Denford Starturn 8 Lathe Docs & Software needed.
Andrew Binning26/03/2021 22:06:09
39 forum posts
9 photos
Having drawn a blank with Denfords I am hoping that some one has a the documentation and software for a Starturn 8 CNC Lathe. 1987 year so is probably DOS based software. I would be grateful for a copy ( I will pay costs ) of the docs and software to get this machine operational. The Stepper drives are Digiplan SD3 and main motor is a Cheetah Anyspeed ASP~5 DC controller. The lathe is fitted with a tool changer.
Hope someone can help me here please?
Emgee26/03/2021 22:27:05
2610 forum posts
312 photos
Couple of links take you to some info and the 2nd one to the Denford Forum.
Emgee
Andrew Binning26/03/2021 22:50:10
39 forum posts
9 photos
Thank you for your links , but as I said , I have gone through the Denford forums which are the only source of documentation/software for the older Denford machines. I had a very prompt reply from the MD who sent me two photos of the processor board in a Starturn 8 but neither of them bore any resemblance to my hardware. So I don't know the names of the hardware or the software to drive it. The Stepper drives are Digiplan SD3s and the head stock drive motor controller is an Cheetah Anyspeed ASP~5 in and the lathe has an ATC fitted. I have mentioned these items in case anyone recognises these combinations of hardware.
Emgee26/03/2021 23:16:26
2610 forum posts
312 photos
Have you been to this page ?
Emgee
Michael Gilligan27/03/2021 07:56:52
23121 forum posts
1360 photos
Posted by Emgee on 26/03/2021 23:16:26:
Emgee
Just for curiosity’s sake, I tried your link ... which [as posted] doesn’t work sad
... somehow, an extra ‘http’ has crept into the address
This should do the trick: **LINK**
http://www.denfordata.com/bb/viewtopic.php?f=46&t=3376
... It looks an excellent find !!
Rod Ashton27/03/2021 08:59:26
344 forum posts
12 photos
Tried for a long time to get my Starturn 5 slant bed to perform with Denford software. Gave up and converted to Mach 3 and laterly to PlanetCNC. Never looked back. Excellent machines.
John Haine27/03/2021 09:58:04
5563 forum posts
322 photos
Denford machines are excellent generally, though it looks like the Starturn is based on a small Emco platform? None the worse for that. I have a Novamill that came (fortunately IMHO) without the controller and software, so I have used Mach 3 with modern drivers but keeping the original steppers. The tool changer is a bit of a wild card but I'd suggest that you don't bother with any of the control electronics and just replace the stepper drivers and get a modern controller such as UCCNC or Mach4 with a motion control card.
Emgee27/03/2021 10:00:25
2610 forum posts
312 photos
Michael, strange the link got corrupted, thanks for re-posting a working link. Same happened again when using the LINK menu, link when posted didn't work.
Starturn 8 software on the forum at  http://www.denfordata.com/bb/viewtopic.php?f=46&t=2087
Emgee
Edited By Emgee on 27/03/2021 10:01:28
Edited By Emgee on 27/03/2021 10:03:23
Andrew Binning27/03/2021 11:39:19
39 forum posts
9 photos
Emgee , your last link , amended by Michael G , http://www.denfordata.com/bb/viewtopic.php?f=46&t=2087 has a photo of boards in a machine that is only 6 months older than mine but they are all different from the boards in my machine. Denford MD , Steve , sent me that link as well but it was no help.
So far all the links that I have seen have not turned up anything that looks like my kit! My plan is to try and find the software that will run the lathe and then sell it , I would love to get stuck in and do a conversion to interface with Mach 3 but I have a loco that needs building and the Starturn is a distraction!
Thanks everyone for suggestions.
Rod Ashton27/03/2021 12:14:13
344 forum posts
12 photos
Would it not serve you well to sell "as is" ?
Andrew Binning27/03/2021 13:14:10
39 forum posts
9 photos
Rod, It may come to that but the lathe belongs to a friend who has entrusted it to me to obtain best value so I am obliged to try and get it in a working state. He used it 20 years ago but can't find the software! I am still exploring other avenues for the software but if all else fails I have already had a PM from someone who is interested in it as is.
Emgee27/03/2021 17:55:16
2610 forum posts
312 photos
Just because the boards have a different appearance they can still use the same software, you won't know until you download and attempt to run the machine.
If you use the link it takes you to a copy of the software to run your machine, if you want an older version I can send that via email if you pm me your email address.
Emgee
Andrew Evans27/03/2021 18:25:33
366 forum posts
8 photos
I think most people upgrade these to work with a modern controller anyway so I can't see you getting any more money if it works with the original software or not. I would sell as is or if you have the inclination upgrade it and then sell.
Andrew Binning27/03/2021 20:31:06
39 forum posts
9 photos
I realise the different boards may run the same software but I was also hoping to get connection schematics which relate to my board. With a view to doing a conversion.
I have sent a PM for the older software. Thanks.
The other query I have just now is regarding the RS232 protocol. Is it a null modem or a DCE-DTE connection. It would be helpful if I could eliminate this as a source of failure before I start trying to work through the software and what files need to be run before which.
Andrew Binning27/03/2021 20:43:28
39 forum posts
9 photos
Whoops! I should have said null modem cable ( Rx to Tx and Tx to Rx or DTE-DCE and hand shaking with the other functions , e.g. RTS to CTS and CTS to RTS) or DTE-DTE in other words straight Tx to Tx and Rx to Rx and so on with the other functions.
I hope I have got this right now
