wanted threaded rod
Mike Brett | 18/01/2021 15:12:06 |
129 forum posts 18 photos | I have some miniature brass door knobs that take a threaded rod which measures 1.85 mm or .073 inches across the threads. I need to order some more of the rod , anyone know who would stock this size . Not sure if this is a BA size or not. Mike |
noel shelley | 18/01/2021 15:34:26 |
2308 forum posts 33 photos | possibly 9 Ba ! Thread gauge would be the answer, 65 Tpi Or 1.8mm X .35 Good luck, Noel |
Howard Lewis | 18/01/2021 15:37:15 |
7227 forum posts 21 photos | Depends on the provenance of the miniature door knobs., UK , possibly Europe, or North America. 9 BA is 1.9 mm OD, 0.39mm pitch, or 65.1 tpi So, 1.85 mm could be a gnat's undersize. (0.025 mm is not much, 0.002" in old money ) 1 - 64 ANC is 0.073 OD 1 - 72 ANF is 0.073 OD, So you need to measure the pitch of the thread . The ANC /ANF threads will be 60 degree thread form The BA thread will be 47.5 degree thread form, so they are not interchangeable! If that is any help Howard |
Brian H | 18/01/2021 15:50:54 |
![]() 2312 forum posts 112 photos | If it turns out that the thread is BA then I could let you have some pieces. I've been cutting down some 9BA x 1" screws to 1/4" long and have saved the cut off pieces. Brian |
Jeff Dayman | 18/01/2021 16:04:51 |
2356 forum posts 47 photos | As Howard said, could be #1-72, if made in USA. |
Mike Brett | 18/01/2021 17:04:37 |
129 forum posts 18 photos | Thanks for replies. I tried my thread gauge, but the thread size is so small its not easy for me to see. It seems to fall between 0.6 and 0.7 in metric. Mike |
Peter Greene | 18/01/2021 17:19:52 |
865 forum posts 12 photos | Just musing but it ought to be possible to determine whether it's a 47.5 or 60 degree thread by eyeball through a reasonably powerful eye-loupe (or whatever). Oh, woe .... the passing of the shadowgraph. |
duncan webster | 18/01/2021 17:26:32 |
5307 forum posts 83 photos | could it be M2? 9ba is unlikely, it has been a 'non preferred' size for many years |
Andrew Tinsley | 18/01/2021 17:30:24 |
1817 forum posts 2 photos | Hi Peter, The shadow graph hasn't passed. I have one in my workshop and for jobs like this, you can't beat it! Andrew. |
Howard Lewis | 18/01/2021 17:35:13 |
7227 forum posts 21 photos | 0.6 mm pitch is 42.33 tpi 0.7 mm pitch is 36.2 tpi Both too coarse to be 1 ANF or 1 ANC, and certainly not 9 BA 48 tpi would be 0.529 mm pitch. 60 tpi would be 0.423mm pitch The thread could be special, or maybe one of the lesser known ones used in watches and clocks? Howard |
Howard Lewis | 18/01/2021 17:55:07 |
7227 forum posts 21 photos | M2 Coarse has a 0.4 mm pitch, and M2 Fine has a 0.25 mm pitch, So both too fine for a pitch between 0.6 and 0.7 Taking the coward's way out would it be feasible to drill and tap out to 8 BA? 2.2 mm OD, 1.68 mm core 0.43 mm pitch Tapping drill 1.85 mm 7 BA 2.5 mm OD, 1.92 mm core 0.48 mm pitch Tapping drill 2.1 mm (Non preferred size ) 6 BA is 2.8 mm OD, 2.16 mm core, 0.53 mm pitch Tapping drill 2.35 mm Howard |
mgnbuk | 18/01/2021 17:57:52 |
1394 forum posts 103 photos | (0.025 mm is not much, 0.002" in old money ) There's inflation for you - 0.025mm used to be 0.001" Nigel B. |
Howard Lewis | 18/01/2021 18:26:04 |
7227 forum posts 21 photos | Absolutely right Nigel. Do you know of a good proof reader? Howard |
Mike Brett | 18/01/2021 18:59:44 |
129 forum posts 18 photos | It did cross my mind to drill and tap, this is what I would normally do. But the parts are so tiny and I do not have a watchmakers lathe. They are only door knobs so not critical. I will just fit in what I can with loctite and leave it at that. Cheers Mike |
