BOB BLACKSHAW | 14/02/2021 09:40:39 |
501 forum posts 132 photos | Hello, am making a Stuart 10v from bar stock, the crankshaft has been made but the steel rod I have used is .05 under 7mm. Its not a problem when making the bearings as I can make them to size, its when the bearings are fitted to the base and the need to line up so no tight spots. A 7mm reamer will make it a bit sloppy, any ideas how I can do this please. Ive seen adjustable reamers from £8 to £100, would a cheap adjustable reamer do the job, or any ideas. Thanks Bob |
Stuart Bridger | 14/02/2021 09:45:25 |
566 forum posts 31 photos | Maybe you are over thinking this. Just make the bearings a good fit on the shaft leave a bit of play in the bearing seats. Install the crankshaft and just nip up the bearings with a good running fit. |
Former Member | 14/02/2021 09:53:22 |
1085 forum posts | [This posting has been removed] |
Hopper | 14/02/2021 09:59:31 |
![]() 7881 forum posts 397 photos | Or, yes a cheap adjustable reamer would do the job if so desired. The first third of the blades are tapered so you could adjust it to fit through both bearings and ease them out just that bit. But, it is easy to make these little engines a bit close in the clearances and they end up running a bit tight, so the previous posters advice might be better way to go. As Mr Harley said to Mr Davidson: A little extra clearance never got in the way. |
Chris Evans 6 | 14/02/2021 10:05:05 |
![]() 2156 forum posts | I doubt if adjustable reamers go down that small. You will need the 0.05 to make it run easily, the oil/grease will use up some of the clearance. |
John Haine | 14/02/2021 10:07:50 |
5563 forum posts 322 photos | Boring is possible if you have a tiny boring tool but for 7mm that's not so easy. How would one "nip up" the bearings? They are made from a solid extrusion and IIRC there is no split in them or provision for nipping up. I suggest that you just drill the bearings. Get a couple of good drills say 6.9 and 6.8mm. Carefully stone a tiny rounding on the outside corners of the cutting edge to make a "Dagenham reamer" - this reduces the tendency to cut over size. Try on a bit of scrap brass first, with luck you'll find that the 6.9mm one will give you the size you want. Slow feed. Or you could make yourself a D bit by turning turning down say 8mm silver steel to the size of your shaft. |
JasonB | 14/02/2021 10:11:35 |
![]() 25215 forum posts 3105 photos 1 articles | Bod what type of steel rod did you use to make the conrod? If Silver steel like a lot of people choose then you could use the remainder to make your own reamer. |
Former Member | 14/02/2021 10:12:32 |
Howard Lewis | 14/02/2021 11:55:50 |
7227 forum posts 21 photos | 0.05 mm sounds like a reasonable running clearance if the reamer does not cut oversize (To minimise the risk of this, do not hold it rigidly in the machine, but ensure that can "float". If all else fails, steady it with a centre and rotate by hand, rather than rigid and under power, would be my suggestion. Howard |
