Here is a list of all the postings OneManEngineering has made in our forums. Click on a thread name to jump to the thread.
Thread: Archdale Vertical Mill |
11/01/2021 08:04:49 |
Thanks Jon, I haven’t seen these before. regarding the ago of my machine, I HAVE NOT A CLUE! i know nothing about it. Very weird that no serial numbers or dates shown anywhere. my next task after finishing the INT40 taper conversion will be to mount the motor into the side of the machine as it is floor mounted now. And I hate it. The only problem is I need to find a motor. The one that came with it weighs a ton so wouldn’t be suitable. Greg
11/09/2020 21:32:15 |
Posted by Tony Simons on 14/04/2016 19:53:10:
Thanks Mike I have seen the archive but nothing related to this model. Hey,
I know it’s been a while, but did you find anything? i am in the same shoe and was wondering if you gathered anything and wouldn’t mind sharing. many help would be awesome. |
Thread: Vfd sizing |
08/08/2020 20:21:55 |
Just don't go too OTT. if the VFD is way too big, its safety features might not work on a smaller motor. for ex if you have a 3HP VFD, the internal safety, overload protection might not perform correctly and you risk not protecting the motor.
also I suggest 1 VFD per 1 motor.
Greg |
Thread: Point on a Thread Tap |
08/08/2020 20:01:36 |
Generally speaking the smaller sizes have point tip so you need something like a cone to aid aligning. the bigger ones have hole so you can use a tap follower. answer is simple: there is no room to centre drill the little ones.
Greg |
Thread: VFD. XSY AT4 220v 1phase to 380v 3phase advice sort |
08/08/2020 19:46:27 |
Posted by Robert Atkinson 2 on 03/08/2020 11:43:44:
That protective earth (PE) connection looks pretty scary. Red insulation and a straght bit of solder tinned wire under a PCB mounting screw, The wire clearly is not large enough to carry fault currents on a system fused for 3kW (13A). Solder tinned wires (tin plated is different) should never be used under screw or crimp connections, The solder cold flows under pressure and a bad joint results. Used to be common with mains leads before pre-fitted plugs to find the leads solder tinned but this was found to be the cause of loose connetions and over-heaing plugs. Red wire on a PE is a technical breach of the acceptable standards.
These things are a liability. As a minimum they must be inside a suitable enclosure. The user is legally responsible for making sure the installation is compliant with all relevant safety and EMI/EMC standards. In practice this does not happen. Robert G8RPI. Hey Rob, could you pls have a look at this: What do you suggest what to do? I kind of figured I ground my motor to the VFD's PE, but you kinda made me change my mind. (This is the only ref point that I could call GND.)
What shall I Do? Thanks, Greg |
08/08/2020 19:42:31 |
Guys, thank you ever so much for y'all input. I went back to the vendor and they asked me to go and have it fixed somewhere near me and they shall bear the costs. That means one thing I guess... yep its a sort of mutant between 220V and 380V. dang! Hence why it doesn't do what yours does. So I am now getting a new one, hopefully a working one this time.
Greg |
05/08/2020 00:43:27 |
Posted by James Walker on 02/08/2020 20:45:55:
I always took P00 as being the max V that the unit could output. The reason being that P02 and P04 have a cap of either 220V or 380V which I believe is determined by P00. Anyway I have my P00 set at 380V and it is fed a 220-230V supply. Also if you have settings that you cannot change you need to input the default "0" password into P09. i.e. jusrt go into param update mode, go to input mode on P09 and "set" the value to 0. This should unlock everything. Did for me.
Cheers, James.
Well, I have tried! Still don’t work. I set P002 to 190V but P000 still don’t go over 220V.
HOW DO YOU DO A FACTORY RESET ON THIS THING?
Greg
03/08/2020 09:56:40 |
Posted by john fletcher 1 on 03/08/2020 09:53:08:
I have been reading with interest the threads relating to the the XSY inverter. Would a reader please tell me the make of the XSY 2.2 Kw inverter, could it be a Huanyang ? John It certainly isn't, but it looks to me that its a sort of copy. It works. I can recommend, but you need to learn the new Chin-glish language. At least my manual is written in that :D
03/08/2020 09:54:09 |
Posted by Andrew Firman on 02/08/2020 21:14:08:
Posted by Andrew Firman on 02/08/2020 20:12:59:
Sorry Greg, Senior moment! James is correct . P000 on mine is set at 380V.. You're forgiven! I am getting there too. |
03/08/2020 09:52:41 |
Cheers, James.
Ill try to enter the password and see if I can change P000. This thing spins my motor up nicely, make no mistake about it, but unable to measure RPM. BTW, my motor is in DELTA!. |
02/08/2020 19:39:15 |
Also Can someone shed some light as to why I can not go over 220V in P000, where I should be able to reach 380V. Ive got XSY-AT4 as well. Is it a faulty item, or supposed to be this way?
https://youtu.be/4tr-i-XGOC8
Thanks, Greg Edited By OneManEngineering on 02/08/2020 19:47:09 |
02/08/2020 12:49:17 |
Posted by Andrew Firman on 23/05/2020 13:32:14:
I have a couple of 2.2Kw XSY AT4 which I want to use to power a couple of 380V 3 phase star wired motors using 220v single phase supply.
Greg Edited By Greg The Londoner on 02/08/2020 12:49:41 |
Thread: Greg, the Londoner, SE8 |
22/05/2020 20:22:09 |
Thread: Elliott dividing head |
22/05/2020 20:07:47 |
22/05/2020 19:59:12 |
And the refurbished Elliot/Victoria Dividing Head:
https://www.model-engineer.co.uk/albums/member_album.asp?a=52943 |
22/05/2020 19:58:07 |
Guys just uploaded couple of pictures of the revival of this nice piece of kit. Please have a look at my album. Also I will upload some footages as well after I finished editing. Youtube link will be provided...
I have to say I am pretty pleased with it.
22/05/2020 19:55:03 |
Just uploaded couple of new pictures of my newly acquired Archdale Horizontal Mill, please have a look:
https://www.model-engineer.co.uk/albums/member_album.asp?a=52853 |
Thread: Archdale Horizontal Milling Machine |
22/05/2020 19:53:24 |
22/05/2020 19:52:46 |
uploaded couple of pictures of the machine: |
22/05/2020 19:33:15 |
UPDATE:
the machine finally arrived at my workshop despite COVID19. I tried to keep 6ft from the machine but could not! It was hell of a journey that's all I can say. I'll upload some footage after I edited them. But still have absolutely nothing on this machine. Archdale has never given serial number to the its machines, just the type, this being a 20" Horizontal Mill.
Any chance of someone somewhere has any literature of Archdale???
