John Rudd | 14/10/2020 10:30:06 |
1479 forum posts 1 photos | So while I await the arrival of my Worden kit (due tomorrow...👍 ) I'll ask another question..... What do folk use for adding the clearance on end mills that are not centre cutting...or even those that are... I see some of my cutters are gashed and others have a ground depression.... The ground depression isnt easy to achieve from what I've tried ( carbide burr, tapered grinding point...) I guess gashing with a thin blade of some sort is the order of the day...? So how do you achieve your clearances? Edited By John Rudd on 14/10/2020 10:30:48 |
John Haine | 14/10/2020 10:39:14 |
5563 forum posts 322 photos | Unless your cutter is badly worn/resharpened it shouldn't need more off, but if it does then gashing is the only thing you can easily do, using a thin cutting disc. IIRC Chaddock describes it in the Quorn book. |
Tony Pratt 1 | 14/10/2020 10:39:52 |
2319 forum posts 13 photos | Thin saucer shaped wheels. Tony |
Thor 🇳🇴 | 14/10/2020 12:16:53 |
![]() 1766 forum posts 46 photos | Hi John, On the centre cutting endmills I use a thin cutting disc in my Dremel before grinding the cutting edge. Thor |
John Rudd | 14/10/2020 12:22:34 |
1479 forum posts 1 photos | Thanks for the replies everyone,
So are we gashing the clearance free hand or using some jig/toolholder while doing this? I'm thinking that anything sized under say 8mm is going to be a challenge? |
Thor 🇳🇴 | 14/10/2020 12:40:15 |
![]() 1766 forum posts 46 photos | I'm doing the gashing free hand, and yes, my old eyes struggles with the small cutters so a jig is on my to do list. Thor |
Chris Evans 6 | 14/10/2020 13:09:03 |
![]() 2156 forum posts | I mount up a thin elastic cut off wheel and gash freehand. I do a batch then set up the Cuttermaster cutter grinder for side or end work as required. |
Clive Brown 1 | 14/10/2020 13:19:15 |
1050 forum posts 56 photos | I don't recall the Prof. describing gashing in the original ME series, but he did emphasise the delicacy of setting up to sharpen slot drills which had an over-centre cutting lip. In those days, all end mills seemed to come with central hollow, whereas now they all seem to be centre cutting. Another point he made re end mills was to sharpen with the end teeth set in 1 deg. inwards towards the centre. This is to allow for tooth wear being greatest on the outer diameter and avoid cutting on the heel of the tooth. |
Howard Lewis | 14/10/2020 20:14:31 |
7227 forum posts 21 photos | Afraid that I gashed the few that have been sharpened with a thin disc in an angle grinder. Not very precise, but did what was required at the time! Howard |
