Centec 2b y axis
jason evans02/03/2021 17:24:02
69 forum posts
16 photos
Hi guys
sorry got another question. Has anyone got pics of the Y axis lead screw setup on a centec mill.
would like to see my options for changing to ball screw before I start tearing it down.
thanks
jay
duncan webster02/03/2021 17:31:14
5307 forum posts
83 photos
The screw is very close to the underside of the table, I doubt you would get a ball screw nut in. The bronze nut isn't a full nut even. I'm happy to be proved wrong
Dave Halford02/03/2021 19:21:10
2536 forum posts
24 photos
Its in full view under the table on the righthand side and only held on by the big nut.
not done it yet02/03/2021 23:23:21
7517 forum posts
20 photos
My y axis nut is dead central and hidden from view.
duncan webster03/03/2021 00:30:15
5307 forum posts
83 photos
Posted by duncan webster on 02/03/2021 17:31:14:
Doh! I was referring to the x axis nut, never seen the y
Gary Wooding03/03/2021 07:50:15
1074 forum posts
290 photos
I've never taken it out, but here's a photo of my Y-axis leadscrew nut. The clearance round the nut seems promising.
jason evans03/03/2021 12:50:17
69 forum posts
16 photos
cheers. there does seem a bit of room in there. is the brass nut just a push fit in the hole it locates in. cant imagine it is rigid.
Gary Wooding03/03/2021 13:11:00
1074 forum posts
290 photos
Posted by jason evans on 03/03/2021 12:50:17:
I really don't know.
T.B03/03/2021 15:49:14
54 forum posts
21 photos
I ended up making a new screw and nut for the Y axis when I refurbished my Centec 2B.
I was too tight to make the whole nut from bronze so pressed a piece into a steel body.
From memory the original nut was a light press fit in the knee casting
Edited By T.B on 03/03/2021 15:51:10
Edited By T.B on 03/03/2021 15:53:08
Edited By T.B on 03/03/2021 17:17:30
jason evans03/03/2021 17:23:53
69 forum posts
16 photos
Excellent thanks for the pics. Just what I needed 👍🏻
Mark Williams 1406/03/2021 09:49:36
11 forum posts
I have fitted ballscrews to my Centec 2b ,x and y axis. No problem, tight squeeze on the y though.
regards
Mark
duncan webster09/03/2021 23:34:03
5307 forum posts
83 photos
Mark, do you have any photos or other details? Not something I'm planning in in the near future, but if I ever do it copying yours would be a good start.
Mark Williams 1410/03/2021 01:47:04
11 forum posts
Duncan,
I am away from home for possibly another two months, so I can take pics then when I get back. From memory I joined a ballscrew to a stub shaft to replicate the original screw and made an adaptor for the ball nut to screw onto that fitted into the casting like the original nut did, I also added needle bearing thrust washers to the stub shaft. I had to space out the mounting flange casting from the y casting by 10mm to get it all to fit. I have a feeling I lost a small amount of y travel but not much. My ballscrew nut had a threaded end on it not a flange type like most seem to be so I think that made it easier.
regards
Mark
