Soluble hard varnish that sticks tightly to metal?
John Aitken03/11/2020 10:20:57
14 forum posts
I know this is a difficult one because I've been looking for months and only found one thing that might work but it will be £200.
I do jewellery repair and especially a lot of metal finishing, so polishing, brushing, sanitising etc and sometimes I need to do this on intricate chains and straps. I have techniques for doing this but they could be better which is why I’m looking for some sort varnish or lacquer that I can masks of polished areas with then apply abrasives to the whole work piece then dissolve the varnish so the polished parts stay polished and brushed parts are brushed.
I can and do use tape but it has its limits and is only so practice and is incredibly time consuming on some items. There are a few products aimed at the industry but they are useless to put it bluntly. They from a loose latex layer.
I really appreciate any suggestions and would like to add I’m not looking for a different way of doing things I’m just asking if anyone knows of a protective coat that can be applied to metal that can then be dissolved in anything that won’t damage the metal. Thanks.
Michael Gilligan03/11/2020 10:31:13
23121 forum posts
1360 photos
The obvious choice would seem to be Shellac
John Aitken03/11/2020 10:34:51
14 forum posts
Posted by Michael Gilligan on 03/11/2020 10:31:13:
I did consider that I was just worried the shellac would gunk all the abrasive dust and brushes together.
blowlamp03/11/2020 10:39:28
1885 forum posts
111 photos
Would epoxy paint followed (after polishing) by paint stripper work for this task?
I found Wllko own brand paint stripper to be very effective againgst some Rustoleum twin-pack paint, which was quite abrasion resistant.
Martin.
Dave Daniels03/11/2020 11:08:52
87 forum posts
Conformal Coating ?
Sticks to clean copper PCB. Can be removed with cellulose thinner.
Not sure how it would stand up to being abraded though.
Other stuff that springs to mind is Rustin's Metal Lacquer.
https://cpc.farnell.com/ambersil/6130004030/conformal-coating-acrylic-400ml/dp/SA02317
D.
Edited By Dave Daniels on 03/11/2020 11:12:26
Speedy Builder503/11/2020 11:20:45
2878 forum posts
248 photos
We used to coat aircraft panels with a spray on blue "latex" which protected against scratches during manufacture, and then could be peeled off, but I think you have dismissed that as impracticable.
Cortec product VpCI®-372 ??
Dick H03/11/2020 11:31:15
141 forum posts
How about polystyrene (eg. CD case) or a bit of Lego (colourful ABS) dissolved in acetone to make a paint? Use acetone again to remove.
How hard are you abrading it?
Perko703/11/2020 11:33:35
452 forum posts
35 photos
I've heard of nail varnish being used for similar processes, dissolves in acetone.
Michael Gilligan03/11/2020 12:08:53
23121 forum posts
1360 photos
Posted by John Aitken on 03/11/2020 10:34:51:
Sorry, John ... I apparently don’t understand your ‘process’
... Could you please explain in more detail?
Shellac is hard and brittle; can be dissolved in Meths, and is the basis of traditional lacquers for metals.
John Aitken03/11/2020 12:45:55
14 forum posts
Lots of good ideas here. I shall try some out. Thanks.
