Me. | 15/01/2021 16:59:01 |
147 forum posts 30 photos | I am in need of some help in working out which type of spur gear i need. ive trawled the internet for some basic info on spur gears but it rapidly gets very technical and gets its very frustrating with all the different types there are. My Milling table has a small gear box which uses spur gears to drive the gear box - the ratios are 34/14 = 1/2" per min 29/19 = 3/4" per min 24/24 = 1 1/4" per min 19/29 = 1 7/8" per min 14/34 = 3' per min I only have the 34/14 ratio so i'm looking to get the 29, 24 (x2) and a 19 toothed spur gears. The centre between the spindles is 61mm (2.375" - 2 3/8ths) approx.
Can some one please advise which type of spur gear I will need and what are the crucial dimensions I should be looking for.
JasonB | 15/01/2021 17:09:44 |
![]() 25215 forum posts 3105 photos 1 articles | Can you give a more accurate ctr distance as you are on the border line between 10DP and MOD2.5 60mm (2.362" ) would work out OK with MOD 2.5 2.400" (60.91mm) would work out OK with 10DP
Edited By JasonB on 15/01/2021 17:14:20 |
Andrew Johnston | 15/01/2021 17:17:01 |
![]() 7061 forum posts 719 photos | Accurately measure the OD of the 34 tooth gear and tell us the make and model of milling machine. Andrew |
Tony Pratt 1 | 15/01/2021 17:17:50 |
2319 forum posts 13 photos | I looked at the 'Rushgears.com' calculator & as Jason says 1.375" centre distance doesn't give a meaningful answer. I'm guessing the mill is a 'Herbert'? Tony Edited By Tony Pratt 1 on 15/01/2021 17:18:36 |
Me. | 15/01/2021 17:48:21 |
147 forum posts 30 photos | Yes it is the Herbert Mill - One of the gears does have 10DP stamped on it - Is this the "type" I need to be searching for I have looked at mod 2.5 and they seem to have more ratios. Can anyone suggest a supplier ? |
Pete Rimmer | 15/01/2021 18:15:32 |
1486 forum posts 105 photos | Those are 10DP gears, but you don't have to use 10DP, you could use 20DP (myford) gears and double the tooth count, or any other DP that will achieve the 2.40" centre distance. |
DC31k | 15/01/2021 18:34:56 |
1186 forum posts 11 photos | Just as an illustration, HPC Gears price for 10 DP is £23.42, £28.13 and £32.78 for 19t, 24t and 29t. eBay prices for 20DP Myford gears are £10.50, £18.95 and £26.40 for 38t, 48t and 58t. The 58t seems to be less common. A further option may be to use timing pulleys and a toothed belt if you can find a more economic source of supply than traditional spur gears. |
