Unimat 3 collet holder
Turbine Guy21/01/2021 15:27:07
541 forum posts
578 photos
I'm trying to find a place to purchase a collet holder (chuck) for a Unimat 3. I have found a few sources for complete sets of collets with a holder. I have not been able to find a source that sells the collet holder only.
I appreciate any help,
Byron
Former Member21/01/2021 15:34:26
1085 forum posts
Emgee21/01/2021 15:35:03
2610 forum posts
312 photos
Byron, chuck for what type and size of collet ?
Emgee
Former Member21/01/2021 15:44:10
1085 forum posts
Turbine Guy21/01/2021 17:01:49
541 forum posts
578 photos
Posted by Emgee on 21/01/2021 15:35:03:
Emgee
I can get collets in size ER-16, ER-20, or ER-25. The largest collet I would probably need is 5/8" (16mm).
Turbine Guy21/01/2021 17:09:39
541 forum posts
578 photos
Posted by br on 21/01/2021 15:44:10:
My unimat collet chuck is Emco ref no 150 290
!4mm thread
Collets are type E16
br
Your set would be perfect for my Unimat 3. I was hoping to get original EMCO items since all my lathe and drill attachment accessories were made my EMCO. I live in the USA and if you are willing to ship them to me please PM me with the price you would like to sell them for.
Look forward to hearing from you,
Byron
Turbine Guy21/01/2021 17:17:34
541 forum posts
578 photos
I just checked my source for collets and found out I would need the ER-25 collets to get up to the maximum size I would like to use. This would be my preferred size.
Former Member21/01/2021 17:29:07
1085 forum posts
Emgee21/01/2021 17:42:19
2610 forum posts
312 photos
Emco did/do an ER25 chuck that screws direct to the spindle on the Emco 5 milling drilling accessory fitted to some 5 cnc lathes and 5 manual lathes.
Original EMCO, item no. 200 050, Fixing M14x1
You don't say if the thread you need is M14x1 or M14x1.5 ?
Emgee
Turbine Guy21/01/2021 17:50:46
541 forum posts
578 photos
Posted by Emgee on 21/01/2021 17:42:19:
Emgee
The Unimat 3 uses M14x1 thread.
Emgee21/01/2021 18:03:07
2610 forum posts
312 photos
Turbine Guy
Original EMCO, item no. 200 050, Fixing M14x1 as in picture, collet recessed into the body so takes up less height from your set-up if milling/drilling, also less overhang from the spindle.
From my own experience using the 5 milling attachment I wouldn't advise using a 16mm milling cutter because the unit is quite low power motor, best results will be obtained using smaller diameters but then the spindle speeds may be a bit low, so feedrate will have to be reduced to prevent stalling.
Used with correct size of cutter and consideration to the points raised excellent work can be accomplished.
Emgee
Turbine Guy21/01/2021 19:23:41
541 forum posts
578 photos
Hi Emgee,
The collet chuck you showed the picture of (EMCO 200 050) would be perfect for my needs. If anyone knows where I could obtain one of these (new or used) I would appreciate it. As br mentioned in a preceding post, the ER-25 collet chuck is available as a complete set with collets on ebay.  I would prefer to get just the chuck if possible.
Thanks for the help,
Byron
Edited By Turbine Guy on 21/01/2021 19:24:57
clivel21/01/2021 19:54:27
344 forum posts
17 photos
I purchased the Emco 200 250 collet chuck for my Unimat from Pro Machine Tools a few years ago and have been very happy with it.
Unfortunately, the Pro Machine Tools website is currently undergoing maintenance so it is not possible to check if they still have stock but it might be worth contacting them to see if they still stock it.
Turbine Guy21/01/2021 20:00:16
541 forum posts
578 photos
After looking at the cost of buying the collets individually, I realize what a bargain the ER-25 collet chuck with the set of collets sold on ebay is. I went ahead and ordered the set mentioned by br.
Thank you all for your help,
Byron
Former Member21/01/2021 20:10:56
1085 forum posts
Jouke van der Veen21/01/2021 20:33:49
203 forum posts
19 photos
Emco C5 spare parts etc. can also be bought at Emco Holz & Hobby in Austria.
Turbine Guy21/01/2021 23:17:48
541 forum posts
578 photos
Posted by Jouke van der Veen on 21/01/2021 20:33:49:
Thanks for the source. They appear to sell the collet holder I thought would be ideal for me as shown in Holz & Hobby This source could be useful for other EMCO parts.
Jouke van der Veen22/01/2021 11:49:58
203 forum posts
19 photos
I have the strong feeling that E H&H also act as a distributor to sellers in Western Europa but I am not sure.
Turbine Guy17/02/2021 13:08:57
541 forum posts
578 photos
I received the collet set that I ordered on Ebay. The runout was very bad so I looked for help to see if anyone else had this problem and what they did to fix it. I found the following thread Collet Runout that gave suggestions for correcting problems with collet holders. After trying some of the suggestions, I came to the conclusion that fixing the collet chuck is beyond my skill and equipment capabilities. After seeing the size of the ER-25 collet set, I agree with Emgee that an ER-16 collet set would be more appropriate for the Unimat 3.
br,
I sent you a PM that I am interested in purchasing the E16 collet set if it is still available.
Thanks for your help,
Byron
Edited By Turbine Guy on 17/02/2021 13:12:41
John Haine17/02/2021 13:20:13
5563 forum posts
322 photos
Did you buy the collet set from a seller apparently in Wales (Mountain Ash)? I bought an ER16 one from him, runout was awful and the small nut would not take smaller collets. I returned it as not fit for purpose and got a refund.
