Dave Harding 1 | 14/12/2020 00:13:23 |
148 forum posts 4 photos | Hi I have used my lathe before for threading by adding the correct drive wheels and engaging the half nut. I was wondering if it was possible to fit the drive wheels in such a way to just give you a constant slow feed for facing cuts. Hope this makes sense. |
Ady1 | 14/12/2020 00:30:23 |
![]() 6137 forum posts 893 photos | Very useful, gives a nice finish set your changewheels for 100+ TPI kind of thing, experiment on a bit of scrap use your tailstock centre for best results Edited By Ady1 on 14/12/2020 00:31:38 |
Martin Connelly | 14/12/2020 00:31:35 |
![]() 2549 forum posts 235 photos | The answer for most lathes is yes. Some have a selector for fast and slow travel, it depends on the lathe and its features. If you identify which lathe you have you will get a more accurate answer. Martin C |
peak4 | 14/12/2020 02:16:01 |
![]() 2207 forum posts 210 photos | Assuming you still have the same lathe as the one in your album, isn't that the second photo tpi2 ?? Bill |
John Haine | 14/12/2020 05:36:29 |
5563 forum posts 322 photos | Did you mean facing, ie the end of the stock, or turning the outside parallel? |
JasonB | 14/12/2020 07:00:16 |
![]() 25215 forum posts 3105 photos 1 articles | As Peak says if you still have the lathe in the photos set up the gears as per the top chart for feeds, I'd try the 0.089mm/rev first
not done it yet | 14/12/2020 07:29:27 |
7517 forum posts 20 photos | I’ve had two lathes from the same manufacturer. One faced ridiculously slowly at best, while the current one faces at a much better rate. I have a QCGB, so changing from long travel to cross travel with sensible feed rates is easy enough, but with the earlier lathe I almost always fed manually because of the slow feed at the fastest setting. |
JasonB | 14/12/2020 07:35:22 |
![]() 25215 forum posts 3105 photos 1 articles | The one in the photo does not have power X-feed so just set it up for what turning feed rate you want and face by hand. Thats the good thing about the 250-280-290, the front lever gives you 3 rates of shaft rotation which equates to two facing and two turning without having to change the gear train. |
Dave Harding 1 | 14/12/2020 10:39:23 |
148 forum posts 4 photos | Yes, I still have the same lathe as the one pictured. I was wanting it set up to turn the outside parallel and hopefully get a better finish. I would face off by hand. |
JasonB | 14/12/2020 11:31:56 |
![]() 25215 forum posts 3105 photos 1 articles | Just set it up as per my post earlier using the top chart on the front of the lathe |
Dave Harding 1 | 14/12/2020 12:03:53 |
148 forum posts 4 photos | Ok I will try setting it up as you suggest. |
old mart | 14/12/2020 14:07:12 |
4655 forum posts 304 photos | You have to have a lathe with a feed to the cross slide, not all do. |
Howard Lewis | 14/12/2020 14:15:10 |
7227 forum posts 21 photos | For finish turning, the feed rate / rev needs to be as small as possible. Think of it as for cutting a screw thread with the finest possible pitch. So the 0.089 mm /rev will give a feed rate of 0.00352 / rev in Imperial units, equating to a little over 285 tpi. A carbide tip may not like such a fine feed combined with a shallow depth of cut. A HSS tool, especially with a small radius should produce a good finish. HTH Howard
JasonB | 14/12/2020 14:43:09 |
![]() 25215 forum posts 3105 photos 1 articles | Should not be a problem for carbide, I usually use 0.0025" for finishing and get a good cut down to 0.001" DOC |
old mart | 14/12/2020 16:30:26 |
4655 forum posts 304 photos | For fine cuts down to 0.0005" for finishing, get the inserts intended for aluminium, they work well on steel and stainless steel, |
Bazyle | 14/12/2020 16:57:21 |
![]() 6956 forum posts 229 photos | If you don't have a cross feed setting you can use an electric screwdriver or drill with a suitable adaptor, eg a tuning fork shape to engage a ball handle, or perhaps a socket to engage the nut on a round handle. |
Dave Harding 1 | 14/12/2020 20:43:58 |
148 forum posts 4 photos | Thanks for the replies. All the time I have had this lathe and it never dawned on me up till now that the numbers of the change wheels in the top set of figures are for cutting speeds. What a numpty I am. |
