Paul L | 11/12/2020 14:41:09 |
![]() 87 forum posts 26 photos | Hi All, I have been given a large collection of ER collets (sandvik 393 series) but they are a non standard size according to the Spec. the OD is 25.45mm (Nom ER25) but the length is 40.0 mm (Nom ER32). Heaven knows where id get a collet holder. Has anyone any idea if these are of any use or should i just bin them. Regards Paul |
Martin of Wick | 11/12/2020 15:08:13 |
258 forum posts 11 photos | Probably too good to bin. First find someone with a 25 collet holder and check that they might fit (say this because there was 6 or 7mm clearance in the back of the ER32 holder I use. Otherwise, just make a collet holder to suit your requirement, seen some drawings in one of the threads here for basic dimensions, obviously you will have to make radial dim to suit 25s and axial to suit 32s checking to see if there is any change to angular tapers. If the nose angle is as per standard you can save work and just purchase a 25 collet closer. Edited By Martin of Wick on 11/12/2020 15:13:34 |
Thor 🇳🇴 | 11/12/2020 15:22:00 |
![]() 1766 forum posts 46 photos | Hi Paul, If you want to use your "special" ER 25 collets in an ordinary ER25 collet chuck with a MT or R8 shank you may be lucky and find a chuck that will accept your special collets. You will probably find that some machining is necessary, a carbide tipped tool should be up to the job. I have a slightly larger ER 32 chuck and it would be possible to make room for longer collets. If you want to use the collets for workholding in your lathe you could just make your own collet chuck. That is what I did for my small lathe, and the chuck is used quite often. Thor Edited By Thor on 11/12/2020 15:37:40 |
Oily Rag | 11/12/2020 15:28:32 |
![]() 550 forum posts 190 photos | Have you measured the angles? 30 degree front and 8 degree back. If not the same why not make your own holder to suit? Sounds as if an ER25 nut could be used as a closure if the front angle is 30 degree. Seems a pity to waste such a gift horse and if they are SKF manufactured they would/should be pretty good. |
old mart | 11/12/2020 15:32:40 |
4655 forum posts 304 photos | I happen to have some new er25 collets. They are 34mm long and at that length, the diameter is 19mm. This is the free diameter, and if you set calipers to 19mm and the diameter of yours is about that at 34mm from the front end, they might fit an er25 holder. I tried googling Sandvik 393 collets and the result was very different from an er shape. Edited By old mart on 11/12/2020 15:36:22 |
Paul L | 11/12/2020 15:36:41 |
![]() 87 forum posts 26 photos | I never even considered making a collet holder myself! i have a set of ER32 collets and holder for the mill but nothing for the lathe. I will check the angles tomorrow and then try to think of a a way to make the useful on the lathe. Thanks all for the suggestions. Regards Paul |
old mart | 11/12/2020 16:10:10 |
4655 forum posts 304 photos | If you have some er32 collets, you could compare them against the mystery ones, all er collets look similar and their angles match. |
John Haine | 11/12/2020 16:24:32 |
5563 forum posts 322 photos | Making a holder is fairly trivial, I made one successfully quite a few years back when I had very little idea what I was doing! (Not that I do now mind you...)
DC31k | 11/12/2020 16:26:44 |
1186 forum posts 11 photos | Could you have a look inside the collet, specifically at the back. These ones: https://www.sandvik.coromant.com/en-gb/products/pages/productdetails.aspx?c=393.14-20%20d060x049 are for tapping and the extra length may possibly be for the square at the end. |
Paul L | 11/12/2020 16:55:55 |
Thank you John. I'll check the angles tomorrow The bore through the collet is round. Here are some photos, |
Tony Pratt 1 | 11/12/2020 17:20:27 |
2319 forum posts 13 photos | Looks nice quality |
old mart | 11/12/2020 18:02:55 |
4655 forum posts 304 photos | They are definitely not er collets. |
Peter Jones 20 | 11/12/2020 18:11:35 |
![]() 63 forum posts 9 photos | I have some similar, came with 'multi machine (lathe/mill) I bought from a friend who was getting divorced (paid him same as he paid for machine, felt sorry for him) It's closer to a Morse taper but doesn't match MT3 No idea what standard they are but interested in finding out Edited By Peter Jones 20 on 11/12/2020 18:19:34 |
DC31k | 11/12/2020 18:13:14 |
1186 forum posts 11 photos | The characters after the dash on the first line of the part number are the LETTERS 'O' (for orange) and 'Z' (for zebra). If you put that part of the part number into Google, you get to: https://www.sandvik.coromant.com/en-gb/products/pages/productdetails.aspx?c=393.01-oz%201825 which gives a reference of DIN6388. They are likely OZ collets. http://www.collet.com.tw/en/product-c109321/OZ-System.html |
Peter Jones 20 | 11/12/2020 18:24:05 |
![]() 63 forum posts 9 photos | That's impressive searching, my 'Google fu' isn't strong like yours |
old mart | 11/12/2020 19:25:36 |
4655 forum posts 304 photos | I think they could be EOC16 collets, the size looks right. **LINK** Din 6388 is the classification, as DC31k says. Edited By old mart on 11/12/2020 19:32:56 |
Oily Rag | 11/12/2020 19:46:49 |
![]() 550 forum posts 190 photos | Big difference in the back taper angle for the EOC collet - 2.52 degree versus 8 degree for an ER - they must be high precision collets and are worthy of being used - even if you have to make a collet holder. As I said in my earlier post if the front angle is 30 degree then an ER25 nut may be a nailed on bet for a closure nut. |
old mart | 11/12/2020 19:51:32 |
4655 forum posts 304 photos | I believe they are for woodworking routers, the industrial type. |
Paul L | 12/12/2020 09:38:16 |
![]() 87 forum posts 26 photos | Posted by old mart on 11/12/2020 19:25:36:
I think they could be EOC16 collets, the size looks right. **LINK** Din 6388 is the classification, as DC31k says. Edited By old mart on 11/12/2020 19:32:56 I think we have a winner! The Spec says its a EOC16A collet, and the front angle is 30°
Howard Lewis | 12/12/2020 10:53:00 |
7227 forum posts 21 photos | Since they are split from both ends, they will be flexible, like ER collets. Being Sandvik, the quality will be good If an ER clamp nut fits the front end, I would be tempted to make a collet holder for them, so that they can be used. Not being skilled enough to make them, I buy my Clamp Nuts. The pitch for ER Clamp Nut threads is 1.5 mm. I have made holders for ER collets for various jobs, (Tap holders, Collet Blocks, drll / end mill holders for grinding ). If I can do it, you surely can! Howard |
