power feed for miller
larry phelan 115/08/2020 12:58:17
1346 forum posts
15 photos
Good morning all,
I am about to fit a power feed unit to my milling machine.
The unit comes with a 110V plug unsuitable for our system, so needs to be replaced. The wires are black white green.
Which is the live, white or black ?
I suspect it is white, but just to be sure I decided to check
Thanks for your help [always available ]indecision
John Haine15/08/2020 13:09:27
5563 forum posts
322 photos
Umm... If it's a 110V plug, is a 110V motor? If so it might not be a good idea to just put a new plug on it, you would need a transformer too...
DC31k15/08/2020 13:17:17
1186 forum posts
11 photos
If it is AC, it does not matter which you connect to live or neutral, but US wiring uses black for live.
See:
https://www.graphicproducts.com/articles/wire-color-coding/
As John says, you need a transformer. A standard yellow building site one is cheap.
Bryan Cedar 115/08/2020 13:23:32
127 forum posts
4 photos
You talk of two connections, do not forget the earth!
larry phelan 115/08/2020 16:58:01
1346 forum posts
15 photos
Yes John, it is a 110v motor, was ordered as such, so was fitted with a 110v moulded plug, just not the type we use., that,s why a new one has to be fitted. and I do have a transformer.
Bryan, I did notice the earth connection, I,m not that brave. I dont take chances, even with 110 v !
Thanks to all
Michael Gilligan15/08/2020 17:54:29
23121 forum posts
1360 photos
It’s a lazy and extravagant option, but adaptor leads are available to suit the yellow ‘site’ transformers:
A google search for :
iec 110v plug to american
should find one for around £25
That said, it’s only a five minute job to put an IEC plug on the lead.
MichaelG
Meunier15/08/2020 20:22:54
448 forum posts
8 photos
I'm resisting the temptation, I really am trying, to enquire if that will need 'Arctic' cabling ? Oh, weak-willed again.......
DaveD
Paul Kemp16/08/2020 00:42:41
798 forum posts
27 photos
I think it might need tropical cable at present or even sub sea cable depending on your location......... In fact an adaptor lead may be a very good suggestion, could have one for all seasons!
I'll get my coat,
Paul.
larry phelan 116/08/2020 10:05:33
1346 forum posts
15 photos
Maybe I should just go back to spinning the hand wheels ?frown
