LCD to indicate RPM
LCD screen to monitor RPM on stepper motor
martin cross 104/11/2020 17:58:56
43 forum posts
59 photos
I'm looking to fit a stepper motor to my horizontal mill table and wondering if anyone has any experience of setting up an LCD to monitor table speed/motor RPM. There's plenty of stuff on YT using aduino, which you have to code; I was wondering if there was a simpler way using a Stepper Motor Driver Controller PWM Pulse Signal Generator Speed Regulator thingy connected to a stepper driver? If not then I'll probably forget the RPM part, it was just that once knowing what is a good table speed is it can be reproduced as and when needed.
Maurice Taylor04/11/2020 18:18:30
275 forum posts
39 photos
Hi, There are plenty on eBay ,search “tachometer”. Most are less than £20.
Maurice
Robert Atkinson 204/11/2020 19:33:30
1891 forum posts
37 photos
Search on ebay / amazon for PWM Signal Generator There are small modules with 3 digit display and UP/DOWN/SET push button switches that will do what you want. Most will generate 2 different rates. You can use this to control a stepper motor driver which has a step input.
Robert G8RPI.
Edited By Robert Atkinson 2 on 04/11/2020 19:34:17
