Carlos Moura | 17/08/2020 17:18:42 |
3 forum posts | Hi! I'm constructing a boiler following an youtube video from Myfordboy. I'm in the soldering phase and came across an issue. I soldered the two plugs on the top cap with ease but when I tried to do the same for the water gauge plugs at the tube the silver solder didn't flow. I'm using a MAPP torch with 30% silver stick. The tube is a 3inch by 1.5mm. I mantained the torch open for more than 5 minutes but failed. Do I need a more powerful torch? Thank you! Carlos Moura Sao Paulo, Brazil |
David George 1 | 17/08/2020 19:54:36 |
![]() 2110 forum posts 565 photos | Hi Carlos welcome to the forum. It sounds that you need a larger blow torch and what are you using to sit the tube on as you will need a hearth to contain the heat whilst getting it hot enough to flow. David Edited By David George 1 on 17/08/2020 19:56:11 Edited By David George 1 on 17/08/2020 19:56:32 |
Carlos Moura | 17/08/2020 21:52:30 |
3 forum posts | Hi David!
I bought a mini oxi-acetylene torch ( it will be delivered wednesday ). I'm using some bricks where I place the parts to be soldered. Thank you very much for your help. *** I'm returning to the model making after 30 years and I'm new to the model steam world. Cheers
Carlos |
David George 1 | 17/08/2020 22:21:05 |
![]() 2110 forum posts 565 photos | The oxycetaline torch is OK for local heat but I believe a propane large heater is better for large pieces to silver solder. You will need some long lasting flux and some heat reflecting blocks and matting. Have a look on this web site Cupalloys. For demo and suplies.
https://www.cupalloys.co.uk/home/index.asp David |
Carlos Moura | 18/08/2020 00:50:46 |
3 forum posts | Thanks for the hints! The website has lots of good information. I'll try again using your advice! Cheers Carlos |
Paul Lousick | 18/08/2020 09:52:35 |
2276 forum posts 801 photos | I was surprised at how much hotter a propane / oxugen torch is compared to MAP gas. Today tried to braze held a small part and the MAPP gas torch melted the brazing rod onto the job after 4 or 5 minutes. Tried the oxy torch on a very low flame and melted in less than half a minute. Paul. |
