Here is a list of all the postings Carlos Moura has made in our forums. Click on a thread name to jump to the thread.
Thread: Issues trying to silver soldering a 3" copper tube |
18/08/2020 00:50:46 |
Thanks for the hints! The website has lots of good information. I'll try again using your advice! Cheers Carlos |
17/08/2020 21:52:30 |
Hi David!
I bought a mini oxi-acetylene torch ( it will be delivered wednesday ). I'm using some bricks where I place the parts to be soldered. Thank you very much for your help. *** I'm returning to the model making after 30 years and I'm new to the model steam world. Cheers
Carlos |
17/08/2020 17:18:42 |
Hi! I'm constructing a boiler following an youtube video from Myfordboy. I'm in the soldering phase and came across an issue. I soldered the two plugs on the top cap with ease but when I tried to do the same for the water gauge plugs at the tube the silver solder didn't flow. I'm using a MAPP torch with 30% silver stick. The tube is a 3inch by 1.5mm. I mantained the torch open for more than 5 minutes but failed. Do I need a more powerful torch? Thank you! Carlos Moura Sao Paulo, Brazil |
