Milling Attachment for Flexispeed
James Alford14/03/2021 18:40:28
501 forum posts
88 photos
Quite some time ago, I asked for information about making a milling attachment:: I have finally finished making one now for my Flexispeed. The lash-up with the plastic wing nut and the spacers is temporary until I can buy a suitable 6mm cap screw or bolt of the correct length.
I was uncertain how rigid it would be or whether the 70 watt sewing machine motor would be suffiiently powerful to be useful. I am pleasantly surprised as the device can take fairly deep cuts, produce a reasonable finish and the motor does not stall. The finish is lot better than I was getting when I used the vertical slide as a conventionaI slide with the cutter on the lathe spindle. I am confident that with patience, I should be able to do small jobs effectively.
All I need now is a small vice to attach to the cross-side. Does anyone have anything suitable which they would consider selling?
James.
Edited By James Alford on 14/03/2021 18:42:50
Michael Gilligan14/03/2021 19:09:29
23121 forum posts
1360 photos
Splendid job, James yes
noel shelley14/03/2021 19:11:38
2308 forum posts
33 photos
Very Nice well done ! I'm supprised the 70W motor is enough. Noel.
DiogenesII14/03/2021 20:54:55
859 forum posts
268 photos
Looks like a good idea turned into an effective attachment - nice work. .you could make a drilled & tapped plate to bolt to the top of the slide to clamp work to, if you are stuck for a vise?
Trevor Drabble14/03/2021 21:16:46
339 forum posts
7 photos
James , l have a new and unused boxed Myford MA71 vice l got from the original Myford Nottingham company . If you are interested in it l could send you some pics For some unknown reason l can't now post pics into my albums from my tablet . Not sure of value , so will need to trawl net for an idea . Trevor.
James Alford14/03/2021 22:50:14
501 forum posts
88 photos
Thank you for the compliments.
A drilled and tapped plate would be a useful addition. Thank you for the suggestion.
Trevor: may I ask how large the vice is? The cross-slide on the Flexispeed is diddy, being just 2" wide.
James.
Michael Gilligan14/03/2021 23:08:13
23121 forum posts
1360 photos
I have taken the liberty of linking James’ useful photo of the Flexispeed for easy reference: **LINK**
https://www.model-engineer.co.uk/sites/7/images/member_albums/142495/612406.jpg
Hope that’s O.K. with you, James
Edited By Michael Gilligan on 14/03/2021 23:10:25
James Alford14/03/2021 23:19:45
501 forum posts
88 photos
Posted by Michael Gilligan on 14/03/2021 23:08:13:
Not at all. Thank you, Michael.
James.
Michael Gilligan15/03/2021 10:39:59
23121 forum posts
1360 photos
I’ve just had a thought, James enlightened
That long tee-slot on your tiny cross-slide [and/or a tapped auxiliary plate] would be very useful with something like the Mitee-Bite products:
I say ‘something like’ because the real ones might be considered ‘reassuringly expensive’
... Have a look here, for inspiration : **LINK**
https://www.wixroyd.com/en/page/mitee-bite-clamping-products-from-wixroyd
Trevor Drabble15/03/2021 11:59:27
339 forum posts
7 photos
James , The vice is 2 7/8"(74mm) wide x 4 1/4"(111mm) long [excluding handle] x 1 3/8"(35mm) deep and so would need mounting on a sub-table , and so probably not suitable for your needs . Can take and email pics if you decide you still interested . I also have another new and unused and boxed Toolmakers Vice 2 3/4" x 1 3/4" x 4 1/2" . Also , Arc do a tool vice , 130-040-04048 which you may find of interest .
Trevor Drabble15/03/2021 12:07:23
339 forum posts
7 photos
Proops are doing a 1 1/2" drill press vice, H4078 for only £18.10 .
James Alford15/03/2021 17:14:27
501 forum posts
88 photos
Michael: I see what you mean by "reassuringly expensive", but there are some good ideas there. Thank you.
Trevor: thank you for the details of your two vices, but I think that they will be too large, sadly. I shall have a look at the Arceuro and Proops products, though. Thank you for the suggestions.
James.
