5 inch gauge wheel standards
David Roberts 2204/12/2020 20:25:03
14 forum posts
Hello and seeking advice on 5 inch gauge wheel standards what should I use I'm thinking of GL5 standards but I don't know if there are others to choose from if there are would you know which is the most popular most widely used.
Thank you very much
David Roberts
Simon Collier04/12/2020 20:59:11
525 forum posts
65 photos
You might have a look at the AALS standard
https://www.aals.asn.au/wp-content/uploads/2019/12/5-inch-gauge-track-wheel-standards.pdf
David Roberts 2204/12/2020 21:11:26
14 forum posts
Hello Simon Collier
I see that AALS standards is used in Australia I'm in the UK are the Australian standards used in the UK.
Thank you very much
David Roberts
Former Member04/12/2020 21:29:08
1085 forum posts
IanT04/12/2020 23:49:32
2147 forum posts
222 photos
David,
I build Gauge '3' engines (not 5" ) so I naturally build them to the G3 track standards because I want my engines (and stock) to run on G3 tracks here in the UK. These tracks have turnouts (points) that don't generally exist on MES tracks. Some of my " 2.5 inch " engines (as acquired) had huge flanges that would have been quite happy on a MES 2.5" track (because they don't have turnouts) but would never (in a month of Sundays) have run on a G3 Garden Railway without change.
You are based in UK. If you want to run 5" on an MES track- then you don't need to worry too much about the finer points of flange width etc - just make sure the engine's gauge is 5".
Whilst the Aussie standards may be perfectly fine (I have no idea) they are of course 'Aussie' standards - and you are not in living in Australia. If you want to run at ground-level 5" in the UK - then clearly the 5GL standards are the ones you need to use (unless you intend to emigrate to Australia of course) because the tracks you will want to visit here in the UK - have (I believe) been designed to support this standard.
IanT
Edited By IanT on 04/12/2020 23:51:11
Brian Baker 105/12/2020 07:38:25
229 forum posts
40 photos
Greetings, I think you will find model engineering UK wheel standards listed on both the Southern federation of M E S or the Northern Association of M E S websites. Whilst the gauge is obviously important, to run cleanly through pointwork, the wheel back to back measurement must be correct.
IanT05/12/2020 10:09:02
2147 forum posts
222 photos
Brian,
The Southern Fed website refers to the old EIM articles (by Martin Baker) about wheel & track standards - as well as referencing 7 1/4" gauge standards. But I wouldn't say that there is much immediate (useful) information there for folks seeking clear guidance on these matters (I don't know about the Northern Assoc.)
Whereas the GL5 Group have very clear, well documented track & wheel standards on their website. If I was just getting into ground level 5" running - then this would be the way I would go. They can be viewed here.
GL5 Track & Wheel standards
IanT
Brian H05/12/2020 10:18:35
2312 forum posts
112 photos
Many thanks for that link Ian.
Dave Smith 1405/12/2020 10:37:09
222 forum posts
48 photos
Comparison of GL5 and Southern Fed standards.
Brian H05/12/2020 13:17:52
2312 forum posts
112 photos
Many thanks for the comparison Dave, As I see it, for all practical purposes there is no difference.
David Roberts 2205/12/2020 16:30:27
14 forum posts
Thank you all for your help
I'm now happy to stick with GL5 track and wheel standards I'd been in touch with the southern Federation model engineers and proved to be very positive I am now settled in the correct standards to use
thank you all very much for your help
David Roberts
