | Not a problem Tony |
Howard Lewis | 03/05/2021 17:16:25 |
7227 forum posts 21 photos | Not aware of a problem after 17 or more years with lathe and Mill. I use a stick magnet in a copper tube to pick up ferrous swarf to get rid of. Howard |
Jon Lawes | 03/05/2021 17:17:14 |
![]() 1078 forum posts | That sounds very much like a non-problem. |
steamdave | 03/05/2021 17:27:19 |
526 forum posts 45 photos | OK. Thanks for putting my mind at rest. Dave |
Brian Wood | 03/05/2021 17:32:59 |
2742 forum posts 39 photos | Cast iron does not hold residual magnetism in the same way as steel does which may explain why it is not noted as a problem with DTI mounts on such surfaces. Regards Brian |
Joseph Noci 1 | 03/05/2021 17:49:20 |
1323 forum posts 1431 photos | Irritatingly, I have had chuck jaws ( the hard type) become magnetic and then it's a pain clearing the fine swarf from the jaws when inserting the workpiece. Likewise tool steel lathe cutters, and some milling cutters and even the hard steel capscrews in the tool-holder. This only occurs in the hard steel bits on the lathe - I have never had issues with the lathe structure. I am not sure how, for example, the chuck jaws, become magnetic but they do so repeatedly. I demag all the bits with a homebrew demagnetiser, and all is well for a few weeks. There is that high-school science trick where you align a hard steel rod say North/South, hold it so and smack the one end with a hammer a dozen strokes - it becomes magnetic - maybe I should stop smacking the lathe so hard.... Joe |
Samsaranda | 03/05/2021 19:31:35 |
![]() 1688 forum posts 16 photos | Are you sure that your lathe is pointing North/South then? Dave W |
Tom Sheppard | 03/05/2021 20:35:04 |
47 forum posts | Yes, it is hung from a rope so it aligns magnetically. |
old mart | 03/05/2021 20:55:12 |
4655 forum posts 304 photos | I have never noticed any adverse affects, in fact using lots of magnets when machining cast iron helps to control the mess. |
