Point on a Thread Tap
Vic08/08/2020 18:43:48
3453 forum posts
23 photos
I realise it’s there to aid manufacturing but why do some manufacturers leave the point on whilst others grind it off? Just wondering!
Howard Lewis08/08/2020 18:50:37
7227 forum posts
21 photos
Cost of removal?
Aid to holding for sharpening?
Not long ago, I need to tap some 5 x 0.5 mm holes, only 3.5 mm deep, so the tap was ground to a flat end. Fortunately, it worked O K despite having no lead in chamfer.
Andrew Tinsley08/08/2020 19:23:48
1817 forum posts
Depending on size of tap either a centre hole or a point is left by the manufacturer. They are there so that the tap can be accurately aligned on a tool and cutter grinder for resharpening.
Andrew.
OneManEngineering08/08/2020 20:01:36
33 forum posts
48 photos
Generally speaking the smaller sizes have point tip so you need something like a cone to aid aligning.
the bigger ones have hole so you can use a tap follower.
answer is simple: there is no room to centre drill the little ones.
Greg
Martin Kyte08/08/2020 20:06:10
3445 forum posts
62 photos
So you can use it as a dot punch.
regards Martin
