Malcolm Farrant | 31/12/2020 11:04:05 |
102 forum posts 3 photos | I am at a loss to understand the two Pipe connections on the Water Pump. One comes from the underside of the casting, and the other from the top. Both then go thru the aluminium base-plate. However I can find nothing that tells me what then happens to them. Obviously they must connect to something, but what ?. No doubt I am being stupid, but PLEASE can someone enlighten me. In anticipation many thanks, and my hopes that 2021 will be a better year for us all. Best wishes Malcolm Farrant (Roskrow) |
Former Member | 31/12/2020 11:09:52 |
1085 forum posts | [This posting has been removed] |
Paul Lousick | 31/12/2020 11:15:39 |
2276 forum posts 801 photos | Which issue of ME is beam engine in ?? Paul |
JasonB | 31/12/2020 11:54:35 |
![]() 25215 forum posts 3105 photos 1 articles | As said if you are running on steam then connect the bottom to water supply and top to boiler clack. If you are on air or separate feed pump to boiler then just treat the engines own pump as decorative. |
Ian Hewson | 31/12/2020 12:31:03 |
354 forum posts 33 photos | Or you could add a baked bean tin and pump water too and fro, as in my engine. Had to do a screenshot as video of engine running was too large. Ian Edited By Ian Hewson on 31/12/2020 12:32:16 |
Former Member | 31/12/2020 12:45:31 |
Paul Lousick | 31/12/2020 12:58:33 |
2276 forum posts 801 photos | Thanks, it looks like a good project to build. Unfortulate that the archive only goes back to 187, not as far as 121 Paul |
Malcolm Farrant | 01/01/2021 11:19:58 |
102 forum posts 3 photos | The artic;esstarted in issue 4603 and then continued every2 weeks until 4643. Hope that helps. The castings are available from Reves |
Malcolm Farrant | 01/01/2021 11:43:53 |
102 forum posts 3 photos | As usual many many thanks for the helpful answers Best wishes Malcolm |
Former Member | 01/01/2021 12:25:51 |
SillyOldDuffer | 01/01/2021 12:57:05 |
10668 forum posts 2415 photos | Posted by br on 01/01/2021 12:25:51:
I did put up all the info and then managed to duplicate it so altered the duplicated one to say DUPLICATE REMOVED I see the mods have managed to leave that one and deleted the reply that had all the info in which Paul thanked me for. br Sorry br, wasn't me that deleted the right one, but I just zapped the dud... I can't retrieve the lost post because pressing delete is permanent. Dave |
Former Member | 01/01/2021 13:00:37 |
JasonB | 01/01/2021 13:37:53 |
![]() 25215 forum posts 3105 photos 1 articles | Your original is still there at 12.45 with the Volume numbers, Dave has deleted the one that said duplicate which was directly after it. Unless you had put more info in the one that you then changed to duplicate. The ME Beam has been covered several times, the one in vol 122 gives 4 page sover to teh pump though it is fabricated rather than made from castings. |
