Loc Tite
Alan Gordon 415/09/2020 17:34:40
129 forum posts
13 photos
Hi everyone. I had to secure a component on a piece of 5mm drill rod with loctite to carry out further work. In order to remove the component I had to heat it up to enable me to remove it from the shaft. However I want to get rid of the residual loctite still within the bore, I dont want take the chance of damaging the bore so is there a chemical that i might use to removed the loctite ?
Brian Wood15/09/2020 18:20:11
2742 forum posts
39 photos
Hello Alan,
Try drilling it out using a 5 mm drill, with the drill held in a pin chuck so the the operation is done by hand
Regards Brian
Michael Gilligan15/09/2020 18:26:26
23121 forum posts
1360 photos
From the 638 technical data sheet :
“Cured product can be removed with a combination of soaking in a Loctite solvent and mechanical abrasion such as a wire brush.”
... It’s pretty resistant to most solvents !
Alan Gordon 415/09/2020 18:26:59
129 forum posts
13 photos
Hi Brian,
Yes i thought about this but the hole is reamed to 5mm and the component will eventually go back onto a 5mm shaft. So I am trying to maintain the reamed dimension, my thoughts are with trying to dissolve the residue out rather than mechanically remove it.
Alan Gordon 415/09/2020 18:29:04
129 forum posts
13 photos
Second thought ! I wonder if "Super Glue" solvent would work ?
Edited By Alan Gordon 4 on 15/09/2020 18:29:52
Howard Lewis15/09/2020 18:29:20
7227 forum posts
21 photos
You might have difficulty finding chemicals to remove the cured anaerobic, so, as Brian says, you will have to use mechanical means.
You may have problems looking down a 5 mm hole to see when all has been removed. Although if the rod was 5 mm the hole is likely to be oversize by about 0.025mm so making a nat's bigger may not matter that much.
Rolled up Emery perhaps?
Howard.
Alan Gordon 415/09/2020 18:30:43
129 forum posts
13 photos
Interesting Howard, thank you
Michael Gilligan15/09/2020 18:43:38
23121 forum posts
1360 photos
Posted by Alan Gordon 4 on 15/09/2020 18:29:04:
What grade of Loctite did you use ?
... I only chose 638 to reference in the absence of any detail.
Robert Atkinson 215/09/2020 19:03:05
1891 forum posts
37 photos
You could go to the source
https://www.henkel-adhesives.com/mx/en/insights/all-insights/blog/how-to-remove-red-threadlocker.html
old mart15/09/2020 19:09:54
4655 forum posts
304 photos
Using the same reamer with plenty of oil would be my first thought. It is very difficult to enlarge a hole that has already been reamed. Make a test piece first out of the same material if the original hole is critical.
alan-lloyd15/09/2020 19:11:19
183 forum posts
Try nail varnish remover, or print head cleaner - acitone
