Cant drill the hole in the valve chest
Jim Beagley | 02/10/2020 19:14:48 |
106 forum posts 52 photos | Hi all. I'm a long way into my first build of a steam engine - an S-50 - and thoroughly enjoying it, but I've just hit my first issue making the valve chest and wondered if there was an easy solution. The plan calls for a 0.07" hole in the far end of the chest from the rod entry, for the end of the valve rod to ride in (this is incidentally wrongly dimensioned as 0.7" on the plans - I wonder if anyone ever tried that). So the problem - there no way that my 1.8mm drill is going to be long enough to reach through the chest and drill this hole. I could drill it bigger and fit a bush, but is there something simpler I'm missing? Thanks all. |
alan-lloyd | 02/10/2020 19:20:54 |
![]() 183 forum posts | Phone Tracy Tools and order a long series drill |
JasonB | 02/10/2020 19:27:24 |
![]() 25215 forum posts 3105 photos 1 articles | Another option that you may just get away with though easier if you drop down to 1/16" or 1.5mm is to drill the end of some 3/32" rod with your drill and then Loctite it into the hole which gives you a long reach drill. Gentle heat will get it back out again. A few other options in this article hidden in the depths of the ME site, changing the pdf number will give you all the parts of the article |
Jim Beagley | 02/10/2020 20:10:20 |
106 forum posts 52 photos | Thanks for the ideas and the link to the article. I'm not sure that I'm comfortable with that thin a drill over that distance so I may go with my initial idea of a bush. Thanks all. |
Jim Beagley | 17/10/2020 23:40:46 |
106 forum posts 52 photos | I’ve now finished my first steam build, my Stuart S-50. |
Oldiron | 18/10/2020 10:54:30 |
1193 forum posts 59 photos | Very nice looking job Jim. Have you tried it on air or steam yet ? regards |
Jim Beagley | 18/10/2020 12:27:45 |
106 forum posts 52 photos | Hi OldIron. Sadly I don’t have a boiler to steam it on which would be ideal. jim
Steviegtr | 18/10/2020 12:49:59 |
![]() 2668 forum posts 352 photos | That looks great Jim. Well done. Steve. |
Jim Beagley | 18/10/2020 15:50:41 |
106 forum posts 52 photos | Thanks Steve. |
