Stuart Cox 3 | 05/01/2021 16:28:52 |
130 forum posts 25 photos | So I have been searching the net for a 130mm independent 4 jaw chuck for my Clarke CL500M, plenty of 125mm out there but there doesn't seem to be any 130mm. Just wondered if maybe this isn't a thing?! Yes Clarke do one specifically for the lathe at £200 which seems a lot. Yes I could make an adapter plate to fit a 125mm chuck, but I'd quite like the diameter to match the headstock (call me anal if you like) 🙄 I found a 130mm 4 jaw self centering chuck but no independent jaw version. Just wondered if anyone knew of somewhere to try that maybe I missed? Thanks Stuart |
Michael Gilligan | 05/01/2021 16:49:38 |
![]() 23121 forum posts 1360 photos | The Clarke item includes an adapter plate ... which helps explain the price. There has been another recent thread discussing this. MichaelG. . Ref. https://www.model-engineer.co.uk/forums/postings.asp?th=168889 Edited By Michael Gilligan on 05/01/2021 16:51:25 |
Jeff Dayman | 05/01/2021 16:56:19 |
2356 forum posts 47 photos | Surely 5 mm on the OD of a chuck will not affect its' usefulness to any real degree. If there are lots of 125 mm dia chicks and no apparent 130 mm ones at reasonable price I'd suggest getting the 125 mm one and getting on with life. BTW a 4 jaw independent chuck needs to be firmly attached to the spindle of course, but does not need ultra precise location on centre. a few thou runout of the OD of this type of chuck to centre will not matter - you are centring each job using the independent jaws. |
DiogenesII | 05/01/2021 17:20:26 |
859 forum posts 268 photos | Hmm. ..does anything prevent it swinging a 150 (or 160) mm four jaw? |
JasonB | 05/01/2021 17:26:01 |
![]() 25215 forum posts 3105 photos 1 articles | Bison do a 130mm independent but makes the Clarke one seem a bargain |
Bazyle | 05/01/2021 18:00:28 |
![]() 6956 forum posts 229 photos | Has anyone measured the 130mm one to check it isn't a 5in one 'converted' by someone in marketing who only thinks in round figures. |
Pete Rimmer | 05/01/2021 18:11:51 |
1486 forum posts 105 photos | 5" = 127mm so just 3mm actually. |
Clive Foster | 05/01/2021 18:16:36 |
3630 forum posts 128 photos | Stuart Far more important to worry about jaw size than exact diameter. Historically 4 jaw chucks, especially in the larger sizes, tend to come in heavy duty and light duty types. Heavy duty types tend to have jaw sizes approaching those of next size up three jaw and light duty ones have jaws more like next size down threes. Heavy duty types have significantly bigger and heavier bodies too. Heavy duty ones hold workpieces more securely but the bigger jaws can seriously get in the way on smaller jobs. Although the heavy duty / light duty split isn't so specific with chucks of the size you are considering different makes and models have considerable variation. For our sort of work a light duty chuck with its smaller jaws and less massive body is generally better so, other things being equal, go for the one with the samllest jaws. Some of the inexpensive imports have been terribly cumbersome. Objectively, on a smaller machine like yours, if a job needs heavy duty holding power its better done firmly strapped down to a faceplate. I have both for my Smart & Brown 1024, admittedly a larger lathe than yours. The heavy duty one comes out about once a decade! Clive |
Stuart Cox 3 | 05/01/2021 19:33:27 |
130 forum posts 25 photos | Posted by Clive Foster on 05/01/2021 18:16:36:
Stuart Far more important to worry about jaw size than exact diameter. Historically 4 jaw chucks, especially in the larger sizes, tend to come in heavy duty and light duty types. Heavy duty types tend to have jaw sizes approaching those of next size up three jaw and light duty ones have jaws more like next size down threes. Heavy duty types have significantly bigger and heavier bodies too. Heavy duty ones hold workpieces more securely but the bigger jaws can seriously get in the way on smaller jobs. Although the heavy duty / light duty split isn't so specific with chucks of the size you are considering different makes and models have considerable variation. For our sort of work a light duty chuck with its smaller jaws and less massive body is generally better so, other things being equal, go for the one with the samllest jaws. Some of the inexpensive imports have been terribly cumbersome. Objectively, on a smaller machine like yours, if a job needs heavy duty holding power its better done firmly strapped down to a faceplate. I have both for my Smart & Brown 1024, admittedly a larger lathe than yours. The heavy duty one comes out about once a decade! Clive Thanks Clive, I will bear that in mind. How can you tell the difference when viewing on line? Is there anything in particular that denotes which is which for example? Thanks Stuart |
