Here is a list of all the postings David Roberts 22 has made in our forums. Click on a thread name to jump to the thread.
Thread: HELP in constructing 5 inch gauge points |
09/12/2020 08:38:09 |
Hello everybody. Brian H thank you for your feedback and I agree with you I was hoping for better response it would be nice to hear from a person or persons who has built points in aluminium for tips on what to do and in my mind just importantly things to avoid things I've learned the hard way save me doing the same thing. Thank you very much. Paul Rushmer thank you for your feedback I have come across the existence of Dennis Monk work on this subject but I failed to get back issues but I did find drawings covering this topic from Dennis Monk I have not received them yet so can't comment on the suitability. I found them at Sarik Hobbies thank you very much. Bazyle thank you for your feedback I viewed the Facebook pages and I'm hoping to find construction using 16mm aluminium thank you very much. Ian T thank you for your feedback hopefully something will turn out thank you very much. Martin Kyte thank you for your feedback the article by Martin Evans looks as if he's purchased the points off the shelf I'm hoping to build my own blur radius and angle that suits that particular point thank you very much. Thank you all once again. |
08/12/2020 11:24:34 |
Hello I'm hoping to construct 5 inch gauge points using 16mm aluminium rail any information on how to construct them and the methods used will be very useful. |
Thread: 5 inch gauge wheel standards |
05/12/2020 16:30:27 |
Thank you all for your help |
04/12/2020 21:11:26 |
Hello Simon Collier |
04/12/2020 20:25:03 |
Hello and seeking advice on 5 inch gauge wheel standards what should I use I'm thinking of GL5 standards but I don't know if there are others to choose from if there are would you know which is the most popular most widely used. |
Thread: Help number two |
04/12/2020 20:19:23 |
Hello Bazyle and br |
Thread: HELP |
04/12/2020 12:29:07 |
Hello everybody |
04/12/2020 09:18:21 |
Could somebody guide me please as regards to wheel standards for 5 inch gauge I'm thinking of GL5 but I don't know if there is anything else what the majority of people use any advice would be appreciated. |
Thread: HELP |
02/12/2020 11:28:45 |
Hello Duncan Webster |
02/12/2020 11:16:15 |
Hello John |
01/12/2020 15:41:41 |
Hello thanks again for coming back to me by the looks of things I messed up my own thread which don't surprise me I'm not very good the computer bit that's missing goes like this. I'm looking forward to getting the workshop together so I can finish the locomotive but I only started it 36 years ago when it first appeared in the magazine engineering in miniature. |
01/12/2020 12:59:21 |
Thank you very much Dave I jest view the video very interesting and makes sense to me if I can learn how to set the gaps correctly during the cold winter there will be a gap full width during the summer the track would be used more often and there should be little or no Gap. |
01/12/2020 12:07:11 |
Hello thank you for coming back to me I have always been under the impression that I would need expansion joints with gaps This is getting very interesting and curious to see if I get more replies especially from clubs with experience of 16mm aluminium rail. |
30/11/2020 20:22:38 |
Hello everybody my name is David Roberts I'm new to this forum I'm building steam locomotive 0-4-0 5 inch gauge. I've had to start over getting a workshop together so far I've purchased a small metal turning lathe, a drill press bench mounted but decent quality and a twin wheel grinder I'm getting the lathe fairly well equipped with tooling. I'm hoping to build a railway at home 5 inch gauge ground level using 16mm aluminium rail and this is where the HELP comes in could you guide me to books or literature of any kind on the subject I could do with knowing what's the widest gap I could leave between the ends of rails at fish plates for expansion without the gap causing problems with trains going over it. Any help delaying ground-level rail aluminium the construction of points curves gradients all of this would be most helpful. |
