Strange Plug Gauge Sizes?
Martin King 203/05/2021 15:35:10
1129 forum posts
Hi All,
This weekends car boot haul included a large selection of these plug gauges, all in very good condition but with very strange diameters.
I was expecting to see the normal .125, 250, 500 etc sizes but there are very few of those.
Are these for special applications of some sort?
There are many more smaller sizes as yet un-measured!
Cheers, Martin
JasonB03/05/2021 15:40:10
.531 and .625 are imperial fractional sizes and most others will give metric sizes if you measure with metric tools.
.985 = 25mm
0.905 = 18mm
etc
Edited By JasonB on 03/05/2021 16:04:33
HOWARDT03/05/2021 15:49:44
1081 forum posts
39 photos
Don't rely on gauges being standard sizes, in production environment gauges are made to suit the process. Gauges are made to suit pre finish sizes, say for a drilled hole prior to finishing where the hole is a non rounded size.
Martin King 203/05/2021 15:54:06
1129 forum posts
Hi Jason, Many thanks, I was just assuming all were Imperial!
I made .985" come to 25mm! Typo I guess..
Are these gauges made to be just very, very slightly under their nominal size for some reason?
They seem like very useful things to have around when boring etc,
I think I will keep these and make a numbered case for them.
Cheers, Martin
Brian H03/05/2021 16:01:17
2312 forum posts
112 photos
Martin, gauges are usually made to be a push fit meaning that they will be very slightly undersize because if they were dead size you would need a press to insert them.
jimmy b03/05/2021 16:02:10
857 forum posts
45 photos
As Howard says, these are most likely to suit a process.
You wouldn't believe the amount of "odd" size gauging I've used over the years!
Jim
JasonB03/05/2021 16:04:16
Yes a typo will correct it.
What did you measure with? as 3 decimal places may not be accurate enough as the difference between exact metric and just under is a couple of tenths.
There are hardly any "odd sizes" if you convert them, just a mix of whole mm and 32nd imperial.
Edited By JasonB on 03/05/2021 16:18:05
Peter Greene03/05/2021 16:04:52
865 forum posts
12 photos
Maybe go/no-go gauges (incomplete set)
Martin King 203/05/2021 16:14:45
1129 forum posts
Hi Jason,
Just measured with a clean cheapo digital vernier caliper so not that accurate.
Will try a micrometer tomorrow.
Nice find though for £2! Got a box of broaches as well which seem very clean but some are a bit big for my kit.
The guy was selling some huge angle plates that I could never ever lift, God knows how he thought they would go at a car boot!
Thanks for the help guys, much appreciated.
Martin
Martin King 203/05/2021 16:24:10
1129 forum posts
Thanks for the numbers Jason, a big help! Martin
Howard Lewis03/05/2021 17:22:24
7227 forum posts
21 photos
If you have the kit, it may be worth setting up a clock with slip gauges and rolling each gauge under the clock (Using it as a Comparator )
That should allow you to measure each gauge more accurately. It will also allow you to check that thre is no taper along the length.
old mart03/05/2021 21:02:02
4655 forum posts
304 photos
At work, we had thousands of gauges in the stores, all sizes, and every one of them was returned to the inspection department for re certifying before being returned to the stores.
