Other uses for horizontal milling cutters?
Dave Sawdon 120/10/2020 14:28:00
49 forum posts
4 photos
I've recently sold a horizontal mill and will soon have a new vertical mill to play with. I now have a large number of horizontal cutters (side and fence, angle, double angle, slab, concave, convex, involute, slitting, etcetera) to dispose of but, before advertising them, I wondered whether the smaller ones could be used on an arbor in the vertical mill, or whether anyone had found other uses for them. It's clear that the slitting saws can be used, but what about the rest?
Dave Halford20/10/2020 14:53:50
2536 forum posts
24 photos
Gear cutters are OK, but that was a Centec in vertical mode. So I suppose anything up to 3/16 wide depending on your new mill.
Speedy Builder520/10/2020 15:41:09
2878 forum posts
248 photos
Never thought about it before, but I suppose you could convert a vertical mill into a pseudo horizontal mill by making an arbor support for the vertical column and making a spindle to go from the quill to the arbor support (in the Z axis). The milling vice / fixtures would present the workpiece such that milling would be done along the Z axis face. Not ideal, but could be managed especially if the vice was mounted on its own universal slide.
Nigel McBurney 120/10/2020 17:03:36
1101 forum posts
I recently started to downsize my workshop pending the sale of my property and then it all fell through,my advice is that if you get rid of something you will need it next week,so keep your cutters,just oil them and stop rust. A lot of cutters can be used in a vertical mill. Another use fo convex and concave cutters is mount them on a length of bar so that they can be used in the toolpost of your lathe,they make very accurate radius form cutters,when one tooth gets blunt rotate the cutter one tooth and get another sharp cutter.I certainly would not dispose of slitting saws and gear cutters.
Steviegtr20/10/2020 17:46:41
2668 forum posts
352 photos
Make a large MDF board & start Ninja star throwing competitions. Sorry in advance.
Steve.
Bazyle20/10/2020 17:59:37
6956 forum posts
229 photos
Can still use them in the lathe on an arbor.
If you want to sell them rather than just clutter ebay don't copy the prices you see there. Cutters seem to be 3 times the sensible price at the moment as house clearers and widdow robbers are listing stuff they know nothing about.
Nicholas Farr20/10/2020 19:25:48
3988 forum posts
1799 photos
Hi Dave, well I used a slot cutter which is 1/2" wide on my Major mill to true up two edges of this piece of T section.
I then used a single 60 degree angle cutter to put a bevel on each side of the bottom of the T section.
Didn't experience any problems, but it's fair to say that I probably didn't take such a deep cut that one would on a horizontal mill.
Regards Nick.
Edited By Nicholas Farr on 20/10/2020 19:29:00
Vic20/10/2020 21:42:39
3453 forum posts
23 photos
Yes I’ve used them a few times.
AJAX20/10/2020 22:45:06
433 forum posts
42 photos
I've sold numerous cutters that came with a small horizontal mill. The smaller diameter ones sell easiest, but the large ones you can't give away. Like you, I've still got a box of them just in case they are needed one day.
Dave Sawdon 121/10/2020 09:44:15
49 forum posts
4 photos
Thanks for the quick responses. I think I'll advertise the larger ones and keep the others for a while to see whether they get called-upon.
Len Morris 221/10/2020 11:21:54
57 forum posts
29 photos
Hi Dave,
Sadly I think Ajax is right. Spare the effort and just weigh the larger ones in at your local metal dealer. Some 10 years ago Lancashire had no end of industrial Ironmonger shops. As they closed, clearance stock was put in the shop windows at silly prices. Brand new 5 inch diameter 1+1/8 bore cutters any width any form for one pound each. Leaving one shop with a slab cutter 4 inches wide and 4 inches diameter a chap entering asked me how much I'd paid. To the response of £4 he said it used to be priced at £395! Turned out he was the shop owner.
As a final thought, you could always get the Mig out and make something 'arty' with them. You'd be amazed what people will paysmiley.
Len
Andrew Johnston21/10/2020 11:53:12
7061 forum posts
719 photos
Posted by Len Morris 2 on 21/10/2020 11:21:54:
If I recall correctly I expressed an interest in buying the larger cutters, but AJAX never bothered to respond. sad
