Robert Grain | 01/11/2020 23:33:08 |
9 forum posts 16 photos | Good Evening My name is Rob I live in leicestershire I have been trying not to start more projects in my live but I just can't help it I am a serial starter, A finisher well as I said I'm a good starter so thats got to count for something I have always into making things with wood or metal or with pretty much any thing and love how things work. I have been looking for a metal lathe for a very long time and I finally found one that was near to collect and looked good. It was from a gunsmith that has sadly passed away the amount of grease on it has preserved it rather well.
It is a Myford ML74 Long bed lathe from what I can tell which seems to be from the 1940's and must have so much history to tell. But with history comes war wounds and so with many Ebay bargains It needs a little love and attention. The first thing I checked was the spindle runout and it definatley has some. So I thought it would be as easy as Emailing Myford and giving then a Visa number, Although it seems like the ML74 isn't quite the same for Spares as the ML7 as I hoped. So what started as thinking I would like to make a few small steam engines and see how metal lathes work. I will be on the hunt for ML74 spindles & Bearings. If anyone knows of a similar M type lathe with availble spindles any help would be very much appreciated, I told the daughter of the last owner it was going to a good home and now I'm not so sure. I am sorry I am not an engineer so i will not be much of a giver but I will always try and contribure on the forum if I can be of any help in the future. Thankyou all very much for be inspirations for home workshop wanabe's Rob |
David George 1 | 02/11/2020 07:51:36 |
![]() 2110 forum posts 565 photos | Hi Rob welcome to the forum. I am struggling to find a ML74 lathe and wondered if you have any further info on it. I have an M Type lathe but if you can put some pictures on we may be more able to help. You have to create an album in your profile to post pictures go to top of page and click forums tab. Then look for web site FAQ click that and look for how to post pictures/ photographs. David |
Michael Gilligan | 02/11/2020 08:23:33 |
![]() 23121 forum posts 1360 photos | Is it possible that you have a rare MF74 there, Rob ? http://www.lathes.co.uk/myford%20mf74/page2.html MichaelG. |
Brian H | 02/11/2020 08:53:00 |
![]() 2312 forum posts 112 photos | Hello Rob and welcome. Please have a look at the link in Michael's post above and see if that is the same as yours. You really need to check if the runout is in the spindle or the chuck or merely down to the bearings needing adjusting You will find many people on here happy to help with advice on engines and other projects. Brian |
Guy Lamb | 02/11/2020 08:57:46 |
109 forum posts | Better a serial starter than a 'Gunner' Robert (Gunner start this and Gunner start that). Lots of years experience on this forum let alone common sense to be gleaned. Guy |
Harry Wilkes | 02/11/2020 10:46:17 |
![]() 1613 forum posts 72 photos | Welcome to the forum H |
Robert Grain | 02/11/2020 10:59:54 |
9 forum posts 16 photos | Hello Everyone Thank you very much for the Warm welcome Thank you for the link yes that's the one. I have created an Album and uploaded several photo's although I am sorry to show the mess around it. we are having windows fitted this week and so everything is now piled up as of last night in there. on the right side is a Rover 3.5 V8 waiting for me and the metal around it is a CNC machine in the early stages of the build. Thank you Brian it seems to have the problem I have read about on these that there wasn't a shimmed and at some stage, it has been welded although it seems to be a successful repair although I did see (I believe it was on here) someone had milled away the damage and made a top plate I'm not sure if I have enough talent for that so I thought I would try and use what I have initially, I have taken the Spindle out and it has lots of wear on it there aren't any oilers on it so it has probably just had oil when in use. I did try to tighten the top up a little but it still has the movement of around 1/2mm I'm not sure if it is usable to make small parts or not. I haven't as yet ever used a metal lathe but I thought if I worked on larger lengths it might push away from the cutter giving me a taper but it was just a guess really. I have a small mini Mill which I thought I might be able to repair the Damaged cross slide but I'm not sure if that will work. It does seem like it might be one of the Rarer type ML74 which I always thought rare might be a good thing but then rare means less available parts to I guess. sadly, I'm not even sure if Engineering companies would look at making a bespoke spindle for it. I have never had this type of thing made before. It seems the definition of irony that I seem to need a lathe to get my lathe working. the first-ever lathe must have been a chicken and egg thing going on Guy, I love the comment and I'm definitely Gunner finish something I start one day I hope the album works Thank you
Rob
Michael Gilligan | 02/11/2020 11:56:46 |
![]() 23121 forum posts 1360 photos | Posted by Robert Grain on 02/11/2020 10:59:54:
. […] although I did see (I believe it was on here) someone had milled away the damage […] I have taken the Spindle out and it has lots of wear on it […] I'm not even sure if Engineering companies would look at making a bespoke spindle for it. I have never had this type of thing made before.
. Useful pictures on : **LINK** http://www.lathes.co.uk/myford%20mf74/page3.html Regarding the spindle ... I don’t know what the cost might be, but it looks like something that could be built-up and reground; like they do with motorcycle forks. MichaelG.
Robert Grain | 02/11/2020 12:05:10 |
9 forum posts 16 photos | Hello Michael Thank you very much for the link, That't the one I thought about trying. Sorry for the mis post of saying it was on here . it was the Lathes.co.uk A very informative resource. I did wonder if it could be either taken away and adding smaller ball bearing type bearings or adding but I wasn't sure if it was a system that is used. its certainly worth checking. Thanks Rob |
MadMike | 02/11/2020 13:27:29 |
265 forum posts 4 photos | Rob if you haven't used a lathe before you are welcome to visit me and we can go through some basics to start you on the long road to lathe madness. LOL. I am in Narborough. |
Robert Grain | 02/11/2020 22:50:38 |
9 forum posts 16 photos | Hello MadMike Thank you very much for the kind offer that would be great to visit you if you have some time It looks like it will be at least 4 weeks before we would be allowed. Thanks Rob |
Hopper | 03/11/2020 02:52:50 |
![]() 7881 forum posts 397 photos | Posted by Robert Grain on 02/11/2020 10:59:54:
I have taken the Spindle out and it has lots of wear on it there aren't any oilers on it so it has probably just had oil when in use. I did try to tighten the top up a little but it still has the movement of around 1/2mm I'm not sure if it is usable to make small parts or not. I haven't as yet ever used a metal lathe but I thought if I worked on larger lengths it might push away from the cutter giving me a taper but it was just a guess really. If you have 1/2mm wear in the spindle bearings, the lathe has done A LOT of work. You need to assess wear on the bed, carriage, cross slide and top slide and tailstock before spending any money on a spindle and bearings. It may well be the whole lathe is similarly clapped and not really worth the expense and time of refurbishing. To be useful, those headstock spindle bearings need to have a clearance of about 0.02mm or less. Otherwise lathe will chatter and cut all over the place and not be terribly useful for precision work such as making model engines etc. Cheapest fix might be to get the shaft metal-sprayed and reground. Lots of machine shops do this to salvage pump shafts etc. But the critical eccentricity of the chuck mounting thread and collar to the bearing areas is down to how careful the machine shop is. Pump shafts etc are not as critical in this area as lathe spindles! (Motorcycle forks are hard chromed and reground which is different again and used mostly on sliding elements like forks and hydrualic cylinder piston rods etc.) Then you will still have to get two new bronze bushes made up by a machine shop to suit as they will surely be worn too. Converting to taper roller bearings might be possible but would involve precision machining of the headstock to fit the outer races and is a major project on its own. Suitable sleeves and adjustment facility might have to be made up to adapt the spindle to modern roller bearing inner race sizes too. The MF series (as distinct from the more common ML series and the earlier M-Type) were a quality machine in their day so might be worth fixing if the cost is not too outrageous. But adding a bed and saddle regrind into the mix might make it quite costly, if they are as worn as the spindle etc. |
Robert Grain | 04/11/2020 10:18:06 |
9 forum posts 16 photos | Hello Hopper thank you very much for the information, I will speak to a couple of engineering firms I will have to have a look around to see who does it around here. I was wondering what the amount of movement should be and so very much different, I can feel the difference with my fingers but also the vernier caliper just sliding along picks the difference without even needing a micrometer. The bearings are definitely worn inside and also there is a step on the outer face too. I have started to look for a ball bearing system but the sizes don't seem to be a standard but I have been working in metric so it would be a possible Inch size I might need to look for, (every day is a School Day time to learn imperial properly then It would be a shame if it can't be used but also these things have a finite life but I feel bad telling the lady that it was going to a good home.
Thank you
Rob |
Hopper | 04/11/2020 11:27:05 |
![]() 7881 forum posts 397 photos | Dont waste your time with ball bearings. They are not suitable for a lathe that size. Taper rollers are what is needed. And you wont find either ball or roller bearings that will fit into the same space as those bronze bushes. Machining the headstock will be necessary to fit the outer races. See MEW Issue 285 for an article on measuring Myford bed wear. You will ideally need a micrometer or two but a digi caliper will give a rough idea. Also see this recent thread on doing a ML7 bed **LINK** A quick check is to set the carriage gib strip adjustment so it is a neat sliding fit at the worn part of the bed about six inches from the left hand end and see if it gets tight when moving the carriage to the unworn right hand end of the bed. If so, set it to be a neat fit on the unworn part of the bed and then use a feeler gauge so measure the gap between the vertical surface of the front bed way and the carriage at the most worn spot. That is your wear amount there. Or even use a sturdy steel rule and feeler guages to measure the dip in the worn area. |
Robert Grain | 04/11/2020 13:48:38 |
Thank you very much I will try that and see what I get on there, Thank you very much for the link I will have a look at that too. It sounds like a good challenge to get started on. Thanks Rob |
Hopper | 05/11/2020 01:03:20 |
![]() 7881 forum posts 397 photos | Yes it will be a challenge all right! Vintage machine tool restoration can become an all consuming hobby in itself if you are not careful. (Ask me how I know this!) |
Howard Lewis | 05/11/2020 12:46:44 |
7227 forum posts 21 photos | Welcome! You will find lots of advice and help on here. Definitely a MF74 (cast into your gear cover, and visible in the pictures on the Lathes UK website ) Unlikely to be able to source a new Spindle, for a lathe of that age, so your options seem to be: 1 ) Hard chrome and regrind back to size. (Being of 1940s vintage, sizes and threads are almost certain to,be Imperial. 2 ) Weld and grind back to original size. 3 ) Grind the shaft to clean up and have new bushes made to the new size. 4 ) Have new spindle made 1 ) would be my preference, since it keeps everything standard sizes, and does not involve heat and possible distortion, or changes to the characteristics of the metal. 3 ) would make it like an old London bus, all manner of non standard sizes. Bed wear sounds like LOTS of scraping to bring the unworn areas down to that of the worn. This may then bring the problem that the Tailstock centre is minutely lower than the Headstock centre. But possibly shims in the right place may solve that. As Hopper says, you could be about to embark on a new and unexpected lifestyle! If you can get the machine running again to an acceptable standard, you will have a huge sense of achievement, gained a lot of good experience, and a quite capable machine. It will not happen in a short time, you will need cash, time and lots of patience (Not a feature that I possess ) One suggestion, for later on. Once the lathe is operable again, it might be worth making up and adaptor, with a Thread and register to match the Mandrel, and with an external register and thread (1.125" x 12 tpi and 1.250" register to take the "standard" Myford chucks and Faceplates. Don't forget to make it with two flats for a spanner, to aid removal! Chucks, 3 and 4 jaw, as well as Backplates, are available in Myford fitting. You are likely to need a 4 jaw independant chuck eventually. This might be easier than having to make up your own backplate to match the thread and register on the mandrel. Pure guesswork, but possibly 7/8" x 12 tpi? Please keep us posted as to your progress. Howard
Robert Grain | 05/11/2020 20:24:41 |
9 forum posts 16 photos | Hello Hopper Thanks for the message I think I know what you have in your workshop and more than one |
Robert Grain | 05/11/2020 20:44:10 |
9 forum posts 16 photos | Hello Howard
Thank you very much for the message and fantastic information. With luck, I am installing a computer system at an Engineering firm, and Might just happen to have the spindle and bearings with me to see if they will help. I think I need to learn the art of scraping by the Sounds of it although the Crossslide seems very deep and will probably need to be built up, I have a tig and I have been learning that on my own in the garage making the CNC and 2 pieces of metal stick together and not too messily so I will have to see if I can see if tig will weld to Cast and what rods to use. I'm a little worried about running out of talent when I'm working with things like this without any experience but there is only one way to learn. I have Patience but the time & cash thing is more of a stumbling block but at the moment it will be good to return it to what it would have been, I don't think I'm too much of a purist that I will use the green though I like the grey (I remember spitting image with John major just being grey and dull, now its the colour to have) I love being down with the kids. I must admit I like the idea of being able to make threads so the adapter will certainly be on my list to make when it's up and running.
Everything in my life seems to take longer than originally I think it will but I always keep chipping away at them so if it isn't going to take too much money I will keep going, Although I also have my eye out for a local ML7 if one comes up. I will certainly keep you posted on progress.
Thank you Rob
Hopper | 06/11/2020 02:04:57 |
![]() 7881 forum posts 397 photos | Posted by Robert Grain on 05/11/2020 20:44:10:, Although I also have my eye out for a local ML7 if one comes up.
Dont limit your options. If you are in the UK and want old Brit machines you might easily find a Boxford or Raglan lathe cheaper than a Myford -- and both are better machines than the Myford but just don't have the cult following that pumps prices up. (Ducks for cover!) But it all comes down to what kind of condition the individual machine is in -- as you have found! Welding up your cross slide risks seriously distorting the whole thing with heat. And scraping a lathe bed is a huge undertaking requiring some advanced skills and special equipment so you might look deeply into that before taking the plunge. |
