Dr_GMJN | 22/10/2020 17:43:09 |
![]() 1602 forum posts | Apologies if I've already asked this at some point - I got side-tracked with finishing a project rather than fettling equipment. Does the Arc-Euro ML7 cross-slide bearing upgrade also apply to the compound slide? Thanks. |
Dr_GMJN | 23/10/2020 21:32:16 |
![]() 1602 forum posts | Apparently it only applies to the cross slide. Not sure why. |
Steviegtr | 23/10/2020 21:42:44 |
![]() 2668 forum posts 352 photos | I this the needle roller bearing thrust washers. Steve. |
Dr_GMJN | 23/10/2020 22:15:42 |
![]() 1602 forum posts | Posted by Steviegtr on 23/10/2020 21:42:44:
I this the needle roller bearing thrust washers. Steve. Yes. |
Steviegtr | 23/10/2020 23:55:58 |
![]() 2668 forum posts 352 photos | I was having issues with my cross slide with play. Not sure if you saw my youtube vid addressing this, without any needle roller bearings. I do prattle on a bit but you will see the basics of the problem i had & managed to fix. Steve. |
Clive Hartland | 24/10/2020 07:27:50 |
![]() 2929 forum posts 41 photos | If you do this mod to the cross slide remeber you cannot do it on the lathe you take apart. It might be better to buy a spare bearing bracket and machine that and the replace on the lathe. I did this on my ML10 and it makes a big difference to its operation. In this case I took the bearing bracket off my vertical slide and machine that and the swapped them over. Whether the ML7 vertical slide bracket is the same as the lathe cross slide bracket i do not know. |
Mike Poole | 24/10/2020 08:02:57 |
![]() 3676 forum posts 82 photos | I locked the cross slide and used the top slide swung round to 90°, it’s handy to have a leadscrew handwheel sometimes. Luckily you need very little travel for the facing operations so just make sure the top slide handle clears the cross slide for the required travel and the cross slide is locked in the right place. A bit of a fiddle about but it worked for me. Mike I can’t remember how I clamped the top Slide to the cross slide as the ML7 doesn’t do 90°, must have been one of my alternative engineering solutions. Edited By Mike Poole on 24/10/2020 09:13:50 |
Dave Wootton | 24/10/2020 09:03:44 |
505 forum posts 99 photos | My friend did this to his ML7, on the cross slide, top slide and vertical slide,as far as I know using the bearings from Arc for them all. I know he was extremely pleased with the results. He either jury rigged a bracket to replace the cross slide bracket or used the vertical slide one, I can't remember, and as he sadly passed away a couple of years ago so I can't ask him. I remember offering him the use of my lathe to carry out the machining, but overcoming obstacles and being independent were all part of the fun for him. It seems a very worthwhile mod which I intend to do to my ML7R which has the same cross and top slide to the ML7. Dave |
Malc | 24/10/2020 09:31:13 |
113 forum posts 6 photos | I did this mod to both cross slide and top side. I posted about this in December 2017, if you check my posts it will explain how I did it. All the best. Malc. |
Dr_GMJN | 24/10/2020 10:27:21 |
![]() 1602 forum posts | Thanks guys. yes I’ve figured out how to use the slide in question using a dummy bracket, so that I can use the lathe to make the mod - no problem there. Looking at the castings I can’t figure out why Arc have told me the kit is “not suitable” for the cross slide? I’m sure it’ll become clear at some point (leadscrew dimensions perhaps?), so I wondered if there was a reason you *shouldnt* do it as opposed to not being able to use the same bearing set as for the cross slide? I doubt very much this is the case. I converted both axes of my SX2P to needle bearings without issue, and it’s made a massive improvement to the overall feel of the machine. |
Clive Hartland | 24/10/2020 10:41:56 |
![]() 2929 forum posts 41 photos | If you look in Arcs. listings and go down to projects there is the detail for the clross slide modification for the 'ML7' It also applise to the ML10 |
Dr_GMJN | 24/10/2020 11:08:23 |
![]() 1602 forum posts | Posted by Clive Hartland on 24/10/2020 10:41:56:
If you look in Arcs. listings and go down to projects there is the detail for the clross slide modification for the 'ML7' It also applise to the ML10 Thanks Clive, I realise that, but was just wondering why it couldn’t also apply to the top slide. |
derek hall 1 | 24/10/2020 11:56:20 |
322 forum posts | Hi I am almost at the end of the modifications to my Myford super 7 crosslide as per the design by George Thomas. I fitted two sets of needle bearings etc as per the design. I will try and post some pics soon. When I had to modify the crosslide bracket I had to mount it on the faceplate and then having no crosslide function, I swung the topslide through 90 and used that as the crosslide. It went ok, but I was extra careful as didnt have a spare bracket if it all happened to end in disaster! So far it's looking to be a fantastic upgrade to the old super 7 crosslide. Regards to all Derek |
Dr_GMJN | 24/10/2020 15:24:46 |
![]() 1602 forum posts | So I had a quick look at the the slides this morning, and there seems no problem with fitting identical bearing sets to both. I have no idea why Arc said they weren't suitable. No doubt some unforeseen issue will raise it's head when I've machined some critical part! |
Dr_GMJN | 03/11/2020 18:03:54 |
![]() 1602 forum posts | Not sure what the issue was supposed to be with fitting the Arc bearings to the top slide - if anything they're easier to fit than the cross slide: |
