Mounting a Mitutoyo dial gauge
pgrbff31/01/2021 11:27:56
261 forum posts
31 photos
I have a dial gauge which I have always used with an articulated magnetic mount, so I bought it for lug mounting.
I now want to measure the runout on my table saw which means I want to lie it down on its back and attach it to a strip that runs in the slot in the table.
Do I need to buy another gauge without the lug mount on the back?
Peter Cook 631/01/2021 11:52:24
462 forum posts
113 photos
Most of the dial gauges I have (albeit not in Mitutoyo's league) came with both a lug back, or a flat one, and can be interchanged. All with four screws.
If you don't have a flat back in the original packaging with yours, I suspect it is fairly simple to make one. Mine are simple flat pieces (of steel or plastic depending on the guage quality) a couple of mm thick with four mounting holes round the periphery.
Take the lug back off (in a CLEAN environment), measure it up and make one.
pgrbff31/01/2021 11:55:48
261 forum posts
31 photos
thanks
Emgee31/01/2021 12:10:50
2610 forum posts
312 photos
Use a clamp bored and reamed to fit the stem.
Emgee
Pete Rimmer31/01/2021 12:31:08
1486 forum posts
105 photos
Put the mag mount on the sliding strip with the gauge down low next to the base. Angle the tip down if you like - it will over-read somewhat but it will yell you where the problem lies.
Another thing you could do is make a plain back and swap it out temporarily, Usually, they are just disc of plain metal.
pgrbff31/01/2021 17:10:16
261 forum posts
31 photos
€2.44 for a back without a lug and I don't have to go far to get it.
old mart31/01/2021 17:30:06
4655 forum posts
304 photos
Take the lugged back off before buying a plain one and have a look. You might be lucky.
pgrbff01/02/2021 06:57:20
261 forum posts
31 photos
Posted by old mart on 31/01/2021 17:30:06:
Tried that, wasn't lucky.
David George 101/02/2021 08:05:02
2110 forum posts
565 photos
I have a simple adaptor which allows you to check slots etc have a look. It is as far as I know from Mercer.
David
Howard Lewis01/02/2021 14:14:16
7227 forum posts
21 photos
Have found a drawing of a Starrett Adaptor to do just that.
Look in my Albums.
