Russ B | 19/10/2020 18:43:26 |
635 forum posts 34 photos | Does anyone have a pdf manual they could share with me for the Colchester Bantam or Harrison M250, I just want to make sure I’ve adjusted the spindle bearings properly on my Myford 280 which looks like it’s cut from the same cloth as the above two machines. |
Emgee | 19/10/2020 19:11:27 |
2610 forum posts 312 photos | Russ If you don't have the Myford 280 manual you can get it here by joining the group Emgee |
Russ B | 19/10/2020 19:40:08 |
635 forum posts 34 photos | Thanks, i’ll take a look. The lathe came with a user manual and parts diagrams but I don’t recall seeing any maintenance info beyond oiling etc Edited By Russ B on 19/10/2020 19:40:40 |
Emgee | 19/10/2020 23:20:40 |
2610 forum posts 312 photos | Russ B Just checked the Bantam manual and it states adjust the rear bearing until end float is 0.0001" when the chuck should still turn freely. It does warn not to overtighten so care is needed in making any adjustment. Emgee |
Thor 🇳🇴 | 20/10/2020 05:31:22 |
![]() 1766 forum posts 46 photos | Hi Russ, There is a Colchester group on groups.io that you may find useful. Thor |
not done it yet | 20/10/2020 09:05:54 |
7517 forum posts 20 photos | Lathesdotco say they were designed to compete with those better manufactures (not to the same design) - a subtle difference that Tony at lathesdotco likely understood. I would expect the Raglan lathes are more akin to these myford designs? Certainly the 254 looked like a Raglan redesigned with an oil filled gearbox... |
Russ B | 20/10/2020 13:03:57 |
635 forum posts 34 photos | Not sure about the Raglans, the 280 looks identical in many ways to the Harrison M300, same bed casting, same saddle, same headstock casting but the two speed change levers are mounted on top of the Myford but are still basically the same inside the box. The apron and the screw cutting box are different but elsewhere the similarities seem never ending! It seems no one knows anything about their manufacturer but I’ve seen so few out in the wild I wonder if they ever produced them in any reasonable quantity. Someone must know something, I’d assumed they were made in nottingham but never seen any photos of the production, whereas there are many pics and history of the rest of the range. I’d be surprised if they weren’t made by Harrison. |
